Z3 passenger seat moves. - Bimmerfest - BMW Forums
Old 10-25-2007, 03:13 PM
NITO NITO is offline
BeamersRWayToEx$pe$ive
Mein Auto: 1999 BMW Z3 COUPE 2.8L
My passenger side seat slides back and forth slightly. All electronic controls work and its as if the seat is loose on the track. It will shift forward or back freely for about a half an inch. Not so bad if someone is sitting in it, but when I'm driving alone, I hear it move if I accelerate quickly or brake hard. I can grab the seat with my hand and just slightly move it back and forth without using the switches. Does not sound like the motors in the seat are being affected by the movement. Any ideas?
Old 10-25-2007, 03:23 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
Yes,
PM with your email address, I'll send you a detailed power point slide show on how I fixed it.
Old 10-25-2007, 06:25 PM
The Other Tom The Other Tom is offline
Mein Auto: 2008 335i
Your seat bushings are worn out. This is a common problem with Z3's. You need to get Doug Whalen's seat bushings and replace your old ones. It's a straighforward fix and EOD Guy's presentation will most likely show you how.
2017 i3 REx
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 10-25-2007, 06:32 PM
WileECoyote's Avatar
WileECoyote WileECoyote is offline
Needs more cowbell
Send a message via AIM to WileECoyote
Mein Auto: 1999 Z3 2.8, 2000 328Ci
If EOD's slides don't show ya, you can also check out Rachel's pages.
Old 10-26-2007, 06:53 AM
Pinball81 Pinball81 is offline
Mein Auto: 05 M3 ZCP, 98 M Rdstr
Originally Posted by EOD Guy View Post
Yes,
PM sent...
2013 E70 X5 35i SAV: Alpine White
2008 E90 M3: Alpine White - SOLD
2005 E46 M3 ZCP: Alpine White - SOLD
1998 M Roadster : Imola Red - SOLD
2003 540i/6 M-Sport : Titanium Silver - SOLD
Old 10-26-2007, 11:53 AM
You guys are the bestest!
Nice to know someone else shares my pain! Well, step one is to first go to dealer: I'm pretty sure my warranty will cover this. If not, I have the best resources to do it myself.
Thanx a million!
Old 10-26-2007, 12:19 PM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
If the dealer does it under warranty, they will just put more crummy rubber bushings in and you'll be in the same boat in another 15-20k miles. Even if you have to do it yourself, I think it's better to do it once and be done with it.
Old 10-26-2007, 01:40 PM
aclswsmith aclswsmith is offline
Mein Auto: bmw z3
bushings
I replaced both seat bushings for about fourty bucks. This is an easy fix. I noticed that another member is sending the instructions. Just follow each step, and you will be amazed at how easy this procedure is. I also fixed my glove box sag using the instuctions given by a member and also was an easy process knowing how.
Old 10-26-2007, 04:22 PM
+1
Also, the more you do, the more confident you are to do other things.
2017 i3 REx
2008 335i
2001 325i retired
Old 08-15-2008, 05:57 AM
lhs2miler lhs2miler is offline
Mein Auto: Z3 coupe
my glove box hangs down, and i noticed someone had the same problem. what's the solution?
Old 08-15-2008, 06:09 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
http://www.mz3.net/articles/253.html
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 08-15-2008, 06:16 AM
Needs more cowbell
There's a guy who's on the bimmerforums' Z3 board who sells them on ebay. Here's a link to it
Old 08-17-2008, 12:01 AM
KraigG KraigG is offline
Officially Welcomed to The 'Fest!
Mein Auto: 1997 Z3 2.8
Just did my glovebox fix with the same kit. Works beautifully!
The seat bushings also worked great, but were a little tougher to get in. That whole "bushings surrounding a block" was a little overengineered, IMHO. They could have done without the bad bushings, and just made the block larger.
Old 08-17-2008, 03:18 AM
///McQ ///McQ is offline
Addicted
Send a message via AIM to ///McQ Send a message via Yahoo to ///McQ
Mein Auto: 2000 M Roadster
I have the same problem. Can you PM the Powerpoint to me also?
