E36 (1991 - 1999)
Old 07-31-2006, 11:39 AM
spiral spiral is offline
Mein Auto: 325is
Steering wheel trembles on highway
I have a 97 318i with auto transmission and 103k mileage. Yesterday I drove it to the highway for 15 miles and noticed the steering wheel trembled sometimes. The speed was around 50-80 mph with AC on. When this trembling got stronger, I could feel the whole car trembling too.. I think the following may be possible reasons:
(1) something wrong with the engin, which is the worst case..
(2) it's normal when you turn on AC which consumes much power.. (should not be this case because I don't have this problem before)
(3) tires should be balanced
(4) something loosened in the drive train which resonates the car at certain speed range.
I'm going to have a long trip with this car so any help would be sincerely appreaciated.
Old 07-31-2006, 11:41 AM
TD TD is offline
Mein Auto: E90 330i 6-spd
Was it worse when braking? My guess (without driving it or seeing it) is worn front control arm bushings.
Old 07-31-2006, 11:51 AM
Mein Auto: 325is
no it remains the same when braking...
Old 07-31-2006, 04:58 PM
Bmwcat Bmwcat is offline
Retired Slacker
Mein Auto: A car.
Sounds like a steering/suspension problem. The A/C shouldnt bother anything. Have it checked out.
"Patriotism is the last refuge of a scoundrel." -Samuel Johnson
Old 08-01-2006, 02:17 PM
318tds 318tds is offline
Mein Auto: 318tds
same problem with my 320i. i have to refill my ATF fluid every now and again to make sure the steering is tight as i think it is leaking. after refilling, the car is more stable. My brother used to have a 518 with the same problem and he had the slave cylinder replaced which sorted the problem. When you are stopped turn the steering wheel and if a grinding or rubbing noise is heard, you should check your ATF fluid as it may be low/leaking or both. Check the ATF fluid level anyway as this provides the lube for the powersteering.
Old 08-01-2006, 04:33 PM
MN325iSedan MN325iSedan is offline
Send a message via AIM to MN325iSedan
Mein Auto: '93 325i
I would suggest to start out with trying the easy stuff, i.e. tires balanced, check for steering fluid leaks etc, then if it persists you can eliminate those from the list.
Calypso Red '93 325i
Old 08-01-2006, 07:10 PM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 93 325 and 91 K2500
Usually this means your ball joints, tie rods are bad, could have a bent wheel, out of balanced, tires. jack your car up and see if you can wiggle the front tire up and down or side to side.
Hope this helps. If you need any parts just let me know
Old 08-02-2006, 05:26 AM
savage217 savage217 is offline
Mein Auto: 1995 m3 w/ dinan upgrades
Yes, this happened to me, it feels like the steering wheel is going to rip out of your hand? I replaced my ball joints and it took care of it. I would suggest changing the lower arm and get both ball joints (inner and outer). You may want to do the rear as well but at least make sure you do both sides in the front. That should fix your problem
Similar Threads
Need help with tire/handling problem pmcwhinnie E39 (1997 - 2003) 5 12-22-2006 12:46 PM
Option code list Terry Kennedy General BMW 16 05-14-2006 03:59 PM
M3 Steering Wheel Review: One Week After (long) james330x 3 Series / 4 Series 3 04-24-2003 11:47 AM
Perfect steering at last (long) PG 3 Series / 4 Series 25 05-15-2002 12:01 PM
Non-Leather Steering Wheel Suggestions? JonW 3 Series / 4 Series 4 04-16-2002 07:20 AM
