E46 (1999 - 2006)
Old 02-20-2006, 04:27 PM
Apollothedog Apollothedog is offline
Mein Auto: 330XI
Need Sirius on new 05 330i
I'm going through Sirius withdrawals and need to get it installed. Dealer wants $700
Yeah that might happen. I saw some threads regarding an install, but I'm not sure if it's relevant to an 05. I have the shark fin thing on the top of the car, I hear that is the satallite attenna,
The dealer wants $275 for the receiver, does anybody know of a discount online source? Is anything else needed?
The dealer says that the head unit needs to be reprogrammed, thus the dealer must do the install. They claim its a two hour job and will cost of $200. Is this true?
Old 02-20-2006, 04:39 PM
Ci2Eye Ci2Eye is offline
Mein Auto: 325Ci
I just did the install myself (today) in an '05 E46 and it was pretty easy. No reprogramming of the head unit was necessary.
I ordered the parts from Circle BMW in New Jersey. You may live close to there and wouldn't have to order by mail.
Receiver was $229.95
Antenna was $ 45.00
Install Kit was $ 45.00
$319.95
Shipping $ 16.60
Total $336.55
The car is pre-wired so you basically just bolt the unit in place, find the wires, and plug it in. Of course you have to install the antenna too but that's not hard either and plug it in also. There are a lot of posts here that will be very helpful if you do it yourself.
'05 E46 325Ci
Old 02-20-2006, 04:45 PM
Mein Auto: 330XI
Do i need the antenna if I have the shark fin? I thought that was the antenna...
Old 02-20-2006, 05:15 PM
Mein Auto: 325Ci
The shark fin contains a telephone antenna and GPS antenna for the BMWAssist and for Nav (if you have it) but it does not have a built-in Sirius antenna on the E46. You'll have to add that as well as the receiver.
'05 E46 325Ci
Old 02-20-2006, 05:25 PM
Mein Auto: 330XI
Beleive it or not, Princeton BMW had told me that the shark fin was also for the satallite on the 05. Where did you put the antenna?
Old 02-20-2006, 06:19 PM
Mein Auto: 325Ci
I believe that's true on the E90.
I put it on the back pacakge shelf. I removed the center child seat anchor, threaded the cable through the hole and ran it under the package shelf to the receiver unit on the left rear of the car. Then I reinstalled the child anchor. I didn't get rid of the anchor as some here have said they did. It can still be used but I used the hole to get the antenna from the trunk to the top side of the package shelf.
So far it's working fine and the car is still inside the garage behind a metal garage door so I think it's going to work fine with the antenna inside the car.
'05 E46 325Ci
Old 02-20-2006, 06:35 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
It's also apparently true on the X3, from what I read a few months back when I was doing research. I did the same install on my '05 just before the holidays last year. Love it!!
I have my Terk antenna on the rear deck. There's a post by KrisL that shows some pics somewhere.
You can look in the bundle of wires back there and see if u have one for satellite. I believe it's got a green plastic connector on it. The phone one is blue? Maybe someone with the phone can confirm that.
The integration with the stock radio/nav is nice. I just did about 9 hours of driving this weekend and loved every minute of it with Sirius. Out in the open I had no drop-outs at all.
Jeff R.
Old 02-20-2006, 06:56 PM
Mein Auto: 325Ci
Jeff,
How'd you install the antenna?
I cut the tail off of the antenna (I used the BMW antenna) and have it snuggly against the back side of the anchor. The pressure from the anchor bolted back in place holds it in back and I put a small piece of velco on the front to keep it from moving.
I think KrisL left the tail on.
'05 E46 325Ci
Old 02-20-2006, 07:08 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
http://www.linquist.net/gallery2/Pri...SiriusAntenna/
Old 02-20-2006, 07:17 PM
Mein Auto: 325Ci
KrisL,
Your posts from earlier were invaluable to me today. Especially when I got to the part where the plug from the antenna wouldn't go through the threaded hole. I thought I knew how I was going to get the antenna to the receiver but it didn't work as I thought. But, your posts help me figure out what to do. I pushed the plug through the hole in the shelf but then routed it beside the thread for the anchor which allowed me to keep the anchor functional.
Here's how it turned out. You'll have to forgive the crummy quality of my cellphone pics.
Name:	Sirius install 1.jpg
ID:	68966   Click image for larger version
Name:	Sirius install 2.jpg
'05 E46 325Ci
Old 02-20-2006, 07:29 PM
Mein Auto: 325Ci
One more.
Name:	Sirius install 3.jpg
'05 E46 325Ci
Old 02-20-2006, 07:31 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
looks good! Glad I could help
Old 02-21-2006, 06:39 AM
romeoz romeoz is offline
Mein Auto: 05 325i
I had the sirius installed for 650 and when I found the antenna was on my trunk I was pissd. I was told it would be in my sharkfin antenna, but come to find out the only way to get sirius intergrated in your sharkfin antenna is to preorder it from BMW when the car is being built, then they can have it mounted in the sharkfin antenna.
Bryan
Old 02-21-2006, 10:44 AM
Mein Auto: 330XI
I was just informed that my 05 330i is not pre-wired for Sirius. therefore the wiring must be run from the trunk to the headunit. Per Circle BMW, this is a 3 hour job at a cost of over $600.
Can this be right?
Old 02-21-2006, 10:49 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Can this be right?
All E46s post-2003 are plug-and-play.
If your car is pre-wired for the cd changer, it's pre-wired for sirius. They use the same wires.
Old 02-21-2006, 11:06 AM
Mein Auto: 330XI
These freaking dealers are so full of crap. They are also swearing that the headunit will need to be re-programmed.
Old 02-21-2006, 11:14 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
What they are telling you is true of the E90.. but not the E46.
Similar Threads
BMW OEM Sirius DIY install: MY 2002 330i ObD Car Navigation, Audio & Electronics by BAVSOUND 310 07-21-2012 05:52 PM
'05 E46 330i with Sirius Radio Option & Factory Cd Changer? EricSteinman E46 (1999 - 2006) 22 09-17-2005 11:17 AM
'05 330i Can 6 disc, Sirius and input be installed Lederman E46 (1999 - 2006) 20 03-12-2005 10:54 AM
Swap '05 330i & 330CiC ZHP aluminum cube trim for myrtle wood. VEGANSAM 3 Series & 4 Series 4 08-24-2004 10:58 AM
No Sirius for '05 330?? Rainydays 3 Series & 4 Series 1 07-27-2004 04:49 PM
