Repairing Power Seat Switch-DIY - Bimmerfest - BMW Forums
Old 10-21-2006, 02:02 PM
Mister Chow's Avatar
Mister Chow Mister Chow is offline
Mein Auto: 1999 528i
Name:	Broken Seat Switch.JPG
So the switch for the power seat snapped off and I figured it was going to be a "cheap" fix with a new plastic stud from BMW. Well no, the little plastic stud is part of the whole switching control box and costs a bundle.
I tried to glue it back together but it was like building a ship inside a bottle so I decided to open'er'up and try to do a better fix.
First thing, remove the switch covers. They pull straight out. Don't twist!
You'll have to take the side trim panel of the seat off. This photo is looking from the driver's footwell. You need to pop out a plastic clip (that took a lot more force than I thought!) and undo a torx screw. There's another plastic clip on the back of the seat but it's possible to access everything without having to pop that one out.
Name:	Fastener location.JPG
The switching control box is clipped to the trim panel and is plugged into the actuators.
Name:	Behind panel.JPG
Disconnect the plug and unclip the control box.
Name:	Clip detail.JPG
And this is what it looks like. I took the picture after I fixed it so both studs are complete.
Name:	Switch Unit 1.JPG
Name:	Part Number.JPG
This is the toughest part of the job. To open the box up you have to flip open all 8 plastic clips simultaneously and pry the box open. Thankfully there's no glue. I used bits of cut up plastic to hold each clip open and then used a thin screwdriver to pry the box open.
Name:	End clips.JPG
Name:	Side Clips.JPG
Old 10-21-2006, 02:19 PM
Part II
After you have the cover off you still have to pry up the clips on the brass plate to expose the studs.
Backside.
Name:	Back opened 1.JPG
Backside without brass plate.
Name:	Back opened 2.JPG
This is what everything looks like taken apart.
Then it's a simple matter of using some crazy glue and fixing the broken stud.
I got a little cocky and though I would reinforce the stud by filling it up with urethane sealant.
Name:	Pair of Studs.JPG
Big mistake! The stud has to be hollow to fit back together. Thank god for Dremel tools.
Reassembly is a two minute job. Much much easier than the disassembly.
I used a dab of vasoline on the plastic to plastic parts to reduce friction and hopefully lesson any stress on those studs. I also switched the two studs (which are identical) so the repaired stud is on the less often used backrest adjustment.
Oh and one more thing. Your seat won't move if the control box is out, the seat memory buttons won't work. So either make sure your seat is in its proper position or plan not to use your car until the job is finished. It should only take a half hour or so plus the time it takes for the glue to dry.
Good luck!
Old 10-21-2006, 08:54 PM
lex89's Avatar
lex89 lex89 is offline
Send a message via AIM to lex89
Mein Auto: '99 528i
Very nice write-up. I wish you had posted this a couple months ago. I just paid $250 for the dealer to do the job. Good to know there's another way
Old 10-22-2006, 06:49 AM
Thanks.
It's kinda silly that the switch can't be fixed more easily. It's not an uncommon incident to kick the switch when entering the car in a tight parking spot and the $250 for a new switch is silly for a $0.50 piece of plastic.
Hope it helps next time!
Old 10-22-2006, 10:33 PM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
did you leave the rear clip in and just bend back the plastic cover to expose the switch?
Did everything re-assemble properly when going this route?
Any idea how to get that rear clip out if, say, you also wanted to replace the plastic cover?
z0lt3c
Current:
2013 Ford Edge SEL AWD
2012 Jeep Grand Cherokee Laredo 4x4
Retired:
95 e36 M3/5spd, 96 328is/5spd, 97 540iA, 98 528iA, 01 X5 4.4iA, 03 325xiA, 04 530iA, 02 330Cic/5spd, 08 535xit
Old 10-23-2006, 06:48 AM
The rear clip is hard to access unless you take the back of the seat off. I tried prying the seatback off a little and all I got was some loose change. Considering the front clip took so much force, I didn't want to risk breaking the cover. If you had a "Y" fork to remove those clips it would probably be a lot easier.
