E36 (1991 - 1999)
Old 10-30-2007, 12:56 PM
enriquecere enriquecere is offline
Mein Auto: E36 318
Question The Million Dollar Question
Hi, this is for anyone who can help me to solve the problems whit my Bimmer.
I have a 318i '95 and I cant start it, I already change many parts and the problem continues. I hope anyone know what happened:
I already changed the following parts:
-MAF SENSOR
-O2 SENSOR
-TPS (trottle position sensor)
-Engine Temp. sensor
-Coolant Temp. sensor
-Fuel Filter
-Air filter
-IDLE valve
-Ignition coil
-Wire set of spark plugs
-Spark plugs
-New battery
The currently diagnose is as follow.
The Engine starts or try to start:
Idle fails
The sparks becomes wet
The injectors are cleaned and working
So the mmillion Dollar Question is
What could my car have? or What could be wrong with my car?
Old 10-30-2007, 01:07 PM
Andycapps's Avatar
Andycapps Andycapps is offline
Mein Auto: 94 BMW 325is
Is the CEL on or was it on before? Could be crank sensor, cam sensor..
Old 10-30-2007, 10:50 PM
jtagle jtagle is offline
Mein Auto: E36 325IS
Spark plugs are wet with oil or water/coolant?
Oil, valve seal or rings.
Water/cooland, cylinder gasket leaking. Try getting radiator pressure test unit. The radiator pressure should hold when pressurized. If it drops, they you have a leak.
I had a pin hole lead on my cyclinder head gasket. Idle start rough during start and eventually improves after a while. try it.
Old 10-30-2007, 11:28 PM
Andycapps's Avatar
If the spark plugs are wet, its probably just gas. If the ignition system isnt working, you're gonna still be injecting gas into the engine as you try to start the car(flooding the engine)
Old 10-31-2007, 06:25 AM
jasonf860's Avatar
jasonf860 jasonf860 is offline
M status achieved!
Mein Auto: 94 325i, 98 Protege
Your DME is fried.
Old 10-31-2007, 10:36 AM
Andycapps's Avatar
Before you jump to the conlusion that the actual DME is fried..What about the DME relay?
Old 10-31-2007, 08:30 PM
slavka slavka is offline
Mein Auto: 1999 BMW 328is
Sound like Crank sensor.
Old 11-03-2007, 04:00 PM
Andycapps's Avatar
Have you fixed the problem yet? I'm curious to know what it was, so let us know.
