E36 (1991 - 1999)
Old 03-05-2008, 06:23 PM
DesirexToxFire DesirexToxFire is offline
Mein Auto: BMW E36 320i 4dr Saloon
Power steering whine anyone?
Hello!
Every now and then the power steering seems to whine and when you rev the whine goes with it if you know what I mean (gets louder and higher). Usually happens when the cars relatively cold when your parking or something. Any ideas what this might be if it's a fault or is it a common thing>?
Cheers,
Paul
P.s Car is 1994 E36 320i 4dr Saloon 142k
Old 03-06-2008, 03:45 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hi
Have you checked your power steering fluid level? may need flushing
2001 Mini Cooper R50
Edirty6 for life
Old 03-06-2008, 04:48 AM
Chris S Chris S is offline
Mein Auto: 1997 323i
mine wines when the wheel is in full lock... so im hoping that its normal... and im guessing the loudness in whining is getting louder due to increased speed?
better awsk someone more knowledgeable in here tho
Old 03-06-2008, 08:19 AM
Chad Haines Chad Haines is offline
still pushin' big wheels
Mein Auto: '95 325i
check your fluid level. When mine was whining really bad I just chalked it up to a cold engine until it happened several times. Turned out I had a leak in my hose and couldn't keep fluid in - if I had waited any longer it could've burned out my pump.
Why does everyone think they are smarter than generations of German engineers?
Old 03-06-2008, 09:40 AM
fumiyasu fumiyasu is offline
Mein Auto: E38 740i
I am having that too. Seems to be common for the clip under the steering fluid reservoir to fail. Aparaently, you could solve the problem by replacing them with the type with the screw n the side. Also, remember to fill up with ATF, not PS fluid.
It's mine.. (correction, it was)
1994 320i SE alpine white - RIP
1992 320i SE black, bilstein coil over, sparco buckets, star chiped - SOLD
1998 Alfa 156 2.5 V6 red - SOLD
1988 325 iS red -RIP
1993 MX5 1.8 BRG - Daily
1996 740i green - Daily
Old 03-06-2008, 11:11 AM
Good call, I'll have a look in a bit and report my findings.
Cheers
Paul
Old 03-06-2008, 11:32 AM
bradley01's Avatar
bradley01 bradley01 is offline
Send a message via AIM to bradley01
Mein Auto: 2002 330xi ZPP/ZCW
Does your PS whine when you turn the wheel/get worse when you turn the wheel?
So Fresh and So Clean!!!
'02 330xi ZPP/ZCW
Springfield, IL
Old 03-06-2008, 11:45 AM
Yep
Old 03-06-2008, 04:03 PM
Was dark so had to look by mobile phone light but seems the fluid is very low and doesnt even touch the dipstick so I'll get some tomorrow. Thanks for all the replies.
Old 03-06-2008, 04:43 PM
Still here
Mein Auto: M3
Check the unit for leaks, the e36 pump is prone to them
Every BMW i have had or been in whines when it is on full lock...is a characteristic
Edirty6 for life
Old 03-07-2008, 04:25 PM
jordan325 jordan325 is offline
Driver
Mein Auto: 325i
On very cold days -10 or more, My power steering is loud. It's happened about 4-5 times this winter and goes away about 10 mins after driving.
Jordan325
Dmd. Swartz e36 325i | Host Daddy reviews
Old 03-09-2008, 06:59 AM
Topped up all sorted! Thanking you
