Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 06-08-2006, 07:16 PM
Jon Shafer's Avatar
Admin • Owner • Enthusiast
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Thumbs up E30 Resource Thread
The most important and relevant questions and helpful information pertaining to the maintenance, restoration, or modification of the beloved E30 BMW 3 Series gets posted here.
Please chime in.
Edit:
This thread consists of:
The official Bimmerfest E30 FAQ thread
E30 DIY Links
Sources of Vacuum Leaks
E30 Owners Manual
http://jon.bimmerfest.com/bulletins/e30_manual.pdf
(to download, right click then "Save As")
Please note: Requires Adobe Acrobat Reader to view.
Please also allow ample time for this 8MB file to download...
Last edited by markseven; 02-05-2012 at 07:56 AM. Reason: Added Owner's Manual link
Old 06-08-2006, 10:05 PM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Please chime in.
Thanks Jon I've noticed we have added a few new members and we seem to be answering ALOT of the same questions over and over again so I asked Jon to give us a sticky for our MOST commonly asked questions (Timing belt DIY,SI batteries). This is long overdue and hopefully will help tone down the amount of threads being posted that are cluttering our board. In the next few days I will be digging up some of the DIY's I have written and posting links here. If you know of a DIY or tip feel free to post them here.
For ABS Light info: http://www.bimmerfest.com/forums/sho...d.php?t=148911
Cluster issues unrelated to SI's:http://www.bimmerfest.com/forums/sho...d.php?t=123222 http://www.bimmerfest.com/forums/sho...d.php?t=123934
Old 06-09-2006, 02:49 PM
SWISS's Avatar
On Top
Timing belts are found on all variations of the M20 engine. It is Very important to change these around every 50k miles or 2 years. It is also recomended that the waterpump be changed at the same time for 2 reasons.#1.) The life of one is about the same as the service interval for the belt(oddly enough). #2.) It's alot easier to do it when you're already changing the belt and have the covers removed.
Here is a link to a DIY with tons of pictures and good advice on changing a T\belt on an M20. http://www.bmwe34.net/e34main/Mainte.../M20Timing.asp
Old 06-09-2006, 03:06 PM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
318is suspension rebuild
These are prices and part numbers from a complete rebuild I did to my one of my previous e30 318is. I'm pretty sure we replaced/upgraded all the bushings and almost all of the supension. This was almost two years ago, so prices may have changed.
Oh, and some pics too:
e30 suspension install
UUC Evo 3 short shifter kit. Bought a new one on ebay for about $180. Huge improvement in positive feeling of engagement.
4.10 LSD. Bought a 325 full size case off ebay for $300. Replaced the small case 4.10 open diff on my 318. Bolted right up.
OEM control arms from Turner Motorsport. PN 31121127725 (L) and 31121127726 (R), $89/ea.
Offset control arm bushings from Turner Motorsport. PN 31129061222, $99.95/pr. Also offset strut mounts from Turner.
Bilstein sports, H&R springs, offset strut mounts, JTD rear shock mounts, Racing Dynamics strut brace, bought used for $500 from a local autocrosser.
Tie rod assemblies from Turner Motorsport. PN 32111125186, $120/pr. Don't forget to order securing plates, BMW PN 32111124540 a whopping $.30/ea.
Front wheel bearing assemblies from Turner Motorsport, PN 31211131297, $140/pr. Don't forget collar nuts ($5/ea BMW PN 31211125826).
H&R Sways (22mm fr, 18mm rear, adjustables) from Turner Motorsport. PN TMSSWAYE30, $319.95.
Adjustable front sway link from Ireland Engineering. Can't locate the PN, but I believe it was about $80.
Urethane motor mounts from Ireland Engineering. PN e30mm318, $98/pr.
Urethane tranny mounts from Ireland Engineering. PN urethanetrans, $80/pr.
Front subframe reinforcement kit from Turner Motorsports. (requires welding), PN RE1777/8, $34.95.
Guibo (flex disc) from Turner Motorsports. PN 26112225624, $39.95.
Driveshaft center support bearing assembly from Turner Motorsports. BMW PN 26121226723, about $60.
Rear subframe bushings (street, not race) from Ireland Engineering, PN e30urethanerear, $80/pr.
Urethane rear trailer arm bushing kit from Ireland Engineering, PN 02REARBUSH, $52.
Rear swaybar bushing reinforcement kit from Turner Motorsports. PN RE1956, $124.95. Take the extra step and through bolt this to the mount, rather than reusing the stock tapping screw.
Brake kit from Turner Motorsports, including front and rear rotors, Metalmaster pads, ATE super blue fluid and stainless steel brakelines. PN E30BRAKEPACK, $299.95.
I think that about does it. Quick notes: this set up appears to have given me about 2.5 degrees of negative camber. Use stock motor and tranny mounts unless you're willing to accept some vibration. And find someone who has a lift.....
