Loose wiring - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-02-2007, 12:17 PM
1canary's Avatar
1canary 1canary is offline
1 canary
Mein Auto: 1998 323i convertible
Loose wiring
Sorry folks, me again. Just wanted to update you on my melting fuses.
If you recall, I replaced my passenger window motor and then my fuses kept popping.
I have now fixed it myself
It turned out that when my window "inched" previously it just brushed gently past the wiring harness to my door lock control unit....BUT....when the window opened properly it snagged the harness and sliced through three wires causing a major short (and melting 20" of wire). To make things worse some dipstick had put a 20A fuse in place of a 5A one which caused the melting of the wires before the fuse eventually disintegrated.
So here's a word of advice to anyone who takes their door panel off....MAKE SURE ALL WIRES ARE SECURED TO THE DOOR AND FREE FROM ANY MOVING PARTS before you replace the panel.
I believe there is actually NO damage to the wiring beneath the fuse box...the smoke was from the fuse. Man how that smoke lingers.
Just thought I would let you know
Old 09-02-2007, 01:25 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey buddy, glad it is sorted
Thanks for the tips!!
2001 Mini Cooper R50
Edirty6 for life
Old 09-02-2007, 03:53 PM
E36 Phantom's Avatar
I Am The Machine
WHOA!!!! A 20A fuse instead of a 5A? Almost might as well have not had a fuse!
Anyway, glad you found the problem and got it all fixed properly. Might wanna check over all your fuses, too!
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 09-02-2007, 04:05 PM
Still here
Mein Auto: M3
You were lucky you only had smoke mate!!!!
Find the person who installed that fuse and smack him upside the head
Edirty6 for life
Old 09-02-2007, 06:03 PM
I Am The Machine
+1!
// Chad //
You're a derbanana
Old 09-03-2007, 10:53 AM
1canary's Avatar
1 canary
Lots of bits have not been put back on as they should have by previous owners. Why do people buy a BMW then treat it like that? Some parts could have been put together better by a four year old with a meccano set. I feel like stripping the entire car down and rebuilding it. Luckily engine is A1. Rear end had been accident damaged and only just adequately repaired but I can't understand why the rest of the car was so neglected.
BTW I will definitely check rest of electrics carefully before and after any work is undertaken
Old 09-03-2007, 10:58 AM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
WoW, a 20A inplace of a 5A. I hope that guy's philosophy in life isn't "The higher the number the better !"
Luckily you didn't fry anything else. Kudo's on the DIY though mate !
Current:
1994 318iS
Sold:
1993 E36 325i
1999 318i E46
