E30 (1982 - 1993)
Old 07-26-2007, 03:48 AM
Goos_M325i Goos_M325i is offline
Mein Auto: BMW e30 M325i
Question No.28 in Fuse Box popping!!! Please Help?
Hi...
I drive a E30 325i...
When I engage the cigarette lighter the electric windows dont operate when my doors are open. Normally the cigarette lighter and electric windows operate when doors are open while the ignition is off.
Then, it pops the no.28 fuse everytime as well.
My radio ariel never worked. and is disconnected.
Even with the lighter completely out of the socket, if i connect the socket via the back wires then it still pops the no.28 fuse.
Any ideas?
BMW Rulez!!!
Old 07-26-2007, 11:39 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
RE the lighter, there is probably something in the socket shorting it, replace the socket and quit smoking, it's bad for you.
RE the windows, check the wiring harness where it enters the door, I'll bet you a pack of smokes there is a cracked or broken wire there.
Take my advice, I'm not using it.
Old 07-26-2007, 05:56 PM
delphini's Avatar
delphini delphini is offline
BMW ADDICT
Send a message via Yahoo to delphini
Mein Auto: 87 cabbie AND 90 sedan
mine does that too , its a 30 amp fuse , i dunno either , my ariel works (did work) once i replaced this fuse.
Old 07-27-2007, 12:30 AM
Thanks ross1
I was thinking that as well but thought maybe it could be something more extensive.
Uhm, i am having a "break down yard day" next week and picking up a few things on my "Replace List". A new ashtray will be one of them...
I no smoking is bad and im trying to quit, but this darn ashtray/cigarette lighter short is jis stressing me out
Delphini... Sup dawg
Howz the cabrio doing? Any new mods?
Old 08-07-2007, 03:00 AM
Thanks ross1....
I fixed the problem. Bought a new ashtray with sighter socket and everything is going well.
No more popping fuses
Thans again...
BMW Rulez!!!
Old 08-09-2007, 08:00 PM
delphini's Avatar
BMW ADDICT
sup goos, ummm a timing belt change and water pump new ecu w/chip just got an is spoiler i'll install before winter and some sideskirts not installed so i got a few projects brewing also i want to get my hood resprayed before winter hows your ride coming along?
Old 08-10-2007, 12:42 AM
Sounds like you gonna be busy... Cant wiat to see the results...
My car still pretty much the same as before, running on 14" wheels tho...
Racing @ our local track on the 1/4 drag strip. Will post pics and results asap.
Send those pics bro...
BMW Rulez!!!
