Old 04-01-2007, 08:22 PM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
Originally Posted by zerock View Post
this is kinda related, from time to time, i would just get no sound, and would try everything, and the only way to fix, would be to reset by removing the cd changer fuse.. so after a while, it got annoying, and removed the adapter for the time being.
Just replied to your post on the other thread, keep me posted on your results.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr | Twitter
Old 04-02-2007, 05:16 AM
x3pig x3pig is offline
Mein Auto: 2007 X3 3.0si
On a related note: I had my DICE iPod kit installed for a few months now. So far my experience is somewhat mixed. On one hand, the kit, when it works allows pretty good control of the iPod, although, I find that the radio text feature is moderately useful given the delay in displaying the text.
The low point of the solution for me is that from time to time (seems to be random but more or less related to not driving the car for a day or more) the iPod or DICE resets and starts playing iPod songs from the begining of song list. This means that the ALBUM switching mode on iPod does not work properly (moves a few songs seamingly at random). I have to manually take the iPod from the glove box and set it to play ALL albums.
Anyone has experienced anything similar? Or is it just my iPod / DICE?
Old 04-02-2007, 05:26 PM
tom @ eas's Avatar
Mein Auto: BMW
Replied in DICE Q/A thread: http://www.bimmerfest.com/forums/sho...65#post2278665
Old 04-03-2007, 06:51 AM
Thanks Tom - much appreciated. Replied to your question in the other thread as well.
Old 04-03-2007, 05:53 PM
zerock zerock is offline
Mein Auto: 2006 X3
well so far it hasnt happened again, but it was indeed odd. i would get no sound or control, and and the same text showing.. its like it was stuck..
Old 09-09-2007, 05:20 PM
X307AMB X307AMB is offline
Mein Auto: X3
Let's troubleshoot by plugging the DICE into the 3/6-pin connectors in the cargo area, then switch the 12-pin connector on the radio if no sound is heard. If there is no change - the module may be defective.
Tom,
I have been communicating with you to get my ice>link Plus to work on my 2007 X3 with NAV.
I get the songs listing but no sound.
The 6-pin connectors pins (BMW & ice>link) used dont match:
BMW ice>link
Pin 1- while/blue Red (Audio Signal)
Pin 2-while/brown
Pin 7-white/red White (Audio Signal)
Pin 8- Black (Shield)
It would helpful if you can provide the pins functions which pins should be connected.
Old 09-09-2007, 06:33 PM
tom @ eas's Avatar
Mein Auto: BMW
Originally Posted by X307AMB View Post
Tom,
BMW ice>link
Pin 2-while/brown
There is no reason to extract the pins as they are keyed to go only one way. This was explained in the email also.
IF you are not getting audio, check to see if you are connected to the correct 6-pin adapter in the center console area, or you may need to swap the white 12-pin connector behind the radio. If you continue to have problems, it is recommend you upgrade to the DICE as the ice>Links are very problematic.
Old 09-11-2007, 10:21 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Send a message via Yahoo to kjboyd
Mein Auto: 2009 MINI Cooper Clubman
Tel Send End
so, i'm having the same no sound issue, when I use the trunk or the center counsel... but DO get track names. Now, when I use the other white connector, I get sound, but I also get TEL and SEND/END on the radion, rather the CDC.. is that what is supposed to happen?
Because, I noticed it completely screwed with my bluetooth integration. and phone contacts would not match their phone numbers.
I swapped the white cd-sars connector tonight on the radio (and dropped a screw behind it all ... it figures) but still no sound. just a clicking noise.
HELP! please.
kev
Kevin
2009 MINI Cooper Clubman - "Oxley"
Nightfire Red/NFR, Tuscan Leather, CP, PP, CW, Roof Rails & Aero Kit, 16" Bridge Spokes, Xenon, Auto, English Oak Trim & Wood Wheel, Alarm, Hi-Fi
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 09-12-2007, 09:59 PM
tom @ eas's Avatar
Mein Auto: BMW
HELP! please.
kev
Some MY07s have the TEL/SND appear when the DICE in in operation, however we have not had a local X3 with the issue to determine the problem. Are you located in the Southern California area so we can investigate further?
Old 09-13-2007, 05:33 AM
kjboyd's Avatar
Hi Tom: nope, Sacramento. I appreciate the offer though. i've also noticed the track name does NOT go away when i turn off the car... much like the BT wont turn off the phone if you turn off the car in the middle of a conversation. it's like it's still playing, but no sound comes through, and only part of the track name shows, like it's cut in half or something.
thanks
kevin
Kevin
2007 Volvo S60 2.5T
Old 09-13-2007, 06:26 AM
XJSChris XJSChris is offline
Mein Auto: Car
It goes away.. Just takes a couple of minutes..
