Old 01-28-2008, 04:13 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Front Lighting
Old 02-22-2008, 07:25 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Strut brace install instructions
http://www.bimmerfest.com/forums/att...7&d=1181582846
Old 02-24-2008, 11:10 AM
Ron Stygar's Avatar
19,585 Miles
Z4 Exterior mirror glass instructions
Following compliments of Palantirion:
First the mirrors. Step 1 is to slide this tab to the left to unlock the mirror (major PITA ):
The mirror pulls off with its retaining clip and then you unscrew three screws to remove the motor. Also disconnect the two wires and connector:
Another view, also showing how to tilt the mirror so you can unscrew the screw holding the plastic cover in place:
Take another four screws out and release two small tabs inside the mirror housing and you can slide it off.
Old 05-26-2008, 04:24 PM
fbriggs fbriggs is offline
Mein Auto: 2003 Z4
Post Z4 water pump replacement (e85, m54)
OK..here is how you really change the water pump on a Z4....(E85, m54 motor, mine is a 2.5) I have done this procedure, and all you will need are one water pump with o-ring, two m6x25mm bolts, a gallon of anti-freeze, simple hand tools, a few blocks of wood, a rolling floor jack, and jack stands. It is a good time to replace the belts, so get both of them. Yes, you do have to move the engine..a little.
1. Jack up the car on one side, place a smaller jackstand under the car where the front stabalizer is bolted to the frame. You just need to get the car up enough to remove the front plastic splashpan. Now remove the splashpan, grip it firmly, and toss it at the nearest BMW engineer to show your gratitude for designing a car that has a sheet metal support with webing placed directly infront of the water pump, thereby making it necessary to move the engine in order to remove the water pump, even though there is enough room infront of the sheet metal support to be able to desing it with a slight 1" dip towards the front of the car thereby providing enough clearance to simply remove the water pump unimpeded. Now, jack up the car a little higher, and remove your small jackstand and place a big jackstand (now that you have the clearance) under the car. place the jack on the other side, and jack it up enough to place another large jackstand under the car at the point where the anti-sway bar (stabilizer) bolts to the frame. Now place a rolling floorjack under the engine and place a block of wood between the jack and the oilpan at the front of the engine. Make sure this block of wood is long enough to support the load across the entire width of the oilpan, in order to srpead the weight of the engine across as much of the oilpan as possible, for obvious reasons. You just need to jack it up to meet the oilpan, don't go any higher yet. The reason you do this now is because the underside of the engine will soon become wet with anti-freeze, making everything slippery.
2. Now remove the belt for the A/C compressor (torx bit needed for tensioner)
3. Remove the top plastic (fanshroud?) cover and loosen but don't remove the bolts on the water pump pulley. Remove the serpentine belt. 16mm socket for the tensioner.
4. Now remove the 10mm bolts on the water pump pulley. Tap the pulley gently to get it off. It is made of plastic, so be careful. Remove the 10mm nuts on the water pump. Now install your m6x25mm bolts into the threaded holes on the water pump. Tighten them, and this will remove the water pump from the engine block. The coolant will spill out, but it won't be a lot. Now remove the upper radiator hose only where it connects to the engine by prying the metal clip. Push it up out of the way against the oil filter housing. You can remove the hose before removing the pump, but I did not because it would otherwise make everything wet that I still have to work on.
5. Now remove the nut at the left engine mount. I think it is a 16mm, might have been 15mm.
6. Jack up the engine slowly, but only go up to the point where the engine mounting bolt is just at the lip of the engine mount, where it almost clears the engine mount, but no further. (I would not want to have to line that thing up upon installation. Besides, it is not necessary to go that far.) You should now be able to pull out the water pump going in the direction of the passenger side.
Ta Da! You've now saved your self a lot of money. Now install the new water pump by lubricating the new o-ring with a little ant-freeze on your hand, and install the water pump. Put the car back together. Pour in some anti-freeze. With the car and the heater running, bleed the air out of the cooling system. (With the bleeder screw located next to the resevior cap.) But keep the old water pump. You will need this during your next trip to Germany, when you get the opportunity to throw it at the head of a BMW z4 engineer. This will make them think! It would be different if these water pumps did not fail prematurely.
Hope this helps!
Old 06-08-2008, 08:55 PM
Ron Stygar's Avatar
19,585 Miles
BMW Antifreeze: 82 14 1 467 704 $19.25 retail
BMW antifreeze ia a long term rated coolant, unless you have repairs.
