Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 04-04-2007, 12:39 PM
Sean McClellan's Avatar
Sean McClellan Sean McClellan is offline
Mein Auto: 1993 740iL
Exclamation Rough Spark Plug Idle
Hello I was just wondering if anyone knows how hard it is to get to the spark plugs on a 1993 740iL. I was just curious, I plan to rip my engine out next year and rebuild the top half of the engine.
Sean McClellan
Old 04-04-2007, 12:59 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
If you have not got to the plugs yet, how do know you want to do the top end rather than the bottom end?
Symptoms?
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 04-04-2007, 01:23 PM
I would like to do the top end because my heads are leaking oil
Sean McClellan
Old 04-04-2007, 02:27 PM
TerryY's Avatar
Old Fogey
Where is the leak? outside?
If it is smoking it probably isn't your heads.
If it leaking outside it is most likely just gaskets that can be changed without ripping anything out.
The spark plugs are under the black covers on each side. The coils are mounted directly over each spark plug.
10 mm deep socket is needed to remove all of the covers and the coils.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 04-04-2007, 09:00 PM
rapidtransit rapidtransit is offline
Mein Auto: E30/ E36
I work on these cars all day long, it is most likely the valve cover gaskets leaking. they get hard and brittle from the heat. you will know when you go to pull the plugs and the tube seals are full of oil. to replace the gaskets you will need to pull all of the small clips off of the injector connectors and hold the harness out of the way with a bungee cord. use spray trim adhesive to glue the gasket onto the cover before putting it on. dont drop any of the hollow bolts or washers for the cover they are impossible to find.
