Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Z3 (1996-2002) and Z4 (2003-2008)
#176
Earl,
Wow, what a thread. As you know I only recently added the M coupe to my garage and am trying to learn more about it. I am not too interested in mods but I sure am learning a lot about the car from your post! I also like your attitude with some of the negative comments.
Kevin 2002 E39 M5 Sterling Gray/Caramel 2007 M Coupe Silver/Black 1999 Mercedes ML320 (hauler...) |
#177
Do you use a tire pyrometer at the track? As you play with the variables of camber and tire pressure, it's nice to collect some data to verify that you're doing the right thing...
'06 M Coupe #308 - Silver Gray/Sepang Brown Dark/Aluminum E36 M3 - gone E24 645 - gone |
#178
Update
I swapped pads today for my track days tomorrow and Sunday. I'm going with Perforance Friction Carbon Metallic race pads front and keeping the "stock" Axis rear. Hopefully there will be no issue with the change in friction bias...we'll see... I also updated my seatbelt guides as per grnrcr's suggestion: [IMG]http://ebsart.com/images/Net%20Publication/Misc%20Scatha/Mod%2028.JPG[/IMG] It looks much better than my initial bolt/washer fix. The only problem is that the seatbelt doesn't retract as well because the CG-Lock's added weight "weakens" the return spring tension. |
#180
Nice work done to your car
#181
Update
Round 1 at Cal Speedway went flawlessly yesterday - IE: No walls were hit The NASCAR banking is very intimidating and the Gs can be downright uncomfortable. By the end of the day I was peaking at 8k in 4th (145mph) just before turn 1, turning in at about 140mph and carrying 135mph through the turn if I caught the right groove. The PF pads worked pretty well once they were fully bedded. Meaning that the car stopped much quicker than with the Axis street pads, but the brake balance was somewhat effected by dissimilar f/r pad material. The car nosedived more as the rear wasn't equalizing the braking forces. This did not translate to any significant stability problems, but didn't boost my confidence either. Today I took the car down to BMS and put on the Hawk HT-14 and HT-10 pads that hadn't arrived in time for Friday's HPDE. My only experience so far has been bedding them in, but the car feels much more planted - squatting on all fours instead of pitching forward. We also cut out the factory air plugs so there should be a little more airflow around the brakes. I'm quite exited to drive tomorrow! p.s. After examining vids I shot with my little camera sticky-podded to the Coupe's roof my lap time in the 4th session was around 2:00 to 2:01. My fastest lap was 1:59. |
#182
Anyway, you went with the HT-14's, huh? Sounds like a really agressive setup. What's the noise like? I assume you're going back to the Axxis street pads for day to day driving?
1995 E36 M3 - Euro Motor, track prep COMPLETE! 1/16/2008 Coming Soon: 1995 E36 M3 - Built 3.2 US Spec, track prep Sold: 2006 E86 Z4 M Coupe 2006 E60 M5 2001 E46 M3 |
#183
Update
Here are my pics from this weekend's HPDE at Cal Speedway. The Coupe behaved fabulously and once again confirmed that it is the right car for me Pics of the paddock area: Friday there were a lot of Corvettes...and most of them were track or race-prepped: This Z06 was mean looking, although I was faster until he learned the track better. It still amazes me how a low-powered car can keep up with a more powerful car in the straights just from cutting a better line. My Coupe parked on Sunday: I never saw this Ferrari on track. I guess he wasn't fast enough to lap me, and I certainly wasn't fast enough to lap him: This C5 was supercharged and was putting more than 700hp to the rear wheels. The Coupe was still slightly faster around the track however, as he had trouble putting all that power down and even with slicks the C5 is not a great-handling car: Another David vs. Goliath story was this Shelby GT 500. With 550hp it was still a LOT slower around the track than my Coupe. Props to the guy for bringing it out though! I'd much rather see it getting wrung out than sitting in a garage More cars in the paddock: I watched one of the POC races. It was fun. There were good battles for 1st and 3rd. Continued in the next post... |
#185
...continued from the last post...
