Old 06-10-2008, 09:03 PM
Oakland7 Oakland7 is offline
Mein Auto: 2007 750Li
Is there a switch to make the cold air flow in the center console?
It seems to be random thing. Sometimes it works and sometimes not. Is there a switch to turn it on??
07' 750Li Sterling Gray
06 Benz R500
05 Range Rover
Old 06-10-2008, 09:11 PM
harjothundal's Avatar
harjothundal harjothundal is offline
E65/E66 Helper Man.......
Send a message via AIM to harjothundal Send a message via MSN to harjothundal
Mein Auto: BMW 745 Li
the rear air control in the center console must be turned on for the rear seat passengers... without that, air will not pass through the vents...
Old 06-10-2008, 09:12 PM
p.s. there is also a switch in the actual console itself, rotary type... both must be turned on...
Old 06-10-2008, 09:47 PM
LBC X5's Avatar
LBC X5 LBC X5 is offline
Mein Auto: 745i
Ahhh i've been wondering this forever! Thanks!
Old 06-11-2008, 10:31 PM
Thanks for the help, I know about the rotary button inside the console but where is the switch for the rear vents for the rear passengers?
06 Benz R500
05 Range Rover
Old 06-11-2008, 10:40 PM
the center console will have 2 rear vents for the back seat passengers... 2 of the knobs for the vents will be to set the vents for hot/cold, and 2 of the knobs will be for turning the vents on and off...
set the vents to cold, and open them up... its actually a switch that will turn on a fan, not really a flap that opens...
Old 06-11-2008, 11:41 PM
I just tried it and it works. however, ive tried to switch everything on and off before and it did not work.
Thanks for the info, it is working well so far.
06 Benz R500
05 Range Rover
