E30 (1982 - 1993)
Old 09-02-2007, 10:55 PM
wpstriker89 wpstriker89 is offline
Mein Auto: '88 325ic
any suggestions?
Just wondering if anyone has some ideas of some cheap and easy suggestions for upgrades in my '88 325ic in terms of performance. Any help would be greatly appreciated
-jace
Old 09-03-2007, 03:40 AM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
A C.A.I. (Colad Air Intake) Would be a good, easy and cheap way to get some power and a hell of a lot of good noise !
Try NGK Irridium spark plugs, they wont exactly give you performance but will smooth the engine out and give you a smoother torque curve throughout the RPM range.
Current:
1994 318iS
Sold:
1993 E36 325i
1999 318i E46
Old 09-03-2007, 08:38 PM
I've been looking into finding a cold air intake, but the only problem is that i just can't seem to find an intake built for my specific model. I've found Carbon Dynamic Airbox, but so far my luck is running dry. Know of anything?
Old 09-04-2007, 07:02 AM
bluebimmerman's Avatar
bluebimmerman bluebimmerman is offline
Back in the action
Mein Auto: 88 325i conv.
Yeah, If you want a true CAI you are gonna have to make your own inlet piping and stuff. I looked for one too, and they only have ones with a heat shield for our cars, unless somebody knows of one...but all mine really does is give a great growling sound, not much a of a power increase, just a more responsive throtle
Old 09-04-2007, 10:58 AM
KCLARK's Avatar
KCLARK KCLARK is offline
Mein Auto: E30 325i Sport & E46 M3
before you get gung-ho on CAI's do a search on here and find out the true facts. cheapo cai's arent gonna get you nothing (no hp) but will give you nice engine humm. fact of the matter is, stock filteration housing and filter on M20's prevails. read up on it. you want a cheapo mod to pick up some horsey's just get a Mark D chip matched up with 17#or19# fuel injectors. This is probably the best bang for the buck mod to do for hp gains.
90 E30 325i Sport
02 E46 M3
Old 09-04-2007, 11:17 AM
Paul Christian Paul Christian is offline
Mein Auto: 87.325is
what is your buget?????
Old 09-04-2007, 12:21 PM
Back in the action
+1 Get a chip... but a markD chip and a new set of injectors aren't cheapo in my book, but it is one of the best bangs for the buck
Old 09-04-2007, 04:48 PM
budget? I'm shooting for $500-$600 hopefully so whatever will help the most then I'll look into that.
'88 325ic *light and quick!*
Old 09-04-2007, 05:04 PM
ok so i found a K&N intake that should fit my car at: http://www.knfilters.com/search/prod...x?Prod=57-0070
but it doesn't come with a heat shield. So i did a little bit more research, and was able to find a site that sold a heat shield:
http://www.signaturemotoring.com/Col...r%20Intake.htm
So the only problem i have now is that I'm not sure if i should stick with the cone intake with the heat shield, or get the Carbon Dynamic Airbox instead:
http://www.motormec.co.uk/cda.html#application
Any thoughts?
Old 09-04-2007, 07:08 PM
ok so i just purchased 19 LB 4 HOLE SPRAY TIP BOSCH INJECTORS today, and I'm now looking into buying a conforti performance chip. Anything else?
Old 09-04-2007, 08:06 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Yeah, skip the CAI and spend that money on flushing and refilling all your fluids and any other maintenance/tune-up items. The chip and injectors will do the trick - even more so if you swap in a M30 AFM (the K&N oiler-type filter is gonna gum up your AFM, btw). As KCLARK posted, stick with stock air filtration
I Timothy 2:1-2
Old 09-04-2007, 09:16 PM
does it not come stock with the M30 AFM? would the dynamic airbox do the same?
Old 09-04-2007, 09:30 PM
any bad reviews on the conforti chips?
Old 09-07-2007, 05:24 PM
einstein57 einstein57 is offline
Mein Auto: 1987 325is
that racing dynamics shield looks great. Stay away from metal heatshields. There is a reason the oem intake pieces are plastic and its not to reduce cost. i like the itg filters turner sells. Once i finish my CAD training i'll be making some killer ram air intakes and 3" maf's. They should be ready by 2010 lol.
i like the exhaust ie sells. you can also get them on ebay for about 320 shipped.
