540 died, won't start, engine and trans failsafe..Any Ideas?
Well this morning I turned on the 540, put it in reverse, went about a foot and car died. I am now getting Engine failsafe prog and Trans failsafe prog and the temp gauge moves into the red after a few seconds. Everything seems to be working but car will not crank or do anything, as if the starter was removed. I have ran diagnostics and here is the following codes that came back for IKE:
246 Data connection to drive and running-gear-control modules (CAN Bus) 247 Data connection to drive and running-gear-control modules (CAN Bus) 248 Data connection to drive and running-gear-control modules (CAN Bus) 251 Data connection to drive and running-gear-control modules (CAN Bus) Anyone ever had this happen before? I did a search and found only one person that had a faulty MAF, but their situation was a little different. I am trying to save a little bit of $$ by fixing it on the spot and not having it towed. Also, diagnostic is unable to communicate with DME. Any ideas would be helpful.
Oscar Dallas, TX 01 540i Sport 06 330i Sport 01 530i Sport 01 540i Sport 6spd
damn oscar that doesnt sound good. why dont you ask your bro? hed probably kno more then anyone on the site.......cmon now. on the other end i finally got my **** running right. 17mpg in the city ftmfw!!!!! |
Somwhere in the back of my mind - a fuse for the DME...? Let me do some digging and see if I can find it. This is vaguely familiar...
Similar problem, another board, last post in the thread:
UPDATE: Finally took it into the dealer. It was Fuse #1 (in with the DME). Replaced and all is well. Don't know if this will help you, but it might be worth looking in to. |
The avarage towing price is $150 which I could save and use towards parts if someone has had this problem before. Good to hear you got things working. I will have the diagnostic computer with me this weekend if you need to use it or clear out any faults. Let me know.
Thanks, keep it comming guys.
or do what my dad did. tie a chain to the car and drag it behind you in nuetral.
you need help i can stop by haha. i was thinking of jacking the car up both sides and sliding the U haul thing in. man oscar your slacking today.
Aaa ?
'91 SpecE30 #523 '03 540i/6 M-Sport '00 Ford F-350 Dually Tow Vehicle BMWCCA #360858 NASA # 128290 My Track Schedule |
AAA $123 to tow 100 miles is cheaper but I was looking more at under $100.
Well talking to my brother is looks like I might have a bad thermostat. I will need to disconnect the thermostat, check to see which DME fuse needs to be replaced and then run diagnostics again to see if I can communicate with DME or EGS. If I can communicate with DME then plug the thermostat back in and see if it pops the fuse. Re-run diagnostics again and realign DME before the car will start. I will keep you guys posted.
Have you ever changed the coolant temp sensor? Did you smell a burning smell? If so refer to this post.....
http://www.bimmerfest.com/forums/sho...d.php?t=164268 |
Got the car started this morning. Busted fuse where the DME and EGS are located under the passenger side air filter. I replaced the fuse and then the car started, car drove great, but under closer inspection looks like the thermostat is going bad (which could be why the fuse blew). Parts was closed, so Tuesday is the soonest I can get a new thermostat. I took some pics and will post soon.
![]() 1999 540i Cosmos Black Metallic. Pdc / Dsp / Sunshades / Heated seats / Navi / Hella Celis Tails / Xenons Austin |
Alright, count me in, were is the post?
no i ment you start a thread.......haha......nobodys gonna come if i host a meet. cmon on
seriously though we need to have a meet, specifically an E39 meet because i kno theres at least 7 of us in the dfw area that would show that have E39's
I had the same thing happen
My car is at the dealer right now for this same problem.
The car wouldnt start. The dealer told me that I had to replace the Fuel Pump and Filter. Then he came back and said I need to change the DME Main Computer System as well as the Thermostat and Wire Harness. Im new to car formus and have owned my '01 540I for a year. Couple of questions: Did you replace the DME? Where was the fuse for the DME? In the glovebox? Did you replace the Thermostat? Does anyone know a BMW repairman they trust in or arounf Atlanta? Where can i read up about my 2001 540I? Where can i get a manual (like the Hayes Manuals) to do repairs? Thanks in advance for pointing me into the right direction -David |
maybe im in another ball park...but when i got my 528...the battery was dead...so i jump started it and it was in fail safe mode and everything......put a new battery in it.....still going now without the fail safe and what not
The fuse is located under the passenger side cabin airfilter under the hood. It's a small grey box with 6 fuses located right next to the DME Computer. You have to slide the top off the grey box to get to the fuses and then replace the broken fuse. Yes, I did replace the thermostat. I did not have to replace the wiring harnes though, but from what my brother has told me is that sometimes coolant gets pushed up the wiring harness due to a bad seal on the theromstat. Sorry, don't know any Atlanta Email me your cell phone number and we can talk to see if you have the same issue. Oscar.Martinez@wnco.com
I took some pictures, I will post them soon to show where the fuse is.
#25
Thanks. Im replacing the battery, since the dealer said mine was leaking.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trans Program car won't start | eshwars | E34 (1989 - 1995) | 8 | 11-15-2011 06:18 PM |
| What is a '02 540 50K mile engine and trans worth? | Reload | E39 (1997 - 2003) | 7 | 10-29-2006 06:25 PM |
| engine (or trans) rattling when turn off while shift in neutral | mikeeeee | New Member Introductions | 1 | 08-29-2006 08:19 AM |
| CONVERTING 1995 525i ENGINE + TRANS | bimmerider2004 | E34 (1989 - 1995) | 0 | 06-10-2005 11:30 PM |
| Trans. failsafe | CFMBENSON | E39 (1997 - 2003) | 3 | 05-06-2005 09:24 AM |