Old 09-13-2007, 06:46 AM
kjboyd's Avatar
thanks Chris...
does the iPod ever turn itself off or just keeps running?
that must drain the battery!
Kevin
2007 Volvo S60 2.5T
Old 09-13-2007, 07:00 AM
Mein Auto: Car
thanks Chris...
the iPod and the radio display do turn off after a couple of minutes.
Old 03-02-2011, 12:20 AM
gio1004 gio1004 is offline
Mein Auto: 2010 X3
Was anyone able to resolve the issue? It is now March 2011, and we are still having the exact same issue as 4-5 years ago!
Old 04-02-2011, 07:47 PM
00Bob 00Bob is offline
Mein Auto: 2007 X3
Same thing here. Looking to resolve this problem.
Thanks!
Old 04-03-2011, 01:56 PM
cesart13 cesart13 is offline
Mein Auto: 1997 528i
BMW no sound troubleshooting
I had the same problem. My friend tightened the fuses seat in the trunk and in the glove compartment. Specially the ones in the trunk open wide and although the fuse lights OK is not enough for the radio or Power Amp to work. Spray some contact cleaner and pry tight the metals in the fuse housing. Good luck!
Old 04-03-2011, 01:57 PM
I had the same problem. My friend tightened the fuses seat in the trunk and in the glove compartment. Specially the ones in the trunk open wide and although the fuse lights OK is not enough for the radio to work. Spray some contact cleaner and pry tight the metals in the fuse housing. Good luck!
Old 04-12-2011, 06:03 AM
akoda akoda is offline
Mein Auto: x3 2007 CPO
any one have a fix ......i have the same issues no sound but everything else works x3 2010
Old 04-12-2011, 11:38 AM
tom @ eas's Avatar
Mein Auto: BMW
I would recommend contacting DICE to speak directly with a technician on your issue.
DICE can be contacted at 888.342.3999 or by email at http://diceelectronics.com/product-support.
Old 05-01-2011, 05:08 PM
Mein Auto: 2007 X3
(for a X3 without navi and satelite radio)
If you have this problem, just plug directly the cable at the back of the radio. For this, you will need 3 repair kit wire and a connector. Take one of the two connector at the back of the radio (CD changer or satelite radio). The rapair wire (3X) was took at the VW dealer (SN: 000 979 009).
This is the chart for the pinout:
DICE cable-------connector
1-White-----------pin 8
2-Black-----------pin 2
3-empty
4-Red-------------pin 9
5-black-----------useless
6-empty
As you can see, one of the two black wire is useless.
Plug the other 3 wires harness normaly in the connector (Under the armrest console - CD changer)
Good luck in your mod.
Old 05-09-2011, 09:31 AM
TLC X3 2010 TLC X3 2010 is offline
Mein Auto: everywhere
(for a 2010 X3 with navigation and no-CD changer
I installed the Dice this weekend. It is easy once you read some of the tips here and see some of the youtube videos. Anyway my 2010 X3 did not come with the CD changer in the center console or the back. The console did not have both the 6 and 3pin connectors required to hook up. Thus requiring the hook up to the cable connectors located in the rear of the vehicle. This required the removal of the back seat and side cushion, routing through the rear seat trim and under the carpet to the center console which also needed to be opened up enough to route the wires. Set the dip switches on the Dice device to NAV Radio setting, disconnected the battery, connected the dice unit and reconnected the battery. The Nav system recognized the ipod but no sound. Very frustrating. It appears that since my X3 did not come with the CD changer BMW did not hook up the white CD SARS wire to the back of the radio. Once I took apart the dash and hooked up the wire everything worked. Hope this helps someone else save some time.
Similar Threads
[eas] * New product announcement * DICE High Definition Radio w/ iPod Integration! tom @ eas Site Sponsors & Bimmerfest Group Buys 69 01-05-2007 12:39 PM
[eas] DICE High Definition Radio w/ iPod Integration Upgrade for existing DICE users tom @ eas Site Sponsors & Bimmerfest Group Buys 7 12-01-2006 12:11 PM
E46 iPod w/ DICE - major problems diamedic Car Audio & Electronics Forum 1 10-23-2006 09:03 AM
M3 - XM, ipod and subwoofer installation mzilla Car Audio & Electronics Forum 0 02-19-2006 10:31 PM
