How do you remove Trunk Liner?
I am interested in having a look at the stock amps in the trunk, and wanted to know where they are and how I get access to them if the are under the gray liners along the wheel wells.
Also do you have any idea of how I remove the cover between the hoops that covers the sub woofer? I got the front to pins out, but the back seems not to be pinned. I can't budge it and do not want to force it. Thanks!
Than '07 328Xi / '91 325ix / '01 330i / '93 325is / '93 Spec E36 Racer |
The subwoofer cover is just "snapped" into place.
Pull up the front, and when you have those pins free it's time to do the back. Carefully lift uo on one side at a time while keeping the cover in a flat plane (as from front to back). The trunk liner is held in by those plastic discs. They just pop out. Our cars have two (2) amps. One on each side wheelwell.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Any idea how to get to the amps?
How do I remove the wheel well covers Randy?
Re: Any idea how to get to the amps?
patlam i cannot remember which one comes off first as i took mine off a LONG time ago. if you are still having trouble. i can go downstairs. and take a look. good luck. |