Besides, you can access the switch with only the front fasteners removed. I moved the seat up all the way to give better access.
The whole thing goes together super easy, no problem.
Old 09-13-2007, 07:19 PM
Peter330i's Avatar
Peter330i Peter330i is offline
Mein Auto: 2011 BMW 535i M Sport
Worked Like a Charm!
Awesome post...I kicked my fore/aft/up/down button off this evening as I was getting out of my 03 540 and it broke the peg inside the switch at the base. When I saw it was going to cost $250 to fix at the dealer, I did a search in this forum and found this post. Thank you for posting step-by-step pics...I'm not the handiest person in the world, yet with this guide, was able to repair my switch in about 45 minutes. Well done.
Old 09-13-2007, 08:13 PM
Thanks, I say spread the wealth (of knowledge.)
Coincidentally, I thought I might have to look this post up myself. The hotel valet returned my car with the switch cover knocked off this weekend. Luckily no intervention was necessary.
Old 09-13-2007, 11:49 PM
rogan rogan is offline
Mein Auto: E39 540, E46 318
I've got the same problem but don't have the plastic bit to glue back on. I was thinking of getting some rubber hose with an OD the same as the switch cover and an ID the same as the white plastic thingy. Hopefully it'll work
Old 09-14-2007, 06:15 AM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
put it together and add it to the FAQ please. good info!
americandan.com
It takes a lot of work to be lazy.
Old 09-14-2007, 06:22 AM
There's already a link to this thread but I'll do some cutting and pasting.
Old 09-14-2007, 07:08 AM
toi toi is offline
Mein Auto: 97 528i at
http://www.koperformance.com/
they have just the outer plastic part of that switch here for like 9 bucks.such a nice site to shop for parts like these.cheap too
Old 09-19-2007, 07:09 PM
Fixed mine now.
When I got the car I only had the white piece sticking out the side of the seat; no switch cover or piece of rubber covering.
Got the switch cover for about NZ$12 (so about US$9) from the local BMW dealer, then went into my local marine shop and got a piece of rubber tubing that just squeezed into the switch cover. Rubber is ~8mm outside diameter and ~5mm inside diameter. Cut to length and push fit. Cost of rubber hose NZ$1.
Works very well and takes a decent amount of force to pull the switch cover off. So total cost about US$10 and less than 30 seconds to cut rubber to length and fit. If you're intelligent enough to know how to breathe then you should be able to do it yourself. Only tool needed was a Stanley knife to cut the rubber to length
Old 02-09-2008, 08:00 PM
Pahhhoul's Avatar
Pahhhoul Pahhhoul is offline
Mein Auto: 2002 525i MT
HELP!
I attempted to do this DIY.
When I went to try and pry the control box open a bunch of springs and rods came flying out.
My control box looks completely different from the OP's.
Anyone have a diagram of how the springs and rods are supposed to be put back in?
I would have taken pictures but my both my digital cameras have been stolen within the past month!
Old 11-20-2012, 02:09 AM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Whoever starts making these things as aftermarket replacements will make a killing. If I could get a casting of one, with both outside and inside diameters accurate, I'd give it a shot myself.
Anyone willing to make a casting of this? I need these studs but find it ridiculous that I need to pay over $200 for an entire new switch.
Old 11-20-2012, 07:51 AM
I had not known about this thread - so I simply wish to cross link it to here:
> E39 (1997 - 2003) > Tips and suggestions for replacing destroyed E39 driver seat adjustment control panel
Old 11-20-2012, 01:12 PM
Ya know..... I wonder if those posts could be made out of aluminum?
