E36 (1991 - 1999)
Old 08-27-2007, 03:40 PM
samsonite's Avatar
samsonite samsonite is offline
I'm here all week
Mein Auto: 1997 318i
Rust spots
After cleaning my car today, I noticed a couple of little rust bubbles. What is the best way to deal with these? I can remember on my first car I sanded it down, primed and sprayed (that's how I'd do a door on my house!), but it was a £100 car and I didn't really care if it went wrong. Just wondered how everyone else does it?
Old 08-27-2007, 03:48 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
We take ours to a bodyshop mate
Bit more expensive but at least you know it is done right
If you know how to do it, why not try and if it goes wrong...THEN take it to a shop
330i M-Sport in Topaz Blue
Edirty6 for life
Old 08-27-2007, 03:54 PM
samsonite's Avatar
I'm here all week
Maybe I'll have a go at one patch, but I'll check how much all the bits will cost - it could be more than it's worth.
Old 08-28-2007, 06:03 AM
Jim Spence's Avatar
Jim Spence Jim Spence is offline
Tyler's Paw Paw
Mein Auto: 1993 325i
I recently fixed three rust spots on my 325; two were underneath fender wells (not visable) and one was dead center at the top of my windshield.
After getting a quote of over $600 PER SPOT to fix the three problems, I decided to tackle them myself first. I figured I could always pay the bucks to a body shop if my work was substandard.
The spot on top of the car ... I pulled away the gasket at the top of the windshield, used a Dremel tool (on low speed) and a fine sanding disc to remove every bit of rust - down to bare metal. I then applied three coats of primer (waiting the desired time between each one before applying the next coat), three coats of BMW paint, and four coats of clear coat, again waiting the desired time between each one. This process took about three hours total. Then I used rubbing compound a number of times to bring up the finish.
The only thing you can even see is a small dimple where the original paint was (as if I didn't put enough layers on it), but this dimple is ONLY noticable if you're looking hard for it.
It's been over three months now of rain and sun, and the spot looks as good as the day I did it.
Conforti chip, aFe CAI, Bilstein struts/shocks, H&R springs, Mason Engineering strut brace, Borla exhaust, BSW/Sony audio, TMS cross drilled rotors/Hawk HPS high performance street pads, BMW style 43 16" wheels with Bridgestone Potenza P960 tires and if you've read this entire signature just to see what I've done to my car then you need some serious professional help.
If you can't afford to do it right, you definitely can't afford to do it wrong.
Old 08-28-2007, 07:05 AM
oakley's Avatar
oakley oakley is offline
The Dakar Dream
Mein Auto: bmw compact 2000 e36
I just spent all weekend sorting out some rustspots on my car..the arches were going abit and i had a bad stone chip about the size of a penny by the rear window..i'll post pics when its finally done..it still needs some cuttin in etc at present
Old 08-28-2007, 10:27 AM
samsonite's Avatar
I'm here all week
It sounds like I should have a go - more stuff for the shopping list!
