#301
http://www.zpost.com/forums/showthre...t=63368&page=2
http://www.zpost.com/forums/showthre...t=63368&page=3 Gorgeous! Last edited by caylan; 08-26-2007 at 07:22 AM. |
#302
8 lbs savings... I NEEEEED one... so I keep tell'n myself, hahaha... damn it! Install looks very straight forward.
#303
Don't think of it as 8 lbs, think of it as 8lbs at the top of the car, and think of that 8lbs times about 4 ft, and then you get 32 ft lbs of torque on the car. Still not a lot, saving weight at the top of the car is good. I just like it cuz it looks sick.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int. Best Website in the History of the Internet! Last edited by Dammmittt; 08-26-2007 at 07:12 PM. |
#304
-Thanks for reminding me. I'm on 6 forums and in two different sections (E39 and Z4) on three of them - so sometimes I forget
#305
I skimmed thru that post for the install pics & not really reading the details but: is the OEM roof screwed on or glued on?
#306
Both. 4 bolts and glued all around.
So am I to understand that the roof needs to be "treated" after purchase? It needs to be clear coated, correct? Is there a special material that needs to be used?
Any ideas how this would look on a black car? The contrast looks great on lighter colored cars, but sometimes CF just looks like a dirty section of a black car...any thoughts how it would look? |
#308
Luminor, i think sixspeed put a coat of laquer on it. You'd probably want to give it a good cleaning and maybe clear coat it when you get it. TCK would be able to give you the best care instructions for it. If you want to see how it would look on a black car, look at some pics of a black M6 with a CFP roof. I think think it looks hot, but you'd have to decide that for yourself. I'm planning on installing mine for christmas
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int. Best Website in the History of the Internet! |
#309
Thanks for the quick response, but why laquer instead of just clear coat. I've got a shop that can clear coat it, unless there is a reason to use some other material...? i.e. Laquer. Link to black M6 w/CF roof: http://www.m5board.com/vbulletin/showthread.php?t=56757 ...looks like it will be very subtle. Any one have a price on this piece. I could call TC, but figured someone might know off the top of their head... BTW, please tell me you were kidding about the 32lb/ft of torque... :-) |
#310
Based on a Sapphire Black M6 I've seen in the flesh I think a CF roof can look great on black cars. But I don't know about Carbon Black though. The blue tones might clash with the warmer black of the CF.
#311
I'm planning on the roof...not sure about the hood. Sounds like the hood needs to be painted. I guess there's a seem of some kind in it.
The roof panel weighs 8.4lbs and costs 1650.00 The hood weighs 14.4lbs and costs 1600.00 ...not sure why the smaller roof panel is more expensive, but that's what they told me. |
#312
& they charge >$50K for that?
#313
At 50K the M Coupe is one of the best performance bargins out there...
#314
#315
OK, so I honestly thought you were kidding. You'll have to excuse my ignorance on the subject, I know next to nothing about physics and the formula for determining a vehicle's torque...but are you honestly saying that you believe removing 8lbs from the roof of an M Coupe will generate any where near 32lb/ft of torque? That means this roof mod would have the same, if not greater, affect on torque production as the 4.10 I just installed... ...if that's the case, I'm ordering one today. |
#316
Anyway...8 lbs is rough estimate of the weight difference anyway, probably more like 10-12 lbs. Well the point of this is that that 8 lbs directed down, is the mass of the object times gravity...lets call that g. The mass difference of the roof is always going to be the same...but the acceleration will change. Now, you remove that 10-12 lbs. You figure the center of mass of the roof is about 4 ft off the ground...estimate... So...if you are pulling one g of lateral acceleration of the car, you would LOSE about 40 ft lbs of torque (twist) on the chassis just by virtue of where you lost the weight on the car because that 1 g laterally is like aiming the weight of roof at a 90 degree angle to the normal direction of gravity (like turning the car on its side). All this means for you is when you turn hard, it puts less stress on the car because you where you lost the weight.
#318
Ahhh, I see...I'm with you now that you've made the distinction... ...and thanks for the wrench, bolts and nuts example but I do get the general concept of torque
#319
Ah, OK. That's a different story. I thought you were talking about torque at rear wheels.. My mistake. |
#320
-Except that 4' off the ground doesn't matter. What matters in your argument is the change of weight relative to the roll center of the vehicle, not the ground.
#321
Yup... distance is taken from CG, not ground. So, moment acting on the cg due to weight savings of cf roof is probaly closer to the order of 10~15 ftlb. Basically, neglible.
#322
#324
I had it clear-coated - that was all ![]() If you get one you may or may not need it done. The roof was already finished for install straight away (and TCK didn't mention any need for further treatment etc before fitting). However, when I inspected mine, there were light scratches in the resin/clear-coat that was already on there. So I asked a friend of mine who runs a bodyshop to add another clear-coat layer. Not only will this help protect the carbon from UV damage (as there is a UV inhibiter in the clear, and carbon can discolour over time from sun exposure), but it also meant they could safely flatten the new coat back until it looked like glass Which it sure does now!![]() Alpine White Z4M Coupe 19" CSLs w/ PS2s -- TCK Carbon Roof -- Gruppe-M Intake -- H&S Cat-Back -- H&R Springs -- Tints -- Storm V1 -- CDV -- DICE -- +more Last edited by sixspeed; 09-01-2007 at 02:57 AM. |
#325
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Z4 M Coupe at NHIS | brave1heart | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 11-11-2006 09:52 AM |
| 335 news release today => 535 next year | klu123 | E60 (2004 - 2010) | 34 | 04-26-2006 03:35 PM |
| Z4 coupe wheel styles | Don L | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 6 | 03-28-2006 06:55 AM |
| Z4 Coupe design | Axcu | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 0 | 12-10-2005 02:17 PM |
| NEW BMW Z4 Coupe Video | OC-Z4 | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 10-07-2005 05:13 PM |
