Old 05-20-2007, 09:01 AM
dmako's Avatar
dmako dmako is offline
Mein Auto: 1999 528i
Another complete cooling system replacement done
Yesterday we did a complete cooling system replacement in my 99 528i. I had no signs of leaks but at 108K miles figured it would be good to do.
Replaced, radiator, expansion tank, hoses, idler and tension rollers, water pump, thermostat, fan, fan clutch, and fan pulley.
The hardest portion of the job was removing the fan nut, used 32mm wrench, heated with oxy/acetylene torch, air chisel, nothing, would not budge. Ended up drilling a hole through nut into WP threads and putting in more liquid wrench, finally broke free. Unbelievable as the nut looked in such good condition i.e. not all rusted, and after removed the threads were fine.
Yes we used anti-seize on new nut.
My water pump had metal impellers and looked brand new as did thermostat.
Ones all was replaced we used an airlift device to decompress the entire cooling system and 'sucked' in all new coolant and water, no bleeding required! Never saw this in action neat.
Well done, few, and thanks to all for my questions leading up to this.
1999 BMW 528i sports pkg. 5-speed, rear lip spoiler, removed phone, Aspheric mirror, new M5 dead pedal, home made clutch stop, removed intake muffler, clear side and rear lights, Nein CDV, full cooling system overall, Beisan VANOS seals.
Best mod to date: removed seat clip.
Old 05-20-2007, 08:03 PM
rudejamaican's Avatar
rudejamaican rudejamaican is offline
Send a message via AIM to rudejamaican
Mein Auto: 2008 335i Sport
How much did the whole thing cost, I am replacing my water pump and thermostat in 2 weeks, I think I am going to do the hoses also just to play it safe.
Old 05-20-2007, 08:06 PM
Brian McKinney's Avatar
Brian McKinney Brian McKinney is offline
BMW Nuthead
Mein Auto: e92 M3 6mt
man your not lieing that fan nut was the biggest pain getting back on, there was no room to hold up the fan while turning the nut, that took us 30 minutes to put on..did you use any Redline Water Wetter with your new coolant, I used it.. the temp gauge is just slightly left of normal
08 M3
TMS pulley
RPi scoops and drop in filter
DRB Motorsports axle back exhaust
Old 05-20-2007, 09:34 PM
cn90 cn90 is offline
Some thoughts:
dmako, glad you did it, you will drive with peace of mind knowing that the next cooling job is some 80K away
1. 32-mm fan clutch nut, easy for me, simply use a long screwdriver and a big whack COUNTERCLOCKWISE...the fan clutch came out in 1 minute.
2. Redline Water wetter IMHO is snake oil
(I use Redline MT-90 in my manual trans and Redline 80W90 in rear diff).
So Water Wetter is unproven, a marketing tactic...........
cn90
Old 05-21-2007, 04:36 AM
BMW Nuthead
seems to work well saving race engines, alot of Redline stickers used in SCCA GT and Street Touring classes, definitely wouldnt hurt anything
08 M3
TMS pulley
Old 05-21-2007, 03:17 PM
dmako's Avatar
Total cost $616.00
Old 05-21-2007, 03:18 PM
dmako's Avatar
Some thoughts:
cn90
Thanks, your write up on the replacement made me go for it. An indy wanted something $400 just to do the radiator. We replaced everything.
Old 05-21-2007, 04:23 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
i love my BluePoint Airlift tool. going to flush my system every year so i'll be putting mine to good use.
americandan.com
It takes a lot of work to be lazy.
Old 05-21-2007, 05:02 PM
dmako's Avatar
Okay that was you, on a previous post I asked about flushing and you posted a pic of the Airlift. Never even knew it existing but my buddy had one. It's the only way to go!