Old 03-13-2013, 11:31 AM
Shader7 Shader7 is offline
Mein Auto: 2002 M5
3D printed Seat Switch Boss
First time posting - forgive me if my pics didn't upload right. I'm Chiming in late here (very late). As a long-time E39 M5 owner, I too managed to break my driver's side seat switch post boss (I kicked it getting out of the car one day). I followed this >great< thread and realized spending $250 to replace a tiny piece of plastic was ridiculous. Taking measurements from the broken bit stuck in the switch, and extrapolating the rest from images found here, I came up with the part below from an ABS 3D printer. It's a little rough and has marks from test fits in and out of the adjustment button (shown here broken as well, held together with an O-ring for testing until I can replace it). I may iterate it one time to make the fit even better but it clicks neatly into the button as-is and I expect that this first-run part will work very well. I'll fit it this weekend and report back.
ID:	366188   Click image for larger version
Name:	B and B.JPG
Old 04-19-2013, 10:47 AM
caryalon caryalon is offline
Mein Auto: 2002 530i, 2001 325i
Any update on this? Did the 3D printed version work?
Old 01-31-2015, 07:51 PM
plracing plracing is offline
Mein Auto: just bought 2005 z4
Question Just bought 2003 530i
New to 530i need to replace belts
Water pump, and idler, remained
Old 07-17-2016, 02:16 PM
Bimmer Fx Bimmer Fx is offline
Mein Auto: 92 BMW 735i
I know this thread is very old but I'm sure the problem still exists... I can easily manufacture these in a very durable resin that won't break and do it very inexpensively for anyone that needs them. I would need an original part and if someone is willing to ship one to me I could quickly make them. I would ship back the original and give you a few. I'm sure I could sell them for $10+ s&h priority mail.
I could also manufacture other small plastic parts that the Dealer wants crazy $$$ for and they are hard to get without going to the dealer...
Just PM me
Thanks...
Old 07-25-2016, 02:40 PM
Even though I would love to help the community out and manufacture small parts like these that are either overly expensive or hard to get, it dawned on me that I can't offer this service without being a sponsor...when I'm ready to become a sponsor I will be happy to help out.
Old 12-26-2016, 09:23 AM
stilldriving stilldriving is offline
Mein Auto:
Question on seat button repair
Originally Posted by Mister Chow View Post
Attachment 89039
Attachment 89040
Attachment 89041
Attachment 89042
Attachment 89043
Attachment 89044
Attachment 89045
Attachment 89046
Thanks for this Mister Chow.
I bought a new Switch but I don't have the post that you and so many have posted that have broken off. I have a brand new Switch button. Is there anywhere I can get the post or "sheath" (as others describe it)?
Secondly, if I can find it to purchase do I still have to go through the above-described procedure to mount the new seat button switch? Thanks again.
Old 12-26-2016, 09:26 AM
Mein Auto:
Attachment 89047
Backside.
Attachment 89048
Attachment 89049
Attachment 89050
Attachment 89051
Attachment 89052
Good luck!
When I bought my car the switch was missing. I have a brand new one. There are three prongs sticking out of the side of the seat. I am missing the stud or studs completely as they were not anywhere in the car when I bought it. Is there anyway to buy the studs? Secondly, do I still need to go through this whole procedure if I do find the missing studs?
Old 12-26-2016, 07:15 PM
Fudman's Avatar
Fudman Fudman is offline
If you look at the first picture in the original post, you will see a small white post. That is what is underneath the hollow black post. When mine broke, I simply removed the old black post, filled the switch hole with hot glue and pressed it onto the white post. Since I am the primary driver, the switch rarely gets touched. This repair is temporary and won't last forever, but is easily redone.
Similar Threads
E39 Front Black Leather Seats Swap 2-Tone Conversion in Tan Interior(PICS) SEAT4SALE e39breyton Interior 23 12-10-2010 08:33 PM
Aftermarket lumbar support options-- help me decide bmw325 3 Series & 4 Series 46 11-27-2003 10:53 PM
GM deathtraps Spiderm0n General BMW Questions 5 03-08-2002 01:57 PM