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 06-10-2006, 10:25 AM
mattdk318i's Avatar
mattdk318i mattdk318i is offline
another E30 nut
Send a message via AIM to mattdk318i Send a message via MSN to mattdk318i Send a message via Yahoo to mattdk318i
Mein Auto: 91 318i and 90 Cabrio
Im going to try to address a question we get about once a week. Vibration under the Console. Theres one of many cluprits but this is the most common. The Guibo or Flex Disk can lose parts of the rubber between The bolt holes. Im restoring a Cabrio and when i first crawled under the car i noticed that mine needed to be replaced. Heres some pictures that will maybe help. It also smooths out the power transmission to the wheels. Its pretty straight foward. You need a 17mm wrench and socket. Please watch your knuckles. There is alot of unforgiving sheetmetal under these cars.
The Lack of rubber explains why you get an unbalanced vibration.
No where else id rather be
Old 06-12-2006, 03:20 PM
mattdk318i's Avatar
another E30 nut
Delphini asked about a 5 speed swap. Ive done countless hours of research on this swap over the past few months . I just always had my little 318 with the 5spd. But my 325is wasnt. Now that i have my cabrio theres no choice im going 5 speed. So heres a list of what you will need.
5 speed transmission 100$ (junkyard)
Driveshaft for a 5 speed 25$(junkyard)
brake and clutch pedal 20$ (junkyard)
gear shifter and mechanisms 20$ (junkyard) perfect time to get shortshift kit
shift knob ($?depends on preference)
brake fluid resivoir 20$ (junkyard)Most have clippable nipple on the right front side So a replacement might not be needed.
clutch kit 239$(always new)
shift boot 11$
new guibo 40$
new transmission mounts 30$
transmission support (metal part) from 325i or E 15$ (junkyard)
If you have owned your car long enough you will know what all of this is. If you have no idea how to even start. I recommend owning your car a little longer and researching This list will help you get up a price list if nothing else. I located a local junkyard over the phone and got this list. My recommendation is to find a complete 5 speed e30 in a junkyard and remove all of the components. Make sure it doesnt have like 240K
The automatic transmission has a switch on the shifter. If its not in Park it wont start. So you have to remove that switch and hardwire it. I have heard rumor of the cruise control acting up when a swap is done. I guess ill have to find out and let you guys know
Old 06-14-2006, 07:02 PM
mrdell4150's Avatar
mrdell4150 mrdell4150 is offline
Mein Auto: 1986 BMW 325ES
Here is my guide to an aftermarket radio install:
http://the3rdline.obproject.com/marc/BMW/radio.doc
1986 BMW 325ES
Old 07-04-2006, 11:31 AM
325ic a beer's Avatar
325ic a beer 325ic a beer is offline
World Traveller Forever
Mein Auto: 1992 BMW 325ic M Technic
If you are overheating after a coolant change..
You probably have an AIR BUBBLE in the system.
I have my patented method to remedy this:
Make sure that the coolant level is topped up just a bit overfilled.
Get a set of 6 to 8 inch ramps. Drive up onto them. With a cool engine, start the engine in neutral. Make sure the hood is open. Crack the air-bleeder screw and let the engine come up to temp. You will all of a sudden see coolant and air start to bubble out once the thermostat opens. Let it keep bubbling until you see no more air bubbles mixed in with the coolant. Now close air-bleeder screw tightly.
This nose- in- the- air attitude make the air bubble slide up and out the front of the head and engine allowing the coolant to completely maintain contact with the hot metal instead of air.
Thats a good thing.
If you do this proceedure on a flat surface..... you'll keep your air bubbles trapped.
Not a good thing.
325ic a beer
"Swimming with the sharks" All over this World...I'll see you in the next one.,,yeahhhh.... AND DON"T BE LATE,,,, DON"T BE LAAATTEE!
Old 09-24-2006, 06:52 AM
SWISS's Avatar
On Top
Rack rebuild
Courtesy of Shane aka Beemer X.
Name:	Power Steering 1.jpg
ID:	86500   Click image for larger version
Name:	Power Steering 2.jpg
Old 10-01-2007, 06:42 PM
mattdk318i's Avatar
another E30 nut
Someone needs to add something to this thread. Its been a Year!!
Old 11-12-2007, 04:49 PM
stategorgeous stategorgeous is offline
Mein Auto: BMW 325i
What common procedures/parts need addressing?
Old 11-12-2007, 04:53 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
For you, Timing belt would be a major priority.
Fuel filter
rear shock mounts
Old 12-04-2007, 09:12 AM
The Barvarian The Barvarian is offline
Mein Auto: 2003 325iT
Looking for e30 HP #'s by model and year.....
Old 01-20-2008, 09:25 PM
my 87 325m-tech my 87 325m-tech is offline
Mein Auto: 89 325is
you should add wheel and tire info!