Old 05-22-2007, 12:15 AM
jvcajita's Avatar
jvcajita jvcajita is offline
e39 m5 touring aspirant
Send a message via AIM to jvcajita Send a message via MSN to jvcajita Send a message via Yahoo to jvcajita
Mein Auto: LSB WB 540 Touring VF S/C
that nut definitely was a deal breaker for me too. I actually even ordered the special tool for that fan holder, it was still hard.
so $616.00 was all on parts? you did all the labor?
Old 05-22-2007, 03:19 PM
dmako's Avatar
Yes 'we' did all the labor. My buddy is a mechanic. Did it in about 7 hours of which 4 were bull $hiting. Would take around 3-4 hours.
Old 05-22-2007, 04:06 PM
Ignore this......
hey dmako,
It is cn90...how is your baby running, good I guess?
I used the screw driver trick and in one whack with 32-mm wrench, it came right out.
Anyway, glad you did it......I did it alone so it was boring listening to music. At least you have a buddy to bs while doing the cooling job LMAO
Actually you are right, you can do the whole thing in 4-5 hours. It took me the entire Saturday because:
1. I did not have a repair manual (I have fixed so many cars before so I kind of used my common sense to get through this job)
2. I had to take notes and photos and verified bolt sizes in preparation for the write-up.
The write-up itself took another brutal 10 hours!!! To this date I have not made a single penny from my write-up....but I benefited from the bimmerboard forum for other things so I "paid" back by writing it up so other can benefit from it.......LMAO
Now you can drive in peace (D.I.P.) knowing that your cooling system will not let you down............
Old 05-22-2007, 04:36 PM
dmako's Avatar
hey dmako,
Piece of mind is the key, I tell you though, all parts looked very clean except for the radiator.
Also I am hoping as a bonus, I had a whine when cold and an indy told me it need a new clutch kit $1000. With the cooling overhaul I don't hear the whine any more.
Now it may be the fact that it is warmer now, not absolutely sure, but hoping.
But it didn't fix my VANOS cold idle issue, oh well.
Old 05-22-2007, 07:39 PM
Look can be deceiving
Look can be deceiving when dealing with car parts...
Your old parts may have looked OK, but functionally they are close the end of their life.
I bet you the whining thing may have been from a worn tensioner/roller.
I can tell you (see my write-up), the WP looked like new but when I applied pressure, the bearing is already worn (there was a play in the pulley); the nroller grease already dried out.
I am surprised your indy told you you need a clutch. The whine from tensioner/roller happens at rest, even without the car moving.
Re: clutch don't worry, my last car E23 (83 735i) the clutch went at 12y and 120K miles.
And it gives warning such as slipping. So I am pretty sure you do not have the clutch problem.
Anyway, now enjoy the drive!
Old 05-22-2007, 08:03 PM
Gh0sT Gh0sT is offline
I want an E46!
Mein Auto: 06' Jetta
For me idler and tension rollers, water pump, thermostat, upper and lower hoses, belts, and cabin air filters = ~214.00
hmm...
Old 05-22-2007, 08:32 PM
In my write-up, EVERYTHING IN THE COOLING DEPARTMENT WAS INCLUDED.
In addition to your list, I also replaced:
- Radiator $170 or so
- Reservoir $55
- thermostat housing $30 or so
- There is a difference between 'rollers' and tensioners'
Unless you are aprt distributor yourself, in my write-up the retail for all thoses parts is $550 or so, give or take a bit
Old 05-22-2007, 10:36 PM
chivas's Avatar
my record for changing out the water pump (the biggest PITA part) was an hour and a half... from breaking the fan off the pump to Airlifting the system.
yeah... no fun included. just blew thru the whole disassembly and reinstall all at once... nonstop.
your vanos issue is with the $h|t seal BMW uses in there. check the FAQ for the techincal thread on Roadfly about it.
americandan.com
Old 05-23-2007, 03:47 PM
dmako's Avatar
RE: your vanos issue is with the $h|t seal BMW uses in there. check the FAQ for the techincal thread on Roadfly about it.
Been there, time to bring that thread back to life? LOL
