HVAC blower question - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 10-20-2007, 05:35 PM
NHBimmer NHBimmer is offline
Mein Auto: 1988 E28 535i
Question HVAC blower question
We just picked up our '88 535i, and the blower doesn't function unless the A/C button is depressed. All the fan speeds work fine when the A/C is on, but nothing when just the heat is on. Does anyone have any idea what might be the cause of this?
Thanks in advance!
Old 11-05-2007, 02:27 PM
hugh1850's Avatar
hugh1850 hugh1850 is offline
Mein Auto: Jeep GC
Thanks in advance!
The heat will not come out of the dash vents. Only the defrost vents and the floor. Have you opened the floor vent with slide, and then switch the fan to position 1-2-3?
1987 BMW 535i, 2016 X5, 2015 Jeep GC Overland
Old 11-11-2007, 02:52 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Welcome to the wonderful world of the e28 featuring TWO fans! The one right above the shifter is for the A/C and when the heat is on the one below the wipers (accesible from the engine compartment) turns on. They are never both on at the same time. On this matter as Hugh1850 stated, cold or outside air only comes out of the center vents and heats only comes out of the top and bottom vents.
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
