NASCAR-style conversion studs
New from TC Kline Racing for the serious competitor:
http://www.bimmerforums.com/forum/sh...threadid=75159 |
Those are a bit pricey - about $200 for a set (5 lug) vs. $150ish for the "crap studs" that most vendors offer (including TC Kline) WITH nuts. Seems like a reasonable extra expense.
Now those Daiyama lug nuts are trick! But is that $80 for 4 or for a set of 4 x 4 = 16? At first the wording ("complete 4 lug set") had me thinking they wanted $20 per nut. Surely I was mistaken. For $300 total it seems like good insurance. |
It's certainly not for everyone and is a bit pricey, but for people who must change wheels often or quickly it is a necessary convenience. I've seen hubs have to be replaced from having the bolts screwed in and out of them so often. They were not originally designed for this type of service and the threads in the hub mounting holes will weaken over time. Even the best lugbolts are not made out of material as strong as these studs. Lugbolts have been known to break and IMO are generally an all-around PITA.
I agree. I'll give them a shot on my track car.
Mark - who do you deal with at TC Kline?
I dealt mostly with Pete Stackhouse on the studs. The set I have was the last of the prototypes, not sure when the production parts hit the shelf.
I didn't realize that lug bolts were less durable than studs and nuts like the rest of the automotive world. Why does BMW use bolts, anyway?
![]() '88 M3 Conforti chip, Evo airbox/K&N filter, UUC short shift kit, oil pan baffle, Hella H4 lights, OEM glass sunroof sold: '99 M3 Coupe Cosmos Black Airbox baffle removed, ZKW ellipsoid headlights, UUC short shift kit, BMW x-brace, debadged '96 Jeep Grand Cherokee Laredo V8 (Support Vehicle) |
They're not necessarily less durable for their intended street use; street cars don't typically swap wheels on and off several times a month like a serious autox or track application would
Either way, it's infinitely simpler to just use lugs and nuts to mount a wheel than it is to deal with wheel bolts. I wish I knew why BMW has used bolts for so long.
Of course that does explain why bolts are used with steel wheels, like my old Fiat 850 Spider.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
I'm looking at buying a car that has been upgraded to Group N hubs with studs. I'll have to get more details on the type of studs/nuts he's using. He said the nuts are 19mm.
facebook.com/sctsracing 02 M3 SMG Coupe - prepared class BMW Club racer 08 135i 6sp - stock class BMW Club racer Photo gallery |
I'd rethink that position. |
You are absolutely right, when installed there is no contact between the wheels and threads, just like with bolts.
In otherwords, it's a problem yet no problem exists?
OK, I give up.
ok, the experts have spoken.
READ my post, like Jetfire says, there can be a problem when most idiots pull the wheel off or put it on. If you watch the normal person do this, they loosen the wheel, then drop it on the studs then slide it off. For mounting they hoist it onto the studs, then slide it back then jiggle it around to get it in place, then put the nuts on. The sliding the wheel across the threads cn damage the wheel. You can avoid that if you are careful. Or you can just replace the wheels every so often like some race teams do.
