Old 02-01-2006, 03:14 PM
19bwb67 19bwb67 is offline
Mein Auto: 325xi
burned cds won't play
Hi, my 2001 325xi business cd radio will not play burned cds. Does anyone have info on this or a solution? Thanks
Old 02-01-2006, 04:14 PM
Clarke's Avatar
Clarke Clarke is offline
Astigmatic Visionary
Mein Auto: 325Cic-Topaz-Sand
Are you burning them as music CDs and not MP3s? No problems on my 2002 325 or X5 with music but MP3s are a no go.
Don't Forget to Have Fun! 325Cic Topaz,Sand;Sport,Premium. X5 3.0 Topaz,Sand;Sport,Premium,Xenon,Nav,HK,PDC.
Old 02-01-2006, 04:48 PM
walt farr walt farr is offline
Mein Auto: 325IT
burned cds
Look at your cd burning program. Most of them allow you to select 1x,2x,4x etc speed when burning the cd. I have found that going 4x or lower solved my problems, which included not playing at all. So slow down your burning speed and also it may help not to use the cheapest cdr's you can find. The combination of the two should make a difference.
Old 02-01-2006, 05:03 PM
KevinH KevinH is offline
Mein Auto: 2011 335i ZPP, ZSP
I had the same issue and found two very important things:
1. Do not apply a label to the CD. I burned about 20 CDs with beautifully printed labels listing the band, album cover art, and all the songs only to find out that 90% of the CDs wouldn't play. I reburned them all without labels and each one plays fine.
2. The type of blank CD is very important. Memorex CDs play well in my Business CD. Maxell skip horribly.
Unlike most people, I haven't found the burn speed to matter much. Even burning those damn Maxell's at 2x wouldn't make them play.
Finally, check and recheck your burn settings. Make sure you're not burning an MP3 CD or a data CD. Then check if the CD plays in another non-computer CD player (preferably another car stereo). I've heard car stereo's are much more finicky than standard or computer CD players because of the vibration control.
Old 02-01-2006, 07:37 PM
ASenna ASenna is offline
Mein Auto: '06 330ci ZHP & '87 RX-7
There are many factors that can affect burn quality and cd player compatibility.
Check out the cdr equal to bimmerfest > http://www.cdfreaks.com/
Old 02-02-2006, 05:09 AM
u080570 u080570 is offline
Mein Auto: 2004 BMW 330ci
Exact same solution in my 04....slowed down the record speed and Im golden...
Old 02-05-2006, 05:04 PM
Try using high-quality media like Taiyo Yuden CD-Rs.
Old 02-07-2006, 05:40 AM
Passenger Passenger is offline
Mein Auto: E46 325ci
All the above advice is good.
It's also worth mentioning that if a CD player has seen heavy use and is begining to flag a little, the ability to read CD-R will be the first thing to suffer. CD-Rs reflect less light than pre-recorded discs and thus require higher laser intensity to read correctly. If that intensity decreases, the errors will begain to creep in.
Old 02-07-2006, 07:30 PM
little<><'s Avatar
little<>< little<>< is offline
B zzzz ZZZZZZZ zzzz
Mein Auto: X3 F25 N55
I have used Sony's CD-R with no problems, using what ever speed I want to burn them. Some thing about the Sony's makes them work better in this application.
Old 02-21-2006, 03:45 PM
mfstout mfstout is offline
Mein Auto: Miata
Aiff
You may need to burn your CD as an AIFF file, not an mp3 file. Just a thought.
sparky
Old 02-21-2006, 04:02 PM
LDV330i LDV330i is online now
Mein Auto: 2014 335i M-Sport EB
Some CD players will not play CD-R's for no obvious reason while the same CD-R will play in another machine.
The CD-R also needs to be finalized.
Similar Threads
CD player won't play CD's.....after work done on car kaleighsmommy E36 (1991 - 1999) 1 07-17-2005 08:51 PM
2004 530i w/o Nav. How can I play burnt CDs? acribb 5 Series 7 10-27-2004 09:33 AM
Can't play burned CDs??? natotx Car Navigation, Audio & Electronics by BAVSOUND 13 10-15-2004 10:07 PM
How to kill time at work, without getting nailed? Hercules Off-Topic 34 02-24-2004 06:53 AM
Playing Burned CDs in the OEM HK/NAV unit Cy in NC Car Navigation, Audio & Electronics by BAVSOUND 3 01-06-2004 11:59 PM
