E30 (1982 - 1993)
Old 09-02-2007, 07:59 AM
bimmer 325 bimmer 325 is offline
Mein Auto: 325i 87, 325e 86,
2 questions?
first how can you check if the oxigen sansor is done?
sec. my obc temp sensor is loose or something, every time i go over a bump i ear a bip and the temp goes up and down up to 75 degre all the way down to -30, not sure what up with that. please help!
Old 09-02-2007, 08:53 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Any problems associated with 02 sensor won't appear until the car has warmed up a little. One way is the car will buck a little like a bad fuel delivery.
Sounds like the sensor is bad, although they are pretty durable. Get one out of a junkyard or donor car and see what happens.
Old 09-03-2007, 09:08 AM
I think my sensor is done, my car almose die a couple of time and i unplog it to see a difference and nothing apen, and like you said, look like i am missing fuel, my car buck a littel and i change the fuel filter, i was prety sure that was it but did not change a thing.
Old 09-03-2007, 09:18 AM
omw41's Avatar
How about the fuel pump? That's pretty common.
Old 09-03-2007, 09:25 AM
not sure, how much presure sooud i have? or anyways to find if it is the fuel pump?
Old 09-03-2007, 09:50 AM
i found the temp sensor problem, it was that i dint have it and the reson why it was going crazy was becouse of a short on the wire. all fixe now.
Old 09-03-2007, 06:41 PM
JAKE325's Avatar
JAKE325 JAKE325 is offline
Mein Auto: 83' 318 I
Check the lift pump in the tank for proper operation too! Do you hear the fuel pump when pumping? Does it sound like bees in your fuel line? Thats a sure sign its on its way out!!
Old 09-04-2007, 07:55 AM
my pump sound a littel bit like a vacum leak, i think it is fine i will try the 02 sensor first if doesent work will come back to you guys. thanks for the input.