Pics of my Coupe: On the front straight: On the banking at about 130mph: In turn 5: Chasing a Lotus through turn 11: Going through turn 12: Some pics of the Coupe at turn 13. If you look closely you will see my roof-mounted camera system: Turn 15: Turn 18: Crossing Start/Finish: Those aren't bugs, that's all road tar from the track My front right RA-1, still with some life left in it. Note the paint marks to check for fender rub (no rub, with the most recent ride height adjustment): I took video (from the roof camera) but can't edit it without my computer crashing. So I'll try to get it over to my laptop and edit it down so I can publish it... |
#186
Sweet pics, suprised to see the Elise's lean more than the MC in the turns.
Ciao! - - Nathan 2000-2.8L Z3 StahlGrau Roadster (some mods) ~ 2001-335i (BONE STOCK!) BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio area FEAR MY TWO SEATER!!!!!!! Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.Z3POWER.net Member Since May 17, 2002 |
#187
Can't wait to see the video. I was just there on Monday with DCI. Did you guys run with a chicane on the front straight to turn "2" transition?
"Hack has been around the block (and back) with BMWs. And, he wrenches and tracks his cars (offering some excellent insight)! -World Famous Automotive Journalist (not Dan Neil, but close). |
#188
They're pretty softly sprung. Surprised me too the first time I saw one in action. It's all about the balance...
#189
Elise ![]() ![]() Z4MC with stock suspension (and not driven all that aggressively) ![]() Z4MC H&R sport springs (driven aggressively but not all that competively )![]() I think the first photo is the only one I took. The blue Elise and I were in the same run group and I was working when the other Z4MC was running. I let a friend who was not running use my camera to capture the 2nd and 3rd run groups. Last edited by Cliff; 05-24-2007 at 08:19 AM. |
#190
-Cliff, those image links didn't work at first, but then they did after a refresh - weird! Anyway, great pics. The Lotuses sure do lean, even more than a stock MC, which is saying a lot! Last edited by Palantirion; 05-24-2007 at 09:38 AM. |
#191
Chicane. Given the hardware we had at the track and what happened 3 years ago at the speedway, running sans the chicane would have been suicide. Sans the chicane we have several cars at the track that can easily reach in excess of 180mph. By my quick calculation, we had in excess of 10,000 hp at the track.
#192
Here is my fastest lap of the weekend, 1:59.20. It's definately not perfect, and I welcome discussion if anyone wants to analyze it with me. (p.s. This may get taken down in the near future for hosting space reasons, so d/l it now if you want it on file.) VIDEO |
#193
I was being my usual overly dramatic self with the "suicide" comment. By the end of the day almost all the cones were knocked down, so when I had a chance to go drive my one session I didn't bother slowing down too much for the chicane anyway. I actually got a little motion sick (which I NEVER had) the first half of the day and was only able to hot-lap for about 8 laps. There's too much wind noise so I can't tell when you're applying throttle, and the camera position makes it impossible to see hands, so I can only comment on the line. What you may want to try the next time you're there, is on turn 2, when you past about the half way mark (you'll see it on the video as you pass the "2" on your right hand side) you can dial in a little bit more turn and let the banking of the turn shoot you straight to your braking zone. You can pick up a lot more speed this way. You need to get to the bottom of the banking where the grass meets the concrete (but don't use the concrete inside the white line where there's no bank). Especially on R-comps, that drop on the banking and straightening out the last half of the turn let's you get on the throttle much MUCH harder for that last portion before you have to hit the brakes. It's not the safest line so be careful, as it requires straightening the car out just prior to getting to your braking zone, as oppose to actually having the comfort of having the car straight for quite a few seconds before getting to your braking zone. But I've experimented with both lines and have found that I'm about 5-10mph faster. Turn 5...Try double apexing that turn. Make the line shorter, throttle steer mid turn. At 3,200 lbs the MZ4 Coupe is just light enough to make that line work. You'll probably go through the turn at the same speed, but the double apex line makes for a shorter "curve." E46 M3s, 5 or 6 series I would probably take that wider line you took. Looks like you've done the Speedway in a heavier car and got used to the heavier car's line. Other than that, I'm not sure what else I can suggest for a faster line. I wonder if you've tried getting to the top of the bank on the front straight before getting to turn 2? I've gotten so used to driving it with the chicane that I always get to the top of the bank by the time I cross start-finish.
