Old 01-16-2007, 09:00 PM
denaliman denaliman is offline
Mein Auto: 2013 X6M
Question 2007 X5 winter wheels
I am waiting for my new ride to arrive. My neighbor is selling his X5 and asked me if I wanted his winter wheels. They are from a '02 X5 4.4 with 48mm offset factory original BMW wheels( style 74 I believe). The 2007 X5's are 46mm offset. Will they fit? would there be any issues? Would I need spacers? I Ordered 4.8i with sport package, dynamic package and 20" wheels.
Old 01-16-2007, 10:24 PM
gbelton's Avatar
gbelton gbelton is offline
///M for Motor Sports!
Mein Auto: No More 6 Series
Do Not Do It!
The size and weight of your pending '07 X5 is different in many aspects of the '02 X5.
Buy it and you will be sorry.
The Tail of The DRAGON, YES!!
2008 Alpine White, Portland Brown ///M5 (SMG)
2008 Alpine White, Fox Red ///M3 (6MT)
2008 Sapphire Black, Black 750Li
Old 01-17-2007, 05:36 AM
Mein Auto: 2013 X6M
Are you saying these wheels will not fit? or will hamper the peformance? I am buying the winter wheels not the whole '02 X5.
Old 01-17-2007, 08:32 AM
sapaman sapaman is offline
Mein Auto: X5, M5
I am in the same situation as you, I have a 4.8i with the 20" sport package on order. Even though the offsets are close, I would be worried that the older Style 74 wheel would not clear the larger brakes of the new X5 (E70). For what its worth, I spoke to someone at Tirerack about winter wheel options for the car, and they indicated the options are very limited because of brake clearance. This is not the case for the older X5 (E53).
2007 X5 4.8i (Performance Center Delivery, Feb 2007)
Monaco Blue/Tobacco/Bamboo, Sport w/ 20" wheels, Running Boards, Premium, Technology, Cold Weather, Heated Rear Seats, Premium Sound, Comfort Seats, Comfort Access, Sirius
2008 M5 SMG (Feb 2008)
Space Gray/Black, Comfort Access, Premium Sound, HUD, Heated Rear Seats, Heated Steering Wheel, Multi-Function Seats, Power rear sunshade, Ipod and USB Adapter, Sirius
Old 01-17-2007, 08:37 AM
gbelton's Avatar
L O L
There is a strong possibility that the clearance maybe too close (mm). It will matter especially in the long run.
Performance, driveability, and stability would be affected based on the current setup which the '02 X5 does not support. You know th old saying, "Upward compatibility, NO."
Silly denaliman, I know you are not buying the whole SAV for just the wheels...
Old 01-17-2007, 10:05 AM
Mein Auto: 2013 X6M
The rims I am considering are BMW Factory 18" X 8.5" 48mm offset Style 74 with 255/55/18. This is the same size rim and tire size that is standard on the 2007 4.8i. The brake disc size is 345mm rear and 348mm front on the new E70. The older X5(e53) disc size is 324mm rear and 332mm front. This difference is big. However, they both have the same standard rim and tire size. (The sport package on the E70 adds 19" x 9"wheels with 255/50/19 tires). So if the standard wheel sizes are the same should they not be interchangable? The only difference I can see is the +2mm offset difference. I do not see any reference anywhere where if the truck is equipped with the 20" rim option or sport package they will have a different brake disc diameter than what is standard.
Old 01-17-2007, 01:34 PM
Mein Auto: X5, M5
I believe the E53 4.8is came with larger rotors (355mm?). One way to get some comfort that the Style 74 wheel will clear the E70 4.8i is to find out if any 4.8is owners have used this wheel. If these wheels clear the E53 4.8is rotors, I would think the E70 4.8i should be no problem. I agree there is no information to indicate the E70 4.8i with sport package has larger rotors than the non-sport.
Old 01-17-2007, 02:51 PM
Mein Auto: X5, M5
I found the attached brochure for the E53 4.8is. It looks like the Style 74 wheel was in fact an accessory for this model, and therefore these wheels must clear the larger 4.8is brake rotor. Based on this, you should be fine with the E70 4.8i.
Old 01-24-2007, 09:41 PM
Mein Auto: 2013 X6M
I had the dealer try a set of BMW style 74 wheels on the e70. They did not fit. The hub bore size is different. The e53 X5's have a bore size of 72.56 and the new e70 is 74.1mm. So now where do I find a wheel that will fit that is not a BMW factory wheel? The truck is so new none of the replica dealers I spoke with had anything in that fitment.