Old 01-22-2008, 09:59 AM
HarryN HarryN is offline
Mein Auto: 1989 325IX
Perhaps some info on sensors and symptoms:
- crank angle sensor
- mass flow intake sensor
Old 03-04-2008, 08:29 PM
turdlecharge's Avatar
turdlecharge turdlecharge is offline
Mein Auto: 89 325is
i think it might be helpful to throw in a sticky for possible vac leaks... maybe it will alleviate some questions
2 good ones i found were
1. o rings on the oil dipstick
2. clutch master cylinder hose off brake master cylinder leaking
has anyone figured out how to make the elbow that goes into the intake from IACV not leak? im thinkn rtv or possibly tappn it and threading it for a brass elbow!
Old 03-04-2008, 08:32 PM
downhiller's Avatar
livin large
another good one is the valve cover gasket. had that on my midget, took me about a week to figure that one out.
Old 03-04-2008, 10:49 PM
SWISS's Avatar
On Top
JB weld those elbows back into the intake.
Other notorious ones are the oil drain back tube seal, hose fittings on the throttle body, injectors not seated, valve cover.
Old 03-05-2008, 04:40 AM
oldtimer oldtimer is offline
Mein Auto: 2005 Z4, 07 Road King Cla
What indication did you guys experience that prompted you to check for leak. Better yet: if the valve cover seal is leaking what indication one can experience. Here's my situation. I replace the TPS and clean the ICV. the engine light still comes on off and on and a steady light. The idles when I come to stop light or sign then it will flactuate. I can tell the ICV is working and is clean because when you first start the car the rpm will be high for a second or two then it drops to proper rpm. Also, when the car is idling and flactuates then pull the tube from the valve cover. the front tube idle will be smooth but high. Can someone tell me what that indicates aside from idling high.
Old 03-05-2008, 05:21 PM
downhiller's Avatar
livin large
i found mine by mistake, sort of. i had a leaking valve cover gasket, and when i pulled the cover there was a small gap to where the crankcase pressure was released. and after i replaced that, it ran decent until the head gasket went. after i replaced that i have the same syptoms. but as SWISS stated "the oil drain back tube" might be leaking on mine. i kinda found the o-ring on the ground after i put everything back on. and i didnt want to takle that one for a bit.
Old 03-05-2008, 08:20 PM
SWISS's Avatar
On Top
Another spot is the oil cap. Pretty much you need to rev your engine and listen for the hiss. My indication that I had a leak came in the form of poor idle and the infamous 1222 CEL code. Idle I discovered was part vacuum leak but more Bosch plat +4 plugs, M20's don't like them. the other was a O ring I forgot on the oil drain back tube when I did the head. And boy is that fun to do without removing the intake....
Old 03-05-2008, 08:46 PM
Thrax Thrax is offline
Mein Auto: 1991 325i E30
+ 2 on Swiss and Downhiller but come on Swiss. JB weld... I thought you were better than that... Replace, reduce, recycle. Sell your old parts on E-bay and buy new to make up the difference.
Old 03-06-2008, 03:57 AM
The last time the valve cover was off the engine was when I painted it but that was a year ago. It was idling normal my idle problem did not start until just recently. I plan on taking the intake off in the near future to combat those vacuum line. I am going to replace them with steal line with as little rubber tube coupling them together to eliminate the worry of any vacuum leak coming from there and of course the hassel of removing the intake just to get the line.
I will investigate the oil filler cap idea.
Old 03-29-2008, 07:11 PM
blubimmer blubimmer is offline
Mein Auto: 1985 318i BMW
another one
well here is one i found today...got me a can of carb cleaner and sprayed around like everyone else has done before...i was getting the same symtoms idle fluctuates when in neutral...like i said started spraying around the engine looking for that vacuum leak and just could not find anything at all the vacuum lines that i could see....then just for the sake of it...i sprayed at the bottom of the fuel injectors and lo and behold i had a reaction...found out that the o rings on my fuel injectors were deterioted and was leaking there...changed the o rings and finally got to adjust and time the engine so that it did on rev up and down...hope this help some one out too...
Old 03-30-2008, 12:28 PM
Mike_Check Mike_Check is offline
Account close at users request
Mein Auto: .
I thought this was a sticky...not a q/a forum...
bmw diy, bmw do it yourself, e30 diy, e30 do it yourself, m50 e30
Similar Threads
The official "alee sucks thread" sucks thread nate Off-Topic 22 06-03-2004 03:37 PM
Official Count @ Bimmerfest? manik///m3 General BMW 3 04-22-2002 02:23 PM
official party hotel for bimmerfest ???? jAb General BMW 5 04-18-2002 04:26 PM
It's official, Bimmerfest is no longer utopia Spiderm0n Off-Topic 32 04-17-2002 06:06 PM
