E30 (1982 - 1993)
Old 09-01-2007, 11:33 AM
bmw325bug bmw325bug is offline
Mein Auto: 2003 325i, and 1988 325ix
temp question?
new to this site but love it so far...
On my 1988 325ix recently i have noticed that driving in stop and go traffic with a\c on the temp guage goes up about 3\4..it is not over heating but makes me nervous..any ideas? when i get back on highway it goes back down to about half..thanks for any suggestions
Old 09-01-2007, 12:48 PM
bluebimmerman's Avatar
bluebimmerman bluebimmerman is offline
Back in the action
Mein Auto: 88 325i conv.
Welcome welcome, How quick does the temp go up, also what does it do when you turn the ac off? Try the search button too(make sure your in the e30 forum first, then type in overheating). It's the best way to find quick answers to common problems. If you can't find it still then write back. Where in Jersey are you?
Old 09-01-2007, 08:43 PM
thank you..i am located in south jersey near cherry hill..little south..the temp goes up pretty quickly maybe on a ten to twenty min drive. it has yet to go over 3\4 but i do not want that to happen..I will try searching ...
Old 09-03-2007, 12:08 PM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05
Mein Auto: 1990 325i
my car does the same thing....if stuck in a traffic jam, the temp will go up, but only when the AC is on. I could be totally wrong, but I think it may have to do with your aux fan(fan you can see through the grill) not coming on at a low speed. I know that mine does not come on until the temp guage goes to almost 3/4 and even then it only stays on for a second, but the temp goes down a bit. When you are driving on the highway, this does not happen b/c all of the air coming through your grill is acting as the aux fan. From what I have read and searched, the aux fan should come on immediately when the AC is turned on. There are 2 speeds to the aux fan..low and high. If the fan does not come on when the AC is on, then it could be your low speed relay that is bad, but most likely it is the aux fan resistor that needs replacing....seems pretty common. Since your car does not heat up past the 3/4 mark, then I would assume that the high speed works. In my car you can hear the fan come on when the temp reaches 3/4. Again, I could be wrong, but it may be one thing you want to take a look at.
Old 09-04-2007, 07:56 AM
Back in the action
That was going to be my next recomendation...to check the fan. Cherry Hill, nice. My family is on Brigantine Island, and O.C. plus a few in Phily.
