Z3 HVAC bulb replacement
The following pics show where I'm at.
Will order the back plate for clearer pics. Have the front piece to show how it comes apart. The bulbs are part of the bulb socket. More to come.
I just replaced both those in the black car last month.
Able to access them through the radio opening (less trouble than removing the console, but still a pain).
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Bulb Replacement Help
The left side of my heat/ac control panel light is out. I pulled the radio and using a mirror found one bulb E 106 (its sort of in the middle) I think I see E105 way down under the flap control but how do I get e105 out? I guess they twist out but I can barely touch the bottom one. No one said working inside consoles was easy but this has me stopped. HELP
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
Re: Bulb Replacement Help
Same one went out in my 99! You're halfway there... Pull the knobs off the HVAC control and then push on all three (3) stems evenly to "pop" the control loose from the console. Keep one hand behind the control to catch it when the clips disengage from the console. Now you can get the whole control up to the radio opening to remove that stubborn bulb/holder. When I put mine back together, the hardest part (but not insurmountable) was getting all the HVAC control mounting tabs lined up; TIP- start with the tabs at the bottom first and insert them all evenly. Make sure the bulbs (you are changing them both, right?) illuminate before putting the knobs back on. Let me know if I can be of more help...
Bulbs
Thanks, I guess I should stop training this mouse to use its paws. I haven't made much progress. It just keeps finding cheeze doodle crumbs under the seat from my trip to homecomming.
Received the backplate today. Comes with lamps and the blower switch.
Lamps are sure tight in place. Had to use long nose to get them out. Not sure how you would do this with it in the dash.
Changing the H/ACBulbs
I'm quick at this one now. Thanks Ron and Randy.
Loosen two radio screws, pull out radio, pop off radio connector, off with antenna, out comes radio, flip two clips on heat/ac panel (I don't have any screws), flip panel, grab bulbs with needle nose (they are tight) in goes new bulbs, done!
My 99 didn't have screws either.
Not sure about the 01, but I'll let you know in a couple of years...
Ron, now you can fix our heater control!
Just invent a different shaped arm coming off the heater control that would somehow, miraculously result in an even transition from cold to hot!
2006 Z4 M Roadster 2005 X5 Kid Truckster 1991 318is e30 Play Car |
Re: Ron, now you can fix our heater control!
http://bimmerfest.com/forums/showthr...threadid=17020 |
Someone had fun designing that nautilus shape track.
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
this is one of the most helpful threads i have read. great job!
My left bulb is out too?
I think it's gonna stay out a while longer too... interior stuff just puts me up the wall. I'd drop the bulb in there and it would, oh, I can't even think about it...
Z3 MZ3 Diff Mount and Subframe Tears |
. at least i didn't have to pull the console again.definitely change both bulbs while you're in there....
Nick aka mng |
Great reference for HVAC bulb replacement.
Yeah - this a great reference thread - those pic's of the back of the HVAC are invaluable when you go to change the bulbs for the first time - which I did a couple of weeks back (had been doing some console work and had it completely out, got it all back together (sans stereo) to find the back bulb had now gone out, so using this thread I was able to pull the back bulb by feel through the stereo aperture and replace it - although it was very hard to get enough leverage on to it).
Thanks Ron. |
So, I had this thread printed out as I went out to the Roady this evening to check the bulbs. The ones on the passenger side are giving me issues: fan control light out (seemingly permanently) and oil temp light comes on with a frim "jiggle" from the heal of my palm a couple of times. Everything was going great until I tried to disconnect the head unit connector. I pulled the little guard thingy up, but it didn't want to come all the way up, judging by the channels on the side. Couldn't easily detach the cable connections with it like that, either. What am I doing wrong? With the head unit hanging out of the opening buy the taught loom, I was unable to do much at all, other than verify the fan control light was in fact connected, but the bulb seemingly burned out.
Other than that issue, this thread has been invaluable, prompting me to attempt something I normally wouldn't want to, for fear of screwing up something minor that costs money to repair.
![]() #232
My head units have been in/out so many times that I've forgotten if there was any trick to relieving pressure the first few times. Maybe someone that's only done it once or twice can offer up a trick. Mine comes off pretty easily these days.
Daniel 2002 M roadster |
here maybe this will help get a idea how it works
http://www.bimmerfest.com/forums/att...chmentid=46024 as the latch is raised it kinda pulls itself away from the radio, then it should just come straight off the back, as you put it back on as you slide the latch back down it pulls the connector back tight against the radio Last edited by 01silber; 09-30-2005 at 08:58 PM. |
Yeah, that makes sense. I was pulling on it up to my comfort level of fitting integrity (didn't want to break a potentially non-replacable part) but perhaps I should finesse it some more. It did seem that pulling it more would do just that, since the channels are angled to facilitate an automated connector removal, as you guys indicate.
Oh, and thanks for the feedback!
![]() #232
No prob. see here http://www.bimmerfest.com/forums/sho...adio+connector
read post number 2 but not number 3
Ah, good info. Sorry Max, I can't count well and read right through to post #3!
![]() #232
moving the temp. control opens the blend door to allow heat from the heater core into the ducting, hot air will always over take cold air
