E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Oilpan Leak! Help
Hey,
The previous owner of my 325i stripped the threads off the oil pan bolt and replaced it with aftermarket parts... was wondering if anyone knows if there is a way to fix it... it constantly drips oil and i cant tighten it anymore... if not any suggestions on where to find a new oilpan that i dont have to pay full price for? Thanks |
Either that or gasket maker, which is very similar but made for engine conditions. As soon as you get a chance, you should take the pan off and re-tap it for a new plug and nip the problem in the bud.
Ahem......
Helicoil anyone?
I'm sure that one IS available.Check google for helicoil manufacturers. Consult a machine shop to find out the pitch of those theads and the threads per millimeter. Check check...roger dodger,, 10-4 Rubber duck...
325ic a beer ![]() "Swimming with the sharks" All over this World...I'll see you in the next one.,,yeahhhh.... AND DON"T BE LATE,,,, DON"T BE LAAATTEE! |
Didn't Work
It looks like the threads are shot and the idiot that owned the car before me put a counter-pressure rod attached to the bolt so that the bolt doesnt even come all the way out.. looks like i bent the rod trying to get it out... gona have to get a whole new pan... any ideas where to find?
junkyard YAY
haha
- How to fix broken or stripped oil drain pan plug bolt threads (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) |
i've seen a rubber plug used with no leakage. also a rubber expanding plug. try a hardware store... ace, true value, etc.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bardahl no-smoke stop leak. | EricG | E36 (1991 - 1999) | 3 | 12-07-2006 03:46 AM |
| Oil Filter Canister Leak? Pictures | M3XTC | E36 (1991 - 1999) | 6 | 09-28-2006 02:00 PM |
| A wierd fuel leak | hishamrazzak | E39 (1997 - 2003) | 5 | 01-20-2006 07:10 PM |
| Bad oil leak | dubumb | 5 Series | 9 | 09-30-2005 08:41 AM |
