Old 03-29-2008, 06:24 PM
jp325xi jp325xi is offline
Mein Auto: 2012 335i, 2005 325xi
Bosch Icon's review
I picked up the Bosch Icon's for my 05 325xi. Even though they were not listed in the official fitment book. I looked on-line and bought the 420A and 422A. They mounted simply and look excellent. They basically cover up the connection and arm leaving a nice clean look. They are noticeable cleaner from the drivers seat.
They work very well, very tight to the windshield and they clear all the water nicely.
I had the OEM's on and they can't even be compared.
Highly recommended.
Old 03-30-2008, 02:02 PM
Topshelf Topshelf is offline
Mein Auto: '06 Z4 Coupe/'05 325xiT
Did you remove the little plastic piece on the drivers side towards the bottom that holds the factory blade in place? If not, just know that if your wiper starts missing a big section in the middle, take that piece out. It was causing all kinds of problems on mine, but I didn't know what the problems was until I found that.
Old 03-30-2008, 02:55 PM
AzNMpower32's Avatar
Tar Heel Faithful
Does the passenger side wiper get a clean wipe towards the bottom of the windshield? I know this is popular on the X5, with the drawback being about 2" of uncleared portion towards the bottom outside of the passenger stroke.
Old 03-30-2008, 04:15 PM
Topshelf; I did not take off that piece, but based on the rain and washing it does not seem to cause any issue, but thanks!
AzNMpower32; The down wipe totally clears the area like a squeegee. Now with that said, there is a slightly bigger area outside the wipers on the right of the passenger side. So it is a tad shorter, but not a issue at all. The functionality and clean look more then make up for it.
Old 03-31-2008, 06:58 AM
bradley01's Avatar
bradley01 bradley01 is offline
Send a message via AIM to bradley01
Mein Auto: 2002 330xi ZPP/ZCW
Highly recommended.
+1! I have them and I love them! Pair them up with a nice coat of Rain-Ex and you are golden!
As far as the length of the blades...you DID get a blade that was too short. I got the 425A blade for the passenger side simply because the recommended size was too short. If you take the OEM blade in and measure it up against what they recommended, you would see that it was way to short (by about two inches). Solution: get a bigger blade. They were the same fitment, just a bit longer; that all. Much better!
So Fresh and So Clean!!!
'02 330xi ZPP/ZCW
Springfield, IL
Old 03-31-2008, 07:02 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
I'm running 422B (driver) and 420B (passenger). Same size as OEM and works great.
Old 03-31-2008, 07:14 AM
bradley01's Avatar
So THAT is what the passenger size was...thanks Kris! The point I was trying to get at was to just check the replacement blade to make sure it was the same length...that's all.
'02 330xi ZPP/ZCW
Springfield, IL
Old 03-31-2008, 11:53 AM
triggs's Avatar
triggs triggs is offline
Gadget freak
Mein Auto: .02.330i.aw.
Uh oh. Mine's been ordered last week and already shipped.. 422B (driver) and 419B (Passenger)
I've followed the size from bimmerfest e46 Wiki...
Wiper Blades
The wiper blades are 22" (drivers side) and 19" (passenger side). The correct Bosch Icon pair are 422B and 419B.
02.330i.aw
| H&R Springs | K&N Cold Air Intake | Borla Catback exhaust | JL Stealth | Kenwood KVT |
Old 03-31-2008, 12:59 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Wiper Blades
The edge of the 420B wiper doesn't touch the windshield when it's in the rest position (due to the curvature of the windshield). The 419B does. Either is fine, really... 420B will just give you an additional 1/2 inch of swipe on each side.
Old 03-31-2008, 02:21 PM
Synaps3 Synaps3 is offline
Holy Flamebait, Batman!
Mein Auto: 2001 BMW 325xi Sedan
I just measured mine, and the sizes are 24 inch driver, 20 inch passenger.
'01 325xi
Just FYI.
Old 03-31-2008, 02:38 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
I had those on my gmc truck I traded in. Worked awesome, goofy looking as hell though on that truck
Not sure what they would look like on the bmw.
