em3: Another idea to lighten the 6er. - Bimmerfest - BMW Forums
Old 01-16-2006, 08:36 PM
SmoothCruise SmoothCruise is offline
Mein Auto: 645 Convertible
This is more a general question, but I figure I'd throw it out to evm3 who is on the quest for the lightest 6er ever.
If the seal on your tires can keep it in, why not fill your tires with helium? It's less than 1/10th the density of air, so the moment of inertia of your tire should be greatly diminished. Plus, helium is relatively cheap.
You could also fill your tire with hydrogen, but that could be dangerous.
Old 01-16-2006, 08:40 PM
Nevervana's Avatar
Nevervana Nevervana is offline
Banned
Mein Auto: Jet Black 650i
Hell, fill it with plutonium.
Old 01-16-2006, 09:23 PM
Malibubimmer Malibubimmer is offline
Officially Welcomed to The 'Fest!
Mein Auto:
The weight saving would be miniscule and helium, consisting of smaller molecules than atmospheric air (primarily oxygen and nitrogen), will leak out and leave the runflats flat.
Old 01-16-2006, 09:28 PM
I bet you it's more than the weight savings on a CF front grill?!? And, plus when you factor in it's rotational inertia, it's probably better than a CF front grill, provided you can seal it.
Old 01-16-2006, 10:06 PM
Mein Auto:
I don't know how much the CF front grille will save, but I suspect the weight savings of helium is no more than a fraction of an ounce per tire. The weight gain necessary to tighten the seals for each tire would probably be more than an ounce per tire. So, I don't think this is a very good idea.
While I haven't done a I suspect someone who was industrious enough could find the infortation about this on the Internet, since I don't think Nevervana is the first to come up with this idea.
Old 01-16-2006, 10:57 PM
lawman800's Avatar
lawman800 lawman800 is offline
Nothing witty here
Mein Auto: here
I think spending an extra 5 minutes on the can before you drive would save you more weight than the helium tires and the CF grill combined.
Lord Irrelevance of the Order of the Roundel - High Protector of the 6erfest
Old 01-17-2006, 12:25 AM
Nevervana's Avatar
Banned
Wasn't my idea. My idea was Plutonium.
Lawman....
Old 01-17-2006, 06:22 AM
devin112 devin112 is offline
Mein Auto: BMW X5
Air is too heavy now? This is news to me.
Old 01-17-2006, 06:31 AM
Just eye-balling it, it seems more effective. I think evm3 would save more weight than swapping his stock grills for CF grills. Here's some estimates.
Assume about 1cm thickness for air pocket in a 20" tire that's 10" wide.
So in cm, the tire is about 50 radius by 25 cm wide. So, the air pocket is roughly
1cm thick * 50Pi in length * 10 in width = 1550 cc.
Now air is about 1.27 mg/cc, so that's 1968.5 mg of air in a tire, at 1 bar, about 2g.
But, the 6er has about 33pounds of pressure, or roughly 2 bars, so it's really about 3.8g of air in a 6er tire. Now, multiply that by 4, and you get about 15g of air in your tire.
Since helium has a density less than 1/10th that of air, he'll have less than 1.5 grams of helium in his tires, saving roughly 14g of weight.
Now, don't forget that in calculating moment of inertia, which is more important than weight when it comes to tires, mass is multiplied by a factor which is a function of the square of the radius. So, take the weight savings and multiply that by at least 50 squared which is 2500.
So just think, if evm3 thought his car would accelerate faster with CF grill. His car should accelerate even more so with helium filled tires.
Old 01-17-2006, 06:38 AM
Ofcourse, what's true for bicycle wheels is also true of car wheels.
http://72.14.203.104/search?q=cache:...ient=firefox-a
Old 01-17-2006, 07:18 AM
BruceWayne's Avatar
BruceWayne BruceWayne is offline
Mein Auto: whatever i want
u guy's.
The 4th of JULY backyard view
The Great Lakes own . straight pimping
Old 01-17-2006, 07:55 AM
lawman800's Avatar
Nothing witty here
Mein Auto: here
Here's another one, how about driving with only 1/2 tank? A full tank weighs too much. Every racer knows at the end of the race, the lower fuel load does increase performance somewhat. The 6 has 18 gallons so save 9 gallons of weight!
Anyone here know how much 1 gallon of gas weighs?
Old 01-17-2006, 08:30 AM
chuck92103's Avatar
chuck92103 chuck92103 is offline
Banned
Mein Auto: 2005 BMW 645Ci
1 gallon of water equals 8.33 lbs.
1 gallon of gasoline equals 5.8 to 6.5 lbs.
1 gallon of ethanol equals 6.59 lbs.
