Front suspension shudder over bump
This only happens about 1 out of 10 times when I'm going over bumps. On the more serious bumps, the whole front suspension seems to shudder violently for about 1/2 second. Any idea what it maybe? The front shocks have been replaced.
Is it bottoming out? The front shocks are bilstein (yellow color, not sure which model), I think the springs are the sport package stock springs. I've also just ordered rear bilstein HDs to match the fronts.
01 530i Sport 5 speed Last edited by ctan; 05-17-2007 at 06:45 AM. |
Does it happen while braking?
I have the same problem with my 01 530 5 speed (sport package). On occasion if I hit a bump while braking the whole front end shakes until I release the brake and re-apply it. I've seen other posts on this before & on other boards (search the roadfly board). It seems to be a rather common problem. I think I read it could be the control arms. I have not done anything about it because it happens so infrequently (2-3 times a year), it would be impossible to duplicate to a mechanic |
It does shake pretty violently, I don't know if it is the braking, but I can be more aware next time.
It seems to affect the whole front end rather than just the wheel that is being bumped. I kind of suspect it may have something to do with the sway bar.
01 530i Sport 5 speed |
I have always suspected the ABS system but the yellow triangle never lights up.
Actually I'm not sure if the triangle supposed to light up for braking or only traction loss? |
Slightly different problem - mine has the front end shudder when going over almost any size bump, with or without the brakes. There is an audible rattle coming from the front left wheeel, as if it's bouncing. If I'm on an exit ramp or makig a turn at the time I can feel the back end lose it for a split second. I think it's probably either a sway bar, control arm, or some other ball joint issue. Any one else experience this?
Unless you ask, the answer is always no. |
I had this same issue. It turned out it was front control arm end links. $150 including labor and parts to replace and and everything is great!!!
Good luck! |
Actually i dont think I had the same problem. Mine rattled and shook whenever i went over any bigger than small size bump on the road. HAd nothing to do with braking.
Think you and I have/had the same problem. I'll get the end link(s) check out - thanks!
My 1999 and 2002 both seem to do this. I assumed it wss "normal". No ABS light that I've noticed. Would the bad end links be covered by the CPO?
Get your mechanic to check the front struts for leakage. I can almost guarantee that this is the problem. I doubt its ABS. I had my front struts leak and go about a year ago... and unfortunately due to lack of money only got them replaced a week ago. This is exactly what would happen to me. When I'd hit a bump, it felt like the front tires were bouncing on the road a bit, and the car would shudder.
Since getting them fixed the car feels like a whole new monster. Its as smooth as silk now.
Strut mounts, possibly?
I just replaced front and rear shocks/struts. I re-used one of the upper strut mounts because it looked ok visually. Within a week it failed and caused some symptoms like what you're describing. Replaced it and all was good. The FIRST thing I'd always check would be the front control arms. They're notorious for failing around 50,000. The design of the front suspension causes them to wear far more than any of the other parts. Good luck!
02 540i 07 X5 |
Just got the news...need new struts. Mechanic said they had "no gas left in them" which would explain the shudder over the bumps, the loss of back end control, and the sea-sickness. Of well, it's just money, right?
