BMW News Articles and Announcements
Read the latest BMW headlines and discuss them with your fellow bimmer enthusiasts! |
#1 |
Touch-up Paint Chips
Touch-up Paint ChipsTouch-up Paint Chips with the AutoVisuals AutoSharp Pen With the spint showers washing off the dirt, grit and grim from the winter the damnage to your BMW's paint can be painfully obvious. If not from the winter (perhaps in sunny California) there are away rocks thretening your paint and it is only a matter of time that you are going to be faced with this situation and no one likes the look of an unsightly chip in the paint! Now you are faced with either taking your car to a body shop to fix those chips or taking advantage of the AutoSharp paint pen from AutoVisuals. Last spring we touched up the 330i with the AutoVisuals AutoSharp pen with outstanding results. Unfortunatly for the paint on the 330i we again need to do touch up work and lucky for us we had a fresh AutoSharp pen handy. The AutoSharp pen utilizes a felt tipped applicator to provide you with the easiest possible experience while touching up the paint on your car. If you have ever colored in a coloring book and stayed inside the lines, you can probably do this. In addition to making the product easy to use, AutoVisuals also provides an exhaustive selection of color codes that can match the color on your car perfectly! We set off to work by first reading the directions (well, most of them) on the pen and find all the necessary tools. Step one is obvious for anyone that has ever painted before; make sure the surface is clean! We used some rubbing alcohol on the surfaces to ensure that the area was free from dirt and wax which seemed to work quite well. Before using the pen, AutoVisuals recommends vigorous shaking of the pen to ensure the paint is mixed correctly and an exact match of paint colors is achieved. After shaking the pen for about a minute we grabbed a paper towel and depressed the tip a few times until the tip was soaked completely with paint. We were ready to start fixing up some damaged areas of the car! A quick walk around the car and it was disapointed to see the damange that the winter had caused, with the 330i just over 5 years old we can't say the damange is any worse than it should be, and besides most of the visual damange will be hidden with the AutoSharp Pen. Once you have colored in the dings in your car, you"ll probably want to go back and put on another layer or two of paint in order to "raise" the paint level up to match your car. The directions on the pen advise waiting five minutes but through experience we would advise waiting thirty minutes prior to applying additional coast of paint. We experience some problems when only waiting the five minutes described on the pen but had no problems after waiting 30 minutes. A few days later, we took some time to survey the areas where we had applied the fixes and had to actively look for them from any distance. When looking up close, you can still make out some of the depressions in the paint but this can most likely be fixed through applying additional coasts to the areas in question. Once again, we were very happy with the results from the AutoSharp pen for the $17.99 price tag. If you are looking to touch up your paint without taking a trip to the body shop and are not an absolute perfectionist, you should definitely give the AutoSharp pen a try. The pen is not a perfect solution (especially for those who could never color inside the lines) but it performs as well, if not better, than you would expect. It certainly makes your car look 100% better from a step or two away from your car and unfortunatly I am sure there will be more paint chips, but at least now I have a simple solution! To give the AutoSharp pen a try and save five dollars off the purchase price go to http://www.autovisuals.com/ and place an order using the coupon discount code E46. AutoVisuals (877) 701 - 7780 http://www.autovisuals.com/ info@autovisuals.com ![]() ![]() ![]() |
This article has been viewed 31863 times.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BMWNA: Do you have paint chips (hood, bumper) from driving? If so please READ THIS! | jaisonline | General BMW | 87 | 11-10-2010 07:13 PM |
| Black Sapphire touch up paint | Dr. Phil | Exterior | 1 | 03-08-2005 04:42 AM |
| scratches - touch up paint? | swchang | The Detail Department | 1 | 08-24-2004 08:03 PM |
| Paint Chips way too easy! | CWolfey | 3 Series / 4 Series | 51 | 03-11-2004 07:18 AM |
| Informal Poll: How often do you get rock chips fixed? | CMOS | The Detail Department | 13 | 01-12-2003 11:18 PM |
