5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
Radiator Nipple
Hi,
I read with interest the details on installing a new radiator nipple since my 523 has developed a leak in the same area and needs replacement. Unfortunately the BMW agents in New Zealand where I live have no reference to the part required P/N 99-00-0-003-352. Can anyone identify where I may purcase the part. Thankyou Warren |
That is the part number and I think they are available from any US dealer. You could try e-mailing one and see if they will ship to you. The part is only about $1 US.
Thankyou for your assistance, I have emailed an agent in California and I will see how get on. |
Check your PM and let me know...
I've always heard that E39's had sensitive nipples
I have no response from the agent I emailed, is it at all possible that you help me further, I will glady reimburse you as required. Thanks Warren |
So if anyone can help then very much appreciated... Thanks Warren |
Warren,
It's on the way! -Mark |
Warren, got the stuff in the mail! Thanks!
I found that part on OEM-BMW-parts.com but it stated that the part is for Mercedes. Are you sure that is the right part for an E39 BMW (1997 528i)?
Aaron |
I am sure it's the right part for the V8, 740 and 540. It's not a Mercedes part, but it's also not in the parts data base. You might try calling a dealer to verify it works for the I6 engine.
(Edit) Here it is... Link: Pelican Parts Repair Nipple for Vent Hose Fitting on Radiator, E39 528i/Wagon, 525i/Wagon, 530i, 540i/Wagon, M5 Brand: Genuine BMW 99-00-0-003-352
M.Wong E38 2000 740iL Orient Blue E91 2012 328xiT Alpine White Passed on to new families: E30 1987 325i Royal Blue E39 2003 540i/6 Sterling Gray R56 2010 Mini Cooper S British Racing Green
Thanks Mark. I just ordered the part. I posted on the other thread too. Any advice on method of removal? Does it just pop out? I'd hate to crack the rest of that plasitc radiator manifold. The other gentleman was suggesting replacing the whole radiator cause of its age. It's just hard for me to do that when the only thing leaking is that poorly designed plastic elbow!
Thanks for your input, Aaron |
Sorry, I have never replaced mine... the whole radiator was done under CPO for me on the E38, and the E39 still has the original.
Finally changed out that nipple. The original snapped in half right at the edge of the groove for the o-ring. If you ask me, it is a very poor design to construct an elbow where it gets so hot and it's connected to a hose which can create tension and torque the elbow causing it snap. In addition the groove for the o-ring molded in has sharp corners rather than a rounded groove, weaking the part.
But all in all it didn't go too bad. The only bad thing was when trying to remove the broken piece that was stuck in the radiator, I accidentally pushed it into the radiator (the black side tank/manifold). Damn! I had to take the radiator out to turn it upside down and dump the little piece out through the coolant inlet. That was not an easy task since it is so tight in there. The automatic transmission cooling lines should probably be disconnected to make it easier to remove the raidiator, but I didn't know the best way to remove those lines without damaging them. |
If you have aluminum fittings on your radiator and steel on the lines they will probably strip if you take them off(ask me how I know).
A claw type pickup tool is also a good thing to have around. http://www.sjdiscounttools.com/vimfc24.html
How to take out the nipple
I recently replaced my radiator with a Behr OEM unit. It was immediately leaking from this nipple. (In fact, I thought it might be some sort of pressure relief valve) It turned out that the nipple had a crushed and torn rubber washer.
You will note that the nipple has a tri-pronged end that gets pushed into the radiator. It clips into place. In order to take out the "old" one, I put a 10mm socket into the upper radiator hose opening, and pushed it on to the "clipped" end to push it closed enough so that I could pry out the old one. I TIED A STRING TO THE SOCKET SO THAT IF I DROPPED THE SOCKET, IT WOULDN'T END UP AT THE BOTTOM OF THE RADIATOR. This worked flawlessly. |
what about the lower nipple?
on the drivers side what about the lower nipple (the one that attaches to the hose that feeds the heat exchange unit on an automatic), elbow joint, I have a leak from there, is that removable? replaceable? anyone know? Help!
Thanks! |
- WANTED: An ingenious method of removing radiator nipple I don't understand this method of using the 10mm socket. Can someone who does understand it elaborate for us in the thread listed above? |
I think I figured out the 10mm/9mm socket trick to remove the radiator nipple intact.
From my experiments today, it will be easy to use this trick (9mm worked best for me) to remove a BROKEN radiator nipple, with the broken half being removed intact (so that you don't have to worry about it floating around your cooling system passageways). It's less obvious how to successfully use this trick to remove the ENTIRE nipple, intact. But let's have the next person try it and let us know! - WANTED: An ingenious method of removing radiator nipple |
