Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 03-30-2007, 12:52 PM
jaugustavo jaugustavo is offline
Mein Auto: 2000 740iL
just did a brake job on e38...
so i just completed an overhaul of my brakes, pads, rotors and sensors. brakes work great, wasn't that hard to do, just time consuming. after driving it for a couple days i have noticed a rattling noise coming from the rear passenger side suspension area when i go over bumpy terrain at low speeds...??!?! anyone ever had this problem and know what it is?
thanks a million if you can help, i dont want to have to go to the dealership if it's a quick fix.
peace brothers.
o/______\o
(Oo=00=oO)
2000 BMW 740iL - Silver
Old 03-30-2007, 01:07 PM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 91 525i
Could be a swaybar link. Also check that you put everything back correctly and tightened to spec.
Old 03-30-2007, 01:51 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Anti-rattle clip in place? Anti-squeal goop set well on that side?
Curious, what did you use for parts? Stock pads and rotors?
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 03-31-2007, 01:06 PM
brembo oem spec rotors, which felt a little heavier than the ones on there and pbr axxis pads. replaced the sensors, greased everything that i was supposed to and tightened everything to oem torque specs. jacked it up and took off the tire yesterday and pounded around with rubber mallet and nothing moved. was i supposed to grease the inside of the rotor before i put it on??
o/______\o
(Oo=00=oO)
Old 04-02-2007, 11:36 AM
Mein Auto: 91 525i
Rotors should be a little heavier. The german brakes chew away much more rotor than american cars.
No grease in the rotor.
Heatshield? A wire or brake line bouncing on a dust shield?
Old 04-02-2007, 07:51 PM
rapidtransit rapidtransit is offline
Mein Auto: E30/ E36
try getting some high temp brake grease and putting 2 globs on the back os the pad where the caliper contacts the back of the pad and a glob where there the piston contacts the back of the inside pad. this will keep the pads from clicking when the square cut o-ring pulls th piston back in to release the pressure.
Old 04-02-2007, 11:29 PM
looks like it was the brake line, the rubber grommet broke and the brake line was clanging around in the o-ring that keeps it on the body. thanks for the help. btw - i greased the hell out the pads and the contacts in the calipers.
o/______\o
(Oo=00=oO)