Old 01-25-2007, 05:14 AM
pseto's Avatar
pseto pseto is offline
Mein Auto: e92 M3 ZCP, M Roadster
its too new that you won't find much other than what BMW has right now. you can try Tirerack for something aftermarket, plus you can get a tire/wheel package that'll come delivered already mounted/balanced.
Old 01-26-2007, 10:19 PM
neill neill is offline
Mein Auto: an old Camaro
BMW Canada has released E70 specific winter set with RFT's.....
Old 01-27-2007, 06:02 AM
Mein Auto: 2013 X6M
Hi neill,
Yes they are $3,900.00 here in Ontario! Any cheaper where you are?
Old 02-05-2007, 03:17 PM
swb3's Avatar
swb3 swb3 is offline
SWB3
Mein Auto: 2014 i8 and some others
I don't know if this interests you but I also have the sport package and wanted to maintain the Y-spoke wheel look for winter. I ordered 4-front y-spoke rims and had Pirelli scorpion ice and snows shipped to the dealer from the Tirerack. They fit and work great. It cost $2,100 for the four rims, $1,100 for the tires, plus mount and balance. The photo is with my winter wheels and tires. (All US $)
2014 i8
Old 02-05-2007, 03:20 PM
swb3's Avatar
SWB3
Here is the pic, it did not attach the first time.
Name:	bmw X5 side.jpg
2014 i8
Old 02-06-2007, 06:07 PM
2thdr 2thdr is offline
Mein Auto: 01 540i/6
Swb3...
...can you tell me which dealership you bought your style 214 rims from? That price is amazing, as I was quoted $4000 CDN for the same rims by my stealer.
Even converted, your rims amount to $2500 CDN, which is amazing.
Old 02-06-2007, 07:18 PM
swb3's Avatar
SWB3
I just sent you a PM with the name and numbers.
2014 i8
Old 02-07-2007, 12:12 PM
Swb3...
...message didn't arrive, but thanks for the quick reply!
Old 02-12-2007, 03:06 PM
dixhead dixhead is offline
Mein Auto: 2007 X5 3.0si(soon)
Will the type 214 wheels fit a 2007 3.0si??? I love the looks of that wheel, and would likely use the factory rims as winter wheels (non-sport model, w/18" wheels).
Old 02-12-2007, 05:07 PM
Mein Auto: 2013 X6M
You might have to put on the wider wheel flares to protect the body from road debris.
Old 02-12-2007, 06:42 PM
swb3's Avatar
SWB3
Here are three pictures that might help you make the decision. These are BMW promo pictures of a 4.8 with the sport package and Y-spoke wheel (214).
The front looks like it would be ok with the standard flares. The back may be iffy, but I guess you could always install the wider flares later.
For winter I installed the front all around and they are inset more in the rear than with the standard rear rim as these pictures show.
Hope it helps.
ID:	98157   Click image for larger version
ID:	98158   Click image for larger version
2014 i8
Old 02-13-2007, 01:48 AM
drjeff drjeff is offline
Mein Auto: 2013 650i GC
So the 214 from the 4.8 will fit a 3.0 with sport package? I just ordered one with sport package and the dealer said the factor doesn't allow me ordering the 20' 214 wheels. Any idea where I can buy them from (give that they'll fit)?
Old 02-13-2007, 12:30 PM
swb3's Avatar
SWB3
I don't know if it will fit the 3.0, however I seriously doubt it would not fit. I ordered four front rims to use with winter tires. The parts fellow at first tried to discourage me, but as we talked it through he was in agreement the fronts could be installed on the back. As it turned out they fit fine and the vehicle handles great.
Philosophically speaking....Look at all the wierd and outlandishly sized rim combinations people are installing on cars and trucks of all makes. Why on earth would these rims not fit and perform fine on the BMW X5 with a 3.0? My guess is to sell more 4.8's and increase the margin for BMW. It's your money but I think its a safe bet to order the rims.
2014 i8
Similar Threads
**SEVAS WHEELS - NEW 2007 FINISHES, AVAILIBILITY, Place Your Order Today!** D2-AUTOSPORT Site Sponsors & Bimmerfest Group Buys 3 01-24-2007 12:03 AM
Comparison X5 4.8 and ML63 jus4ac X5 E53 (1999 - 2006) 3 01-14-2007 12:52 AM
FS/WTT (NJ) 4 Dun Winter Sp M3 snow tires with Miglia Wheels loaf Wheels and Tires 3 11-25-2006 09:46 AM
2005 leftover vs 2006 X3 duvbear X3 E83 (2004 - 2010) 45 07-12-2005 12:11 AM
Pics of 2007 X5 chefwong X5 E70 (2007 - 2013) 4 01-11-2005 11:39 AM
