Old 01-27-2008, 09:36 PM
jfive96 jfive96 is offline
Connections Etc.
Send a message via MSN to jfive96 Send a message via Yahoo to jfive96
Mein Auto: 1998 528i
Thumbs up - -CCV(Crankcase/Oil Seperator Fixed!!! w/Pics!!!- -
- -Well today I tackled the common CCV (Crankcase Vent/Oil separator) problem. My problem was a very loud intake leak sound and once I placed my finger over the side port on the CCV, the leak went away as best my finger could make it do. Also motor would shack back and forth, lighting in and outside the car would dance to the misfire that the CCV was causing among other things.
Here is the new unit: , , , .Here is a view from the front of the car of the old unit , .
Just before I started this I asked myself could the CCV be replaced without taking the intake manifold off. The answer is YES It can be replaced with out taking the intak manifolid off. Here are the intake manifold gaskets I bought a while back thinking that they were the problem .
On to surgery, first I started with removing the air box from the fender to the throttle body .
Once the tubing is removed you can see the 3 bolts that hold the CCV in place on the bracket .
As you can see
the three bolts are easy to get to. They are 10mm. After disconnecting a couple of pigtails and moving a few lines out of the way for clearance the CCV came out without much fuss , , . Once the old CCV was out, I took these picks to show them both , ,
the CCV on the left is the new one and the one on the right is the old one. After that itís just a matter of doing the reverse and making sure you reconnect any lines or pigtails that were disconnected. This is a go time to check all hoses and cables while most of the big boxy items are out of the way. Also check the hose coming from the bottom of the CCV to the oil dipstick to tube. After a while the rubber becomes spongy from the heat build up and if you look inside you can see that the inside of the hose is starting to deteriorate. So it would be best to change it at this time. Here she is all buttoned up back to normal . I was curious to see what the old looked like inside and out, so I took it apart and snapped some shots. I hope this helps anyone out there whom may have the problem I had with a bad CCV(Crankcase/Oil separator). I have more photos and info if anyone needs it. My car now runs and ideals MUCH, MUCH better. When I get to work tomorrow I will have the check engine light cleared and wait to see if it will come back on. I have yet to drive it since the work has been done. Going to fill her up before I go to bed just thought I would go ahead and right this up first. I still hear a very faint air sucking sound but it could just be me and my superman hearing when it comes to this car. Iíll get a second option from one of our techs tomorrow and see if Iím just hearing things. Just a side note, while the CCV was bad I did smell the fuems in the cabin from time to time and my OBC said my gas MPG were 20.9. I thought that was very strange, so Iím going to reset the MPG and the MPH gauges and see wha I get after a few tanks. Here are the pics of the old CCV in its nakedness enjoy. , , , , , , , , , , .
If I missed anything let me know. Here is the link to a thread that helped me out http://www.bimmerfest.com/forums/sho...d.php?t=214052. Thank you. Peace.
[SIGPIC][/SIGPIC]* *Guns Don't Kill People, Crazy Mutherf*%$ers Like Me Kill Theives!!!!!!* *
"Connections Etc." I got what you need! Get at me!!!
I'm Rich B@*#$h!!!!
Old 01-27-2008, 10:13 PM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
Thanks for posting. Think I will be tackling this soon.
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 01-27-2008, 10:16 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
be nice if you added this to the FAQ or the DIY post
americandan.com
It takes a lot of work to be lazy.
Old 01-27-2008, 10:32 PM
Connections Etc.
Wink - -It would wouldn't- -
- -Going to add somethings to this so DIY section to come.- -
I'm Rich B@*#$h!!!!
Old 01-27-2008, 10:33 PM
Connections Etc.
Cool - -Yup- -
- -No problem. Glad to help. I love the E39.- -
I'm Rich B@*#$h!!!!
Old 01-27-2008, 11:18 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
Excellent and well document, thanks! Great to see these DIY posts and folks like yourself sharing your knowledge.
Old 01-28-2008, 01:14 AM
Connections Etc.
Cool - -Got Props Yo- -
- -Thanks for the props. I hope this nfo can help someone.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 05:38 AM
tractordave tractordave is offline
Mein Auto: 523i se
how did you know it was broken whats the symptoms apart from the sucking noise does it miss when its warm or is worse when cold mine is fine when cold but misses etc when hot
Old 01-28-2008, 07:19 AM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: '00 BMW 540i; '11 BMW X5
Were the vibration issues you mentioned occur when it was cold out in the morning only? did you have constant idle problems....even in warm temps?
Old 01-28-2008, 01:24 PM
Connections Etc.
