E36 (1991 - 1999)
Old 07-30-2006, 12:30 PM
worz worz is offline
Mein Auto: 318is
Strange Alarm problem
Hi all, my first post here
I have a 1997 318is and have just started to have a problem with the alarm.
Last night I was woken up by a high pitched noise outside, which i eventually tracked down to the car(thought it was the house alarm first) I unlocked and relocked it using the key fob and all was quiet. Just to mention this is not the normal alarm siren, just a high pitched scream.
Since then 90% of the time when I unlock the car with the key fob, I get this high pitched noise for approx 30 secs...
So any ideas, thanks in advance
Old 07-30-2006, 02:35 PM
Bmwcat Bmwcat is offline
Retired Slacker
Mein Auto: A car.
Is that a BMW or after-market alarm? Can you do some sort of re-set to it?
"Patriotism is the last refuge of a scoundrel." -Samuel Johnson
Old 07-31-2006, 09:52 AM
Mein Auto: 318is
It is the factory fitted model. As with these things, its all working perfectly again today, I am not sure if that is good or bad.
I wouldnt know how to reset or do anything to it, the manual doesnt help much
Old 07-31-2006, 11:41 AM
oakley's Avatar
oakley oakley is offline
The Dakar Dream
Mein Auto: bmw compact 2000 e36
mine did the same and got worse over time until i had to disconect it...in the end after replacing the siren box, the led and a load of other parts i finally managed to get hold of a new wiring loom containing the white plug that connects to the siren beside the front left head light...after cutting the old connector off and replacing it it all now works perfect so the earth connecter must have been rotten\ rusted ect..sorry i know this is long winded but it took me months of research and a hell of alot of money for what was essentially a cheap and easy prob to solve!! but this is of course a last attempt at sorting it if it continues to get worse!!
Old 07-31-2006, 05:54 PM
Retired Slacker
Mein Auto: A car.
Quick fix?
One quick fix might be to disconnect the car battery for 10 minutes. That re-set my alarm system that was acting squirrely.
Old 08-01-2006, 10:37 AM
Mein Auto: 318is
Thanks both of you for your advice.
Been perfect again for another day now. But if it does get worse at least I have some clues
Similar Threads
strange "new posts" problem EdCT Site Feedback / Questions / Suggestions 0 06-28-2006 09:03 AM
Stellar Alarm Problem CLOTAGAMES E36/7 Z3 (1996-2002) 1 02-10-2006 07:19 PM
Alarm problem -- help!!!! nerak 3 Series & 4 Series 3 09-08-2004 08:52 PM
t Nick T. The Test Board 5 07-05-2003 10:25 AM
