2000 328i how to change turn signal bulbs??
Hello,
I am new here..I have a 2000 328i and both of my turn signal bulbs need to be replaced..But, I cannot make any sense of the instructions in the manual. Can anyone help me??? Thanks. |
Go to www.my330i.com, click on garage, and then find his clear corner installation on his pre-facelift sedan. You'll see pictoral instructions on removing the turn signals to get the bulb out.
How to get to the turn signal bulbs????
RDW |
Step 1 is to pull the entire turn signal lens assembly out of the car. Step 2 is to pull the bulb out of the turn signal lens assembly to change it. For detailed instructions on step 1, follow the link I provided above. It involves pushing a screwdriver down to release a tab. |
Thanks, Kris, I printed the pics and will try again this evening. Even though I am a woman I am pretty good at this kind of stuff...changed all of my other bulbs, but these turn signal bulbs have got me..changing them won't be a problem..getting to the darn things is. I appreicate your help.
The key to figuring it out is persistence. It can be challenging to figure out the first time you do it. And getting it done can be challenging even after you finally figure it out. Sometimes actually finding the tab and getting it to give takes a fair dose of patience.
Just keep at it. Good luck. If you can't get it, you'll just have to go buy a facelifted model 3er. They made it easier with the facelift.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! Last edited by tturedraider; 01-28-2008 at 04:39 PM. |
Unless it's a coupe. You need child sized hands to get at them!
Jeff R. Golden Gate Chapter BMW CCA - Autocross - Come Join Us! ![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
Replacing Front Turn Signal Bulb
There are at least two versions for the late '99 production: one that requires pushing down on a tab and one that requires levering a screwdriver away from you to push the lens out, so do NOT push down on anything to release the lens until you're certain which version you have. The owners manual is basically useless, as it simply says "release the lever" but doesn't tell you how. I can only describe my version: Looking through the oval hole, the first thing you'll see is a black flat piece of plastic. Do NOT push down on this or the silver-colored prong sticking out from it. Look a bit deeper and you'll notice a white tab, no more than 3" deep, so you don't need a long screwdriver. You just need to get the screwdriver behind the tab and push it away from you, thus causing the end of the screwdriver to push the lens out. It doesn't take a lot of force, so if it's not budging, you're behind the wrong tab. After it pops out, simply turn the receptacle and then the bulb to replace it. To reinstall, line up the prongs into the slots and push in until it clicks. (With all due respect, if you're giving advice, first be sure that it's correct).
^^^ You picked a five year old thread to bump with your first post? Hookay.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
And you picked a perfectly valid, informative post to ridicule?
I'll be neither popular nor unpopular as I actually have a life that doesn't require
10,000+ posts on a site filled with so much misinformation. I have much better sources. |