Cool - -I Got The Shakes- -
- -The vibration was in cold weather and in the morning. I did how ever notice on warm days it was not as bad. I could be at a red light and with my foot on the brake it would shake pretty good. The idle was pretty consistant for the most part, say If was going from light to light about 3 blocks apart. Once I would get to the light, thr RPM hand would fall all the way down to zero and sit there. The motor would shake hard and the after a few seconds the hand would raise to about 300-500 RPM. There were times that the car would just die all together. One more thing, the leak at the CCV was so bad that after I found it and placed my finger over the vent port the motor ran fine then once I let go it died. All is will now though, the CEL light went off on its own after about 3-5 cycles of starting the motor. I hope this helps. Peace.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 02:09 PM
Al's540i's Avatar
Yes this does help, I'll look at this over the weekend. Does my 540i have a CCV also?
Old 01-28-2008, 02:52 PM
razzy530's Avatar
razzy530 razzy530 is offline
Send a message via Yahoo to razzy530
Mein Auto: 2007 530i 6 Speed
Now can you come over and do this to my 2002 530i ?? Oh wait, maybe i can have the dealer take care of this under CPo Warranty? What do you think?
2013 F30 335i M-Sport (RWD)
2007 E60 530i 6 Speed (RWD)
2002 E39 530i Retired
BMWCCA MEMBER #397411
Old 01-28-2008, 03:43 PM
dmako's Avatar
dmako dmako is offline
Mein Auto: 1999 528i
Thanks very much!!
I'll be replace mine this spring as I get the cold weather whine. Did you have to replace any hoses?
1999 BMW 528i sports pkg. 5-speed, rear lip spoiler, removed phone, Aspheric mirror, new M5 dead pedal, home made clutch stop, removed intake muffler, clear side and rear lights, Nein CDV, full cooling system overall, Beisan VANOS seals.
Best mod to date: removed seat clip.
Old 01-28-2008, 04:42 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Good work.
Two questions.
First, did you replace the grommet that goes into the intake manifold and into which the CCV fits?
Second, you didn't mention the hose that goes from the bottom of the CCV to the dipstick housing. DId you just remove that tube or did you remove the dispstick assembly?
Old 01-28-2008, 04:59 PM
Connections Etc.
Cool - -No Lies- -
- -Not really sure about the 540 models.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 05:07 PM
Connections Etc.
Cool - -Payment- -
- -Beer and food is all I need!. If it is covered under warrenty have the dealer do it for you so you can get your money worth.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 05:15 PM
Connections Etc.
Cool - -1 Hose- -
Originally Posted by dmako View Post
Thanks very much!!
- -The only hose I wanted to replace was the hose coming from the bottom of the CCV to the dipstick tube. It is 10 years old and just didn't "feel" that great. Plus the end at the dipstick tube was hard to come off without a lot of work on my part and I didn't want to risk damage to anythng with it being Sunday. I will replace that hose once I go CAI. Other than that hose non needed replacing.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 05:24 PM
Connections Etc.
Cool - -Nope- -
Originally Posted by Steve530 View Post
Good work.
Two questions.
- -I didn't replace the grommet, it looked real good. No cracks and held the old CCV in place after I removed the 3 bolts very well. I would suggest that you inspect that hose and replace it if it is collasped or soft to the touch. You will have to take a pair of good pliers and work the hose off the end of the CCV first then off the dipstick tube. You do not have to remove the dipstick tube.- -
I'm Rich B@*#$h!!!!
Old 01-28-2008, 05:31 PM
I replaced the CCV on my son's '98 323is a few weeks ago. It was the same part number as your CCV. Removal was similar. I managed to reach down to the dispstick assembly and pull the hose off the dipstick, then I just remove it with the CCV. I did replace the grommet, 13 41 1 733 217. It probably is not necessary, but I figure it's just a $2 part and I would want to do it over for that.
BTW, the 530 CCV is entirely different. And the 540i does have a CCV, but it, too, is different.
Old 01-30-2008, 05:26 PM
razzy530's Avatar
yes. I looked on OEMBIMMERPARTS.COM and it is totally different from the 'earlier' models. Im going to have my dealer replace it before my CPO runs out in March
Old 01-30-2008, 05:41 PM
I was hoping you'd DIY it and blaze a path for us 530 owners.
Old 01-30-2008, 06:09 PM
razzy530's Avatar
OK, how about this..... I will go to the dealer's shop, and take pics along the way as the tech replaces the CVV?
Just kidding, they wont let me do that
Old 01-30-2008, 06:35 PM
barbers528's Avatar
barbers528 barbers528 is offline
Trying to figure it out.
Send a message via AIM to barbers528
Mein Auto: 1997 528i
Good write up. I had mine done last march and what a difference it made. Thanks for sharing...
Christ gave his life. Why should I give Him anything less.
Old 01-30-2008, 06:40 PM
Ryan M Ryan M is offline
Mein Auto: .
yes, it does. It looks slightly different though. Open your hood and look between the firewall and intake manifold. The CCV is on the back of the motor with the brake booster line and some vacuum lines coming out. It's an easy DIY.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 01-30-2008, 07:05 PM
razzy530's Avatar
ok, what about on a 2002 530i? where is it located?