If you are retaining water on race day, I would postpone.
Old 01-17-2006, 08:49 AM
gbelton's Avatar
gbelton gbelton is offline
///M for Motor Sports!
Mein Auto: No More 6 Series
Already being done...
Smooth,
You are a very astute and well read guy. I say this because you not only mathematically described/proved the helium would be better for the driver but in California this is already being tested. I do believe this testing is limited to a certain population but you have hit the nail right on the head when it comes to people thinking about lighter, more efficient ways to run their cars. Burning less gas seems to be there motivation versus what you describe.
In the end, those who race their 6er and need the extra weight reduction I would take everything each poster stated with the exception of Plutonium, and Hydrogen. Kaah-Boom! No thanks!
Good reading anyway and I am sure everyone can appreciate the thought.
Check this out from Google: http://www.parker.com/ead/cm1.asp?cmid=842
GMAN
The Tail of The DRAGON, YES!!
2008 Alpine White, Portland Brown ///M5 (SMG)
2008 Alpine White, Fox Red ///M3 (6MT)
2008 Sapphire Black, Black 750Li
Old 01-17-2006, 05:15 PM
lawman800's Avatar
Nothing witty here
Mein Auto: here
Wow, if 1 gallon of gas is roughly 6 pounds, then 18 pounds is 108 pounds so if you can cut any of that out, like at least 1/2 the capacity, then you can save 54 pounds. You can't save that much weight no matter how long you sit on the can!
Old 01-17-2006, 05:26 PM
BruceWayne's Avatar
Thats the reason I drive on empty all the time.
Old 01-17-2006, 07:13 PM
MysticBlue MysticBlue is offline
They call 'em rigs here
Mein Auto: '09 E92.
You can only make that argument concerning rotational enertia if the material is a solid. The air is not going to begin rotating as a solid as the tire rotates.
You're talking about 1/2 an oz. here.
Some ideas that would make more of a difference:
Get a haircut.
Go commando (no underwear).
Take one floor mat out.
Vacuum the interior.
Run 5 1/2 qts of oil instead of 6.
If you wear over the calf socks, change to ankle socks.
Shorter shoelaces.
Cut those spare buttons off the bottom of your shirt. You don't know how to sew anyway.
Always leave your change in the little change bowl on the counter, never carry any in the car.
Hey, was it your idea to leave out the dipstick to save half a pound and a dollar and a half of material? Genius.
09 E92, IB, DCT.
Old 01-17-2006, 07:18 PM
Mein Auto:
Unless you're 19 year old Lindsay Lohan (who drives a 604 HP SL65).
Old 01-18-2006, 12:39 AM
lawman800's Avatar
Nothing witty here
Mein Auto: here
Lindsay also turned that SL65 into scrap right quick! Sometimes losing too much weight can give you too much acceleration, I guess.
Old 01-18-2006, 02:12 PM
Jp_Austin's Avatar
Jp_Austin Jp_Austin is offline
Mein Auto: '06 650i
If you really want to save some weight, get rid of the stuff you don't need. As suggested, floor mats, trunk liner , battery cover windshield washer fluid, wiper blades and arms. And while you are add it, replace your seat with CF seats. I've got to believe the stock seats themselves weigh around 100lbs ea. Hell, evm3 could have a complete CF seat instead of just the back of it.
Jp
_______________________________________________
'06 650i Conv. Monaco Bl/Cr, SMG/HUD/Sirius/Spt Pkg ED 11/06
Old 01-19-2006, 10:16 AM
Mein Auto: BMW X5
LOL, nice one MysticBlue! lol
That gave me a good laugh.
Old 01-19-2006, 10:19 AM
lawman800's Avatar
Nothing witty here
Mein Auto: here
The CF backing, unless it replaces the assembly, would be just another tack-on accessory that overlays the stock component, thereby adding bulk and weight instead. Some on Fleabay has been selling those backings which just clamp on the stock seats.
I still say spend some quality time on the can. Always worked for me. Although sometimes it turns your morning ride into a mid-brunch ride....
Similar Threads
Borrowing from my 401K, Good or Bad Idea? CD-55 Off-Topic 50 09-16-2014 03:36 PM
V1 Stealth Install idea (Ron et al)... Ben Carufel E36/7 Z3 (1996-2002) 11 12-22-2003 08:32 AM
Stiffer sway bar up front, good idea or bad idea? Andy Motorsports, Racing & Track 47 11-02-2003 04:11 AM
I got a great idea! I call it Euro-delivery! Stevarino European Delivery 21 06-24-2003 07:53 PM
yet another idea for a low cost CAI (it's possibly the best design yet) 31st330i 3 Series & 4 Series 2 04-23-2002 05:29 PM