Old 06-17-2008, 08:37 PM
Ron Stygar's Avatar
19,585 Miles
BMW Faults: MSS70-2006 MZ4
Will add to them as it goes.
Old 07-23-2008, 11:03 AM
Ron Stygar's Avatar
19,585 Miles
Headlight washer operation
Old 11-11-2008, 07:52 AM
Ron Stygar's Avatar
19,585 Miles
Winter storage
Following is from a S54 bulletin.
Following is from the BMW Operating Fluids manual group00.
Gas tank mention was interesting.
Old 12-12-2008, 08:59 PM
Ron Stygar's Avatar
19,585 Miles
Differential Fluids
Old 12-13-2008, 09:34 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Beyond the trip home from the dealer (with the container bouncing around in the trunk) shaking the jug had never occured to me.
Thanks!
Glad to see you have your connection (laptop) back.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 12-16-2008, 08:55 AM
Ron Stygar's Avatar
19,585 Miles
Z4 M Filling Quantities
Old 12-21-2008, 04:54 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Jacking points
Old 01-06-2009, 09:26 PM
Ron Stygar's Avatar
19,585 Miles
CDV install and clutch bleed
1.3mm: Smaller yet versus the 1.7mm we are used to seeing.
Tools I used.
Also used a second clamp on the reservoir clutch line output.
No leaks this way at all if you don't shake the hose.
Some other lock valves:
Clutch Bleed:
The E36 and E36/7-8 (Z3) use the same basic clutch pieces parts.
For some reason the E36/7-8 (Z3) cars engagement point is lower than the E36. On the E36/7-8 (Z3), the engagement point lowers with heat.
From checking out the E36/7-8 (Z3), developing the front shifting arm bushings, I know that the temperature in the tunnel area exceeds 200 degrees F. The stock front shifting arm bushing in my M coupe turned to mush in less than 5000 miles.
The clutch slave cylinder is in the tunnel area.
Bleeding the clutch raises the engagement point on some E36/7-8's.
I purchased the bleed tool to see what the result is using it. Will be checking this out later this year.
For the ingineer fluid folks, how would the engagement point change with air in the system versus no air in the system with heat?
In other words, is it a bleed the air out thing?
Old 02-01-2009, 09:08 PM
Ron Stygar's Avatar
19,585 Miles
Z4-M NA Passenger side motor mount bracket problem
http://www.bimmerfest.com/forums/sho...d.php?t=233491
http://www.bimmerfest.com/forums/sho...d.php?t=247988
http://www.bimmerfest.com/forums/sho...d.php?t=272236
http://www.bimmerfest.com/forums/sho...d.php?t=294159
http://www.bimmerfest.com/forums/sho...0962&highlight
http://www.bimmerfest.com/forums/sho....php?p=4067789
If you want to use BMW stuff MotorSport Z4 uses the following:
http://www.bimmerfest.com/forums/sho...ght=motorsport
Screw 07 11 9 913 653 $0.47r
Screw 07 11 9 913 673 $0.62r
Washer 07 11 9 903 078 $0.35r
Bulletin:
Angle torque:
This is used on the connecting rod bolts and other things.
You torque the screw and then turn it degrees mentioned in the TIS torque area for what your doing.
http://www.unofficialbmw.com/all/too...le_torque.html
Retail is $191.37 now.
Motor mount bracket screws:
I had the front reinforcement plate out to clean the power steering fluid.
Good time to do the motor bracket screws.
Will do the drivers side when I remove the air collector.
I used the Motorsport 10.9 screws and washers.
Torqued all four at 24Nm with the following Sears tools.
Torque:
Old 02-17-2009, 06:47 AM
Ron Stygar's Avatar
19,585 Miles
Operating Fluids Group 11
Old 02-26-2009, 09:40 AM
Ron Stygar's Avatar
19,585 Miles
Secondary Air System Analysis
Old 03-14-2009, 06:03 PM
P2ayc P2ayc is offline
Navigator
Mein Auto: 2003 Z4
switched power z4
Finally got my extra power outlets in today. I have one for xm & another to charge my phone. I hate having wires out the cigg lighter.
What I did is remove the ashtray, remove the screw under it. Then lift the unit up & back the whole thing comes out in one unit.