Old 06-28-2009, 10:27 AM
sandiegodude sandiegodude is offline
Mein Auto: Roadster
I need to do the same....
Can I also get that PPT presentation? Will that tell me what parts I need to get? Thanks
Old 06-29-2009, 06:55 AM
Z3 Rick Z3 Rick is offline
Could I also get your PPT of how to fix the passenger seat? I appreciate it.
Old 06-29-2009, 03:57 PM
EOD Guy's Avatar
All I've been away for awhile, Did everyone get the ppt that wanted it? Thanks
Dave
Old 08-14-2009, 02:16 PM
ChuckECM ChuckECM is offline
Mein Auto: DINAN Z3, 2.8 '97
Can you email me the info?
www.emeider@ecmdesign.net
Thanks!
Old 06-14-2011, 06:28 PM
Charlie G Charlie G is offline
DirtMaster
Mein Auto: 1998 Z3
Z3 newbie
Greetings from a new owner. Just picked up a 1998 Z3 2.8L and am just dieing to spend the next few days just blowing my hair back. When we were test driving the car the passenger seat was noted to be moving approximately 1/2" (13 mm for you purists, but this car was made in SC so inch approximations should be fine). I had researched the forum before making the purchase commitment and noticed this.
Of the several Z3s that I drove the one I chose does have a slightly greater tendency to miss 3rd gear for 5th. Is there an easy detent spring replacement or other tidy fix? The rest of the car made this an easily tolerated issue.
Thanks, and it's good to be aboard.
Charlie G
Other vehicles are E30 track car, E39 wife car, F250 diesel tow pickup
Old 06-16-2011, 05:08 PM
BJA97Z3ROADSTER BJA97Z3ROADSTER is offline
Mein Auto: 97 Z3 Roadster
EOD...Can you also send me that slideshow on the seat please?
briadams@charter.net
Thanks in advance!
Old 06-16-2011, 07:36 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Ditto for me. Can you send the ppt to:
Dennis.canon@gmail.com
Appreciate it.
Sent from Samsung Tab using Bimmer app
Old 06-17-2011, 07:14 AM
Needs more cowbell
In case EOD doesn't email ya
Old 06-26-2011, 04:35 AM
mr. slate mr. slate is offline
Tom
I also completed Doug Whalen's retrofit for the bushings. The fix is straight forward and can be done by a novice in a few hours. Pay attention to the details of the instructions provided. The difference is night and day once the replacement bushings are installed.
Currently own:
2001 530i slate green
1997 Z3 atlanta blue
Formerly owned:
1983 Jeep CJ7
1986 Porsche 911
Old 06-26-2011, 08:07 AM
Steamer's Avatar
Steamer Steamer is offline
Mein Auto: 2011 550i, 00 M Roadster
+1
Old 06-26-2011, 12:53 PM
droz3 droz3 is offline
DROZ3
Mein Auto: 2001 Z3 / 2006 X3
When re-installing the seats it is a good preventive maintenance item to clean the contacts in the seat electrical plug (1 per seat) with some electrical contact cleaner (like Deoxit contact cleaner).
Some Z3 owner's have had their SRS light light-up because of faulty contact in these seat electrical plug.
Z3 2001 3.0L 5-speeds,Topaz Blue/Sport+Premium package/Stong-Strut/Bilstein shocks/Rogue Engineering RSM/Ireland Engineering rear sub-frame bushing/CDV delete/Conforti CAI/Jim Conforti Shark/DRL module/European Wiper Module/Pioneer AVIC-N4 GPS-Receiver+XM Radio+iPod/iPhone interface+Bluetooth+12CD Charger/ASA-AR1 18" wheels+Michelin PSS/Bi-Xenon upgrade.
Latest mod : 3.73 diff. ... WOW
X3 2006 3.0L Automatic, Silver Gray, all original ... so far ...
