Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 06-24-2007, 11:28 PM
munchen munchen is offline
Mein Auto: 325i manual sport
Question V8 engine M3 (E92...) require valve adjustment?
Does anyone know if the new V8 powered M3 (E92...) require regular valve adjustments -- like the E46 M3 engines?
Old 06-25-2007, 08:43 PM
GregW in Oregon GregW in Oregon is offline
Mein Auto: '15 M4 Coupe; '12 ML350
Valve adjustment
No, they're hydraulically adjusted like most cars these days. BMW figured out how to do it and still keep the valvetrain mass down.
"The single-piece aluminium cylinder heads feature four valves per cylinder in characteristic BMW style. The valves weighing 42 grams each are activated by ball-shaped cup tappets with hydraulic valve play compensation. Tappet diameter is only 28 millimetres or 1.10, while the intake and exhaust valves measure 35 and respectively 30.5 millimetres (1.38 and 1.20) in diameter. Measuring only 5 millimetres or 0.20 across, the valve shaft has hardly any influence on flow conditions in the intake manifold, while the hydraulic valve play compensation rules out any change in valve play, ensuring lasting reliability and at the same time reducing the cost of maintenance." --BMW press relesase
Greg Lake Oswego, Oregon
2015 M4 Coupe - Silverstone/Sakhir/CF
2012 M-B ML350 - Arctic/Black/Satin Ash
Old 06-26-2007, 12:52 AM
Thanks Greg W for the answer to my question re: valve adjustment on V8 M3 engine. Another reason for the V8 M3!
Old 06-26-2007, 06:20 AM
Valve adjustment
Here's a pic of the valvetrain components:
Old 07-03-2007, 05:12 PM
Chimera's Avatar
Chimera Chimera is offline
Out, Out Brief Candle!
Mein Auto: Jeep Grand Cherokee (WK)
Where do you guys find this stuff at?
Old 07-03-2007, 05:17 PM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
Nice
http://www.worldcarfans.com/print.cf...2.001/lang/eng
WorldCarFans is usually a good place to check.
2015 VW Golf R: (pic)
