E36 (1991 - 1999)
Old 08-29-2007, 12:10 PM
Nick72 Nick72 is offline
Mein Auto: 1996 316i SE
Help needed
I have a 96 E36. I'm a bit thick when it comes to the working of a car. I need some advice. Sometimes when driving and quite often on braking the car pulls slightly to the left. I'm thinking either the tracking is out or wishbones.
I would be grateful for any advice.
Old 08-29-2007, 12:21 PM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
Its most likely your wheel alignment, or you might need new tyres.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 08-29-2007, 12:23 PM
Just changed the tyres so maybe the alignment. Thanks for the info.
Old 08-29-2007, 12:31 PM
Vornado's Avatar
Thats probably what it is then, if you just changed them. Did it start doing it after you got them, or has it been going on before?
Old 08-29-2007, 12:33 PM
slavka slavka is offline
Mein Auto: 1999 BMW 328is
alignment
Old 08-29-2007, 12:35 PM
It was like it before I changed the tyres.
Old 08-29-2007, 12:37 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Any vibration??
2001 Mini Cooper R50
Edirty6 for life
Old 08-29-2007, 12:53 PM
No vibration. Is that a good thing?
Old 08-29-2007, 01:13 PM
Still here
Mein Auto: M3
Yeah, means your brake pads and Rotors are not warped
Edirty6 for life
Old 08-29-2007, 02:56 PM
Thanks for the advice guys
Old 08-29-2007, 03:11 PM
Still here
Mein Auto: M3
Edirty6 for life
Old 09-02-2007, 04:42 AM
Spoke to Kwik Fit about getting the alignment done on my car and was told only BMW can do it. Does anyone know if it can be done anywhere else as BMW quoted me 350.00gbp.
Please say I don't need to pay that much.
Old 09-02-2007, 05:01 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
Alignment can be done at any tyre fitting place or garage with the laser alignment things and mirrors. BMW charges more and charges a fixed price, whereas an independent will only charge you based on what needs aligning, and it will be cheaper.
Pirate, I had new tyres and alignment done a few months ago, but the car still moves to the left slightly if I don't hold the steering wheel, and the steering wheel shakes under braking. Why would I have warped brake pads and rotors? Is that what it could be, or just worn parts in the steering gear?
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 09-02-2007, 05:14 AM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
Just another quick tip.....make sure the tire pressures are equal. if there not, that could cause the pulling as well.
Cone
XXX
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 09-02-2007, 05:24 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
good call cone!
BMW, if your car's steering wheel vibrates under braking then your rotors are warped. Thats the main reason.
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 09-02-2007, 05:37 AM
B/\/\W's Avatar
I just did some reading about this issue. I might have a look into high quality ceramic pads and standard rotors, as the issue seems to be that a rotor is a rotor, made of iron, whereas the pads are composites and the best ones are made to be heat resistant. The copper filaments in the ceramic help to draw heat away from the rotors, which prevents warping of them because they don't get as hot. So pads seem to be the key here.
330i SE coupé
Old 09-02-2007, 05:40 AM
BMW FETISH!!!
I didnt know that
You learn something new everyday. Thanks bmw!
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Old 09-02-2007, 06:37 AM
318is_e36_myt's Avatar
318is_e36_myt 318is_e36_myt is offline
E36r
Mein Auto: E36 99 316i sport compact
1. Never take you car to kwik fit, they are far to expensive and are usually the independent tire fitters rejects anyway.
2. Any tire place got do it or major garage over here in the uk.
Agree with Cone. the tyre pressure could be the key on this one, so check that out first, as its free to do so.
We are all allowed to make mistakes.....we are only judged on how we fix them!
Old 09-02-2007, 08:33 AM
bobbobb bobbobb is offline
Mein Auto: 318tdse
Cone
XXX
+1
plus diffrent makes of tyre on the same axle can do this as well but mostly on the front
Old 09-02-2007, 08:35 AM
Still here
Mein Auto: M3
EBC Green or Red stuffs are your friend mate...not too expensive either
Edirty6 for life
Old 09-02-2007, 11:10 AM
greenbeem's Avatar
greenbeem greenbeem is offline
Do I Offend?
Send a message via Yahoo to greenbeem
Mein Auto: 1994 318iC
Mine shakes sometimes and not others, I know it's pads and rotors because I checked the bushings, I was just curious to why it would only do it every once in a while
She's good, but I keep finding Barbie doll's under the hood.
Old 09-02-2007, 11:12 AM
B/\/\W's Avatar
That's actually true of mine as well, it doesn't always do it under braking, weird eh?
330i SE coupé
