Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3!
Old 06-19-2007, 09:16 AM
Bruce's Avatar
Bruce Bruce is offline
///M forum moderator
Mein Auto: 88 E30 M3.2, 08 451
E92 M3 alpha N?
Reading the latest article about the motor in the E92 M3 seems to indicate it does not have an MAF....indicating it has some sort of alpha N setup. The E46 M3 CSL got another 17 hp from the CF intake and the alpha N, but it was not available on the regular E46s.
Old 06-19-2007, 09:26 AM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein Auto: Ti Silver 03 M3
From what I understand they did away with the MAF, which is cool.
Tim
The 2014 F32 4 Series Coupe Concept
BMW F32 4 Series Coupe on sale summer 2013
Old 06-19-2007, 09:42 AM
Bruce's Avatar
Well...then it does have alpha N then.
Old 06-19-2007, 07:35 PM
GregW in Oregon GregW in Oregon is offline
Mein Auto: '01 M3 Coupe; '06 ML350
Tim
"From front to rear, the entire flow of intake air in the new eight-cylinder power unit does not require the usual hot-film air mass flow meter with its obligatory sensors. Instead of determining engine load by means of such elaborate sensors, therefore, which would also create disadvantages in air guidance due to the geometry of the components involved, the V8 power unit of the new BMW M3 uses the engine control unit to perform this function. To do this, the system determines engine load under current driving conditions by taking the position of the throttle butterfly and idle adjuster, the position of the VANOS control unit, engine speed, air temperature and air pressure into account. This, in turn, gives the engineers at BMW M GmbH new freedom in the configuration and optimisation of the engine air intake process. And at the same time this management concept operates with maximum reliability." -- BMW press release 3/22/07
Greg Lake Oswego, Oregon
2008 M3 Coupe - Alpine/Fox Red/Carbon
2012 M-B ML350 - Arctic/Black/Satin Ash
Old 06-20-2007, 10:03 AM
Penforhire Penforhire is offline
Mein Auto: 2006 330i
Doesn't sound as accurate as a proper mass air flow sensor.
Old 06-20-2007, 10:11 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
It's not. But you can flow huge amounts of additional air that way.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 06-20-2007, 11:35 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
It sounds like an enhanced Alpha-N, one that conforms today's strict emission standards.
Alpha-N uses RPM and the position (angle) of the throttle butterfly (Alpha), where the new system uses these, plus a bunch of other parameters.
Of course, this will require a bad-ass DME, which will enable real-time monitoring of all these parameters and forward them to the engine.
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 06-20-2007, 11:58 AM
Bruce's Avatar
Agreed it is much more complicated than what I woudl fit on an S14, but cool nonetheless.
Old 06-20-2007, 12:10 PM
The stock Bosch unit was able to handle it for the CSL. I doubt it'll be that much more complicated.
Old 06-20-2007, 07:46 PM
ObD's Avatar
ObD ObD is offline
Mein Auto: '08 535 6mt
No Microsoft is involved.
