E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3! |
M3 update
One Bad M...
Very good stuff, thanks!
Listed as 3648 lbs, what was the official weight of the E46?
2000 IR/Bk M Coupe |
The footnote for the weight figure in this PDF describes it as
But taking away 75kg for driver and luggage yields a curb weight of 1580kg, or 3476 lbs, compared to 3415 lbs for the E46 M3, for a net increase of only 61 pounds, which is quite a trick, all things considered. And let's not forget that a good portion of the savings probably comes from the CF roof, which should lower CG relative to the E46. I think most people were hoping that M GmbH could keep the E92 M under 3500 lbs, and it appears that they have. Let's see, 61 pounds heavier, but with 26 lb-ft more peak torque and ~80 more hp!
Patrick Him: 2008 135i Alpine White Sport|NAV/iDrive|HDRadio|BT|Step (WAF) 2005 ///M3 Silver Gray PCD 25 May 2005 Traded in 26 Mar 2008. 1993 325i 5MT|H&R Sports|Bilstein HD|RD Sport Sways|Mille Miglia MM-IIs w/ 225/50-16 Bridgestone RE750s|UUC StrutBarbarian|JC Chip & CAI|M3 cat-back|UUC Clutch Stop|Alpine HU & changer|Boston Acoustics 6.53 Pro|2 x JLAudio 10W0 subs|Xtant amps Hit 9 Jun 2006. R.I.P. Donated to charity 5 Jul 2006. Her: 2005 Honda Odyssey EX-L Silver Pearl |
Thanks for sharing. From page 18, you can kind of depict that there is going to be a M3 Sedan. Number of doors/seats - 4/4 instead of 2/4 for the coupe.
Thanks for this post.
2005 330i | ZHP, Xenons, Jet Black/Natural Brown (Black Cube) |
Thanks for the post!
FYI I pulled the original file and replaced it with a scrubbed version. BMWNA really frowns on Center personnel pulling this stuff off of their proprietary site, and posting it on Internet forums (usually imposing financial sanctions on the Dealer Principal). James W, your job is safe now!
The extra weight is probably due to things like (just guessing here):
I'm pretty appalled at the weight. This isn't progress. It is unavoidable I suppose because the chassis just keeps getting bigger every generation (why? stop!).
To put all this money into the engine, to make it 30lbs lighter, and the roof, and end up 61lbs heavier than the e46 which was already too heavy, is ridiculous, imo. You can't make up for weight with power alone, unless you are just a drag racer (in which case you could have bought a mustang) Part of the greatness of BMW is nimble handling, grip, and all around performance. You cannot get that with 3,500lbs of weight. To handle the thermal load from a car that heavy when cornering you would need something like 335mm tires all around and that isn't going to be nimble, or reasonable. I guess I can vote with my dollars and go buy an E36 M3, and find a way to get this new engine in it =) The new M3 is a sweet car, but it seems more like a slightly lighter M5 than what I think of as being a great M3. When comparing the M3 to cars like a GTO or Mustang you used to be able to point and laugh at the overweight american iron...not so much anymore. Last edited by jmott; 04-12-2007 at 01:08 PM. |
Ed |