Old 03-31-2008, 02:43 PM
Hmm, I know mine are 22 driver and 20 passenger. No could anything longer than that 22 work on the drivers side. If you can see, then I guess it's the right size!
Old 03-31-2008, 03:19 PM
Tar Heel Faithful
Woah, those are big for a sedan! The X3 uses the same length (22"/20")
Old 03-31-2008, 03:53 PM
Rev2Liv Rev2Liv is offline
Mein Auto: Vespa GTS
This is a sidenote, but ICON's sit noticeably taller than standard wipers. If you look at the OEM implementations of Audi, MB Infiniti and even Lexus, you'll notice they implement an offset wiper linkage to reduce the profile of the blade.
Old 03-31-2008, 04:27 PM
Just went back and exchanged the 20 inch passenger wiper with a 19 inch, but the 24 sits fine and doesnt go over the windshield at all.
Old 03-31-2008, 04:37 PM
Does the 24 sit properly in the down position? That's where I think you would run into a problem with the bottom of the wiper. If it's working, then just leave it though.
Old 03-31-2008, 04:45 PM
I got the size from Bav. Auto. The driver's side fits perfect and the passenger side, at rest, sits with the right tip almost touching the rubber, so I don't think I could of gotten them any bigger. I noticed when I was looking at some other brand, similar to the Icon's, that each year was different and they didn't even list 05 xi's in the fitment guide. If I was not so lazy I would go take a pic and post it.
It was pouring today and the blades worked much better then OEM.
Old 03-31-2008, 06:22 PM
Well technically I've ordered the 24 inch bosch for pickup tomorrow morning, but the old wiper I have there now also measures 24 inches and it sits fine with no issues.
I'll repost here tomorrow if I have any problems with the new one.
Old 04-02-2008, 10:41 PM
Just posting to say that 24inch driver and 19 inch passenger fits perfectly on the windshield, both in motion and at rest, although I dont think you can go any higher than 24 and have it fit.
Gives me a huge tract of wiped space on the windshield too. I like it.
Old 04-03-2008, 04:44 AM
boogety boogety is offline
Boogety Boogety
Mein Auto: 325Ci
Just FYI, someone in another forum I frequent revealed that the Bosch Icon letter designations after the sizes ("19A", "22B") signify a less or more aggressive curvature to adapt the wiper to windshield curves of smaller radii. In other words: Pick the letter A wipers for a flatter windshield application, and the letter B for a more curved windshield.
If your tips don't quite touch the windshield on the passenger side, you might want the B style there... the driver's side would use either the A or the B
Old 04-03-2008, 05:18 AM
bradley01's Avatar
I thought that the A and B meant whether or not it was drivers side or passengers side. I.E. A for driver and B for passenger...
'02 330xi ZPP/ZCW
Springfield, IL
Old 04-03-2008, 05:51 AM
tdd tdd is offline
Mein Auto: Electric Red '02 330CiC
Since I need wiper blades, this thread came along at a great time. On Amazon, I found the blades for my car ('02 330cic) and this is what Amazon lists them as:
"Bosch 3397001394 Wiper Blades, OE Fitment - Set of 2"
"This product fits your 2002 BMW 330Ci"
There's nothing designating a number (e.g., 422A, B, etc.). Would these be the right blades?
Thanks,
Tom
'02 330CiC, electric red, sand leather, sp, pp, steptronic, bi-xenon
"Send lawyers, guns and money/The sh*t has hit the fan"
Old 04-03-2008, 06:43 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
422B, etc are the Bosch Icon part numbers. Bosch makes several models of wiper blades.
Old 04-03-2008, 07:05 AM
tdd tdd is offline
OK. I think I understand. Thanks.
Old 04-03-2008, 08:17 AM
Boogety Boogety
Mein Auto: 325Ci
You'd be right for our applications... but not all vehicles have the wipers pivoting from the far left/center like our cars. Some pivot from the far right/far left (tips meeting in the middle of the windshield), far right/center (perhaps a right-hand-drive car originally, but shipped to us as a left-driver), top of the windshield (say, a tour bus or other large vehicle), etc. Thus, I guess, the A and B designation...