#194
Hey Folks, new to this board (my first post)...I've read through this entire thread, probably one of the best I've seen on any of the boards I frequent. That being said, has anyone compiled a relatively comprehensive list of what performance mods are currently available for the Z4 M Coupe.
I recently picked up an '06 with ~2K on the clock and am looking to make some changes. the items I've been able to find (but not neccessarily items I would choose) so far are: UUC Short Shift UUC Clutch/Flywheel Dinan 3.91 (local shop has a 4.10 as well) Ubiquitous CDV removal SuperSprint Exhaust I'm sure there's a K&N for the car Anyone have any others or know of one spot to find a list? Thanks...looking forward to the feedback. |
#195
I'm going to be getting a proper camera/telemetry setup this summer.Quote:
-Any suggestions for the last complex (turn 13+)? I never felt like I found a groove through there. Quote:
#196
[QUOTE/]-I've got a list of my mods, but it would take more time than I have to list every possible mod. Also, we're still not sure about certain products - one's that work for an E46 and "should" fit. Time will tell. Probably a better strategy for you would be to figure out what you want the car to do differently and then see what products/advice can help you attain that goal.[/quote]
Thank you for the reply. Your suggestion is as reasonable as it is obvious. I do have some idea of what I'd like the car to do differently, I was simply hoping someone might be able to add to the list of performance options I wrote down in the event one of them might be of interest. Given the relatively few options available I was hoping someone might be able to fire off a few that I wasn't aware of. I'll ask a few specific questions: Are there any other exhaust options outside of SuperSprint? Does anyone know if there is an Alcon Brake kit available for our cars? Is it worth getting the UUC short shifter (at $350) or is the Dinan shifter worth waiting on? Are there any other clutch/flywheel options other then UUC? Does anyone have any experience with 19" Neez wheels on the M Coupe? I've heard some mention of Motons being applied to the M Coupe, anyone else seen/heard this? Thanks again. Last edited by Luminor; 05-25-2007 at 12:23 PM. |
#198
2) No idea, but I wouldn't go with Alcon over StopTech, Brembo or PFC. If you want to upgrade your brakes for cheap, swap the pads and put in stainless lines. 3) I really like the stock shifter, so I haven't researched any Z4 alternatives. 4) Not I. 5) We considered several of Moton's products but opted for TCK's because they are less expensive than Motons, easier to install, and are the valving is already optimized for the MC. SteveHiFi may be going with Moton Club Sports. |
#199
http://www.eisenhaus.com/ehdetails.p...57&Submit.y=14
- SuperSprint Race - OE STB - Dave Z Modified CDV - RE CS - H & R Sport - ZHP Shift Knob & Leather Z M Boot |
#200
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Z4 M Coupe at NHIS | brave1heart | Z3 (1996-2002) and Z4 (2003-2008) | 9 | 11-11-2006 09:52 AM |
| 335 news release today => 535 next year | klu123 | E60 (2004 - current) | 34 | 04-26-2006 03:35 PM |
| Z4 coupe wheel styles | Don L | Z3 (1996-2002) and Z4 (2003-2008) | 6 | 03-28-2006 06:55 AM |
| Z4 Coupe design | Axcu | Z3 (1996-2002) and Z4 (2003-2008) | 0 | 12-10-2005 02:17 PM |
| NEW BMW Z4 Coupe Video | OC-Z4 | Z3 (1996-2002) and Z4 (2003-2008) | 9 | 10-07-2005 05:13 PM |