There are three connectors attached to this, you want the largest (brown) one.
Peel back the wire covering & locate the purple & white wire. This is hot when the switch is on. Use the ground from the cigg lighter.
I fished the wires into the glove (something,on this car that is basically useless) I have the xm & extra outlet there.
I only listen to one station on xm so I don't need to see it or have it within reach. If you do then bring the wires out at a different location as fits your needs.
Old 04-02-2009, 06:02 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Instrument Cluster System Test
Speed: km/hr X 0.6214 = miles/hr
From jragan:
1. Enter Vehicle.
2. Start Car. (You can enter test mode and test all while the car is running and moving)
3. Enter test mode (hold down the S/R button until _tESt_0._ is displayed)
4. Press the S/R button quickly until _tESt_19._ is displayed.
......After a second, _tESt_19.0 will be displayed with alternating/flashing L_oFF and L_oN.
......When L_oFF is displayed, press both the S/R and the button beside it at the same time.
......You will be returned to _tESt_0._
5. Press the S/R button quickly until _tESt_7._ is displayed.
......After a second, _tESt_7.0 will be displayed.
......Press S/R button quickly until _tESt_7.3 is displayed.
6. Drive.
7. Note speeds. (Remember the _tESt_7.3 speed is in km/h so you'll need to do some math afterwards)
8. Stop Driving.
9. Turn car off.
10. Exit vehicle.
Last edited by Ron Stygar; 08-28-2010 at 09:24 AM. Reason: (You can enter test mode and test all while the car is running and moving)
Old 04-03-2009, 06:56 AM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: 08 Z4MC & 03 Z4 2.5i
Talking Z4 Softtop Removal and Softtop Motor Changeout
Over on Z4-forum.com, in the How-To section are two How-To's. One for the Soft Top removal and the other is for the motor replacement.
Soft Top removal: http://www.z4-forum.com/forum/viewto...p?f=12&t=10190
Motor replacement: http://www.z4-forum.com/forum/viewto...p?f=12&t=10189
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of more people.
Walter E. Williams
Drives a 2008 Z4M Coupe' (His) & 2003 Z4 Roadster (Her's)
Old 04-05-2009, 11:51 AM
Ron Stygar's Avatar
19,585 Miles
Tire wear
Old 04-25-2009, 03:47 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Weight distribution
Old 04-26-2009, 02:42 PM
Ron Stygar's Avatar
19,585 Miles
S54 Limp-home modes
From the E46-M3 (S54) Training Manual.
Old 05-02-2009, 08:22 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Rivets
http://www.bimmerfest.com/forums/sho...d.php?t=302441
Confusion was that it shows at group 51 but doesn't show the correct rivets.
Turns out it's under group 41.
Did someone remove your bumper before, that didn't have the right parts? Could have been from assembly.
The part you have is a pop rivet as suspected.
There is one on each side on the wheelwell at the bottom 9 inches in from the fender.
Item 10
http://www.realoem.com/bmw/showparts...51&hg=41&fg=10
Item 27
http://www.realoem.com/bmw/showparts...08&hg=41&fg=25
Old 05-08-2009, 06:26 PM
Ron Stygar's Avatar
19,585 Miles
S54 Valve Check/Adjust
BMW shows it done every Inspection.
I checked mine on the '01 Z3 M coupe around 30K and it was in spec.
Will be doing it at 30K steps along with some other things.
Engine rotation:
Before you start, be cool on the car.
http://www.bimmerfest.com/forums/showthread.php?t=9755
http://www.bimmerfest.com/forums/showthread.php?t=28710
http://www.bimmerfest.com/forums/showthread.php?t=68387
http://www.bimmerfest.com/forums/sho...d.php?t=337021
http://www.bimmerfest.com/forums/showthread.php?t=97891
http://www.bimmerfest.com/forums/sho...d.php?t=493987
Originally Posted by jmillet View Post
I use the Craftsman off-set leaf gauge, SKU 40802, price $9.99, that has blades ranging from .005" (.127mm) to .030" (.762mm). As pointed out by Ron the .007" (.178mm) and the .009" (.229mm) work for the intake valve clearance check and the .011" (.279mm) and .013" (.330mm) for the exhaust valves.
$15.84 total delivered tax and shipping.
http://www.sears.com/shc/s/p_10153_1...?keyword=40802
Old 05-17-2009, 09:19 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Emblem Install
