E36 (1991 - 1999)
Old 03-05-2008, 01:58 PM
miamikk miamikk is offline
Mein Auto: 1996 328iS
Oil leak under the car
Yesterday I noticed an oil leak under the car. I have never seen any dripped on the gound. The oil has dripped on to some parts. I am attaching couple of pictures.
Its on the front driver side under engine.
How do I locate the leak source ?
Any help would be appreciated.
ID:	138000   Click image for larger version
ID:	138001   Click image for larger version
ID:	138002   Click image for larger version
ID:	138003   Click image for larger version
Old 03-05-2008, 03:04 PM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
you should start off by getting under there and clean everything you can. spotless. get some degreaser, spray it on there, and rinse it off. then drive around for a day or two then get back under and check.
personally, looks like a powersteering hose issue
Old 03-07-2008, 12:00 AM
blurin03 blurin03 is offline
Mein Auto: '97 328is, GMC, Ducati
I also say power steering. The two rubber hoses from under the reservoir. They are known to leak after 6-7 years.
Old 03-07-2008, 10:51 AM
estoril blu estoril blu is offline
Mein Auto: e36 323 convertable
id say power steering too degrease and jet wash all the crap off but most certainly the power steer hoses check fluid level common leak on these
Old 03-07-2008, 04:20 PM
im im is offline
Mein Auto: bmw325i /318ic
really hard to see with all the crude...clean with degreaser and rinse+ wipe with rag and repeat...do not do it on lawn or drive-way..will kill lawn and stain drive-way..do it on street...pictures are of power steering area....loose cap or bad hose or clamps.. have friend turn wheel at full lock and hold...and look for leaks?
Old 03-08-2008, 07:06 PM
vwvannut vwvannut is offline
Send a message via AIM to vwvannut
Mein Auto: 1992 325i
if it makes you feel any better, the bottom of your engine looks ten times better than mine.
