Old 11-24-2005, 04:59 PM
cobradav cobradav is offline
Officially Welcomed to The 'Fest
Mein Auto:
Svc Bulletin for Recent 6er Cabrios (3rd brake light)
SI B 63 05 05 Lights September 2005
Technical Service
SUBJECT
Third Brake Light Cracked
MODEL
E64 (6 Series) from 6/05 to 8/05 Production
SITUATION
The third brake light lens may crack.
Approximately 30 millimeters from the left or right side of the brake light the lens may crack.
CAUSE
Excessive tension on the third brake light lens. A change has been made in the tempering process.
PRODEDURE
For all affected vehicles, on a customer complaint basis, replace the third brake light. Refer to TIS (RA 63 25 000) for replacement instructions.
PARTS INFORMATION
Part Number Description Quantity
63 25 6 911 909 Third Stop Light 1
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Old 11-24-2005, 05:31 PM
SmoothCruise SmoothCruise is offline
Mein Auto: 645 Convertible
Technical Service
SUBJECT
Where do you get your info cobra? It's like you're a BMW engineer or something.
Does BMW call the buyers up on any of these things, or is it something that the consumers have to keep up on? And if so, where do you go?
MODEL
These are the dates when the car rolled off the factory floor, right? I bought my car February 2005, right off the dealer's lot, so I'm safe. Didn't you post another bulletin about cars during this date? It looks like these cars were a 'bad batch'.
SITUATION
I haven't seen that, but I think mine aren't sealed correctly. Every time I wash my car, I see dew forming on the inside. This could rust out the wiring eventually. I should take it to the dealer and have it fixed. I've had so many problems with my 6er, I go in there at least every 3 weeks. Everyone can recognize me and all know my name. At one point, it felt natural to ask for a job application. It's rather embarassing.
Anyways thanks for the update.
Old 11-25-2005, 03:54 PM
GaryRudolph's Avatar
GaryRudolph GaryRudolph is offline
Mein Auto: Z4 35is, X5 50i
I just noticed mine break two days ago! Fantastic, just need to bring it in.
Old 12-01-2005, 06:28 PM
Mein Auto:
On recalls for major items or safety issues BMW should mail owners a notification and they might even call if truly serious. Otherwise at service they might just do a fix. The third method is "upon owner complaint". These choices are included in the Service Bulletin. No, not a BMW engineer, but I played one on TV
You will find your mfr date in the door pillar in same area as tire pressure.
You're welcome
Similar Threads
Brake Light Circuit message Midnhtsun 3 Series & 4 Series 9 10-22-2004 05:01 PM
Dave Zeckhausen Brake pad recommendation please Tom S. 5 Series 19 03-08-2004 06:29 PM
Changing color/pattern of third brake light? Soupcan325i 3 Series & 4 Series 10 12-06-2003 08:09 PM
Brake light warning lamps and switch help gek330i General BMW Questions 7 10-23-2003 09:42 AM
Condensation inside third brake light? Desertnate 3 Series & 4 Series 2 01-07-2003 11:33 AM
