E36 M3 (1995-1999)
#76
I get a brake light circuit failure that shows up on the comp randomly and then goes away. I've checked the brake light and it works. I've also checked the fuse but it is not that either. Should I just leave it be until the message stays on or until the brake lights stop working?
#77
Where can we get these 'metal pieces'?
#78
I cured the brake light circuit failure by replacing the brake switch.
#79
JT Designs:
http://www.jt-designs.com/ Jim
coolant light goes on computer screen even after replaced several times
#81
Replace your brake light switch
Here's a pretty good link covering the procedure involved: http://www.pelicanparts.com/BMW/tech...ake_Switch.htm Cheers,
Hi,
One of the plastic front headlight washer jets has fallen off. The replacement one won't stay on properly. To cap it all, the headlight washers have sprung a leak behind the front bumper and between the washer bottle reservoir. How do I get behind the front washer jets to access the spline which the nozzles fit onto? Do I have to remove the front bumper to access the hoses and connectors? if I do, how do I go about removing the front bumper of my E36 M3. Any help greatly appreciated. |
#83
M3 Gear Shift
HYA MATE MY CAR SEEMS TO BE HAVIN THE SAME PROBLUM AS URS ITS DIFICULT TO GT INTO GEAR ONCE ITS WARM... DID U MANAGE TO SORT URS OUT??
#84
WATS THE ISSUE WITH GEARS NT SHIFTING AS MINE IS ALSO DOIN IT WEN ITS WARN??? |
#85
dont forget about your micro filters. 20 bucks and 1 hour of work if you do it yourself for the first time. lets more air in through air coditioning and heating vents.
'94 325IS white- Vader seats, M3 rims,,,,,(for sale) '98 ///M3 dakar- stock engine 71k mi. magma brown vaders. |
#86
about the brake light circut. you can wait till it goes out or replace it now. its located underneath your brake pedal way high and its this plastic switch that is a pain to get out . i got it and had a bmw guy put it in.
#87
Brake Circut Light
#88
Hi, I have a problem with my SMG transmission, when in sequential mode the hazard lights come on. Internally only, I think. Still shifts fine, I do back it off when it happens. Doesn't happen in auto modes that I've noticed. Is this a fault signal? Or dodgy wiring?
First time bmw owner..... Thanx |
#89
wear out fast
The head linner fails on all 3 series, the door panels come apart. gas door security catch is plastic, rear lites have problems. But come on man all this is light weight stuff. The car is solid the motor can't be beat, it's a sound investement, money wise...wk...And a really fun car to drive, that's fast and powerful, you can get it in 3'rd gear under 20mph...
#90
wow, 5 year thread
#91
Hey Biimer guys. I just bought a '97 Dinan M3. Got a good deal, cleaned the airfilter parts out of the MAFS and now it runs fine.
Can anybody tell me how loud the Dinan supercharger is supposed to be? I can't tell if the whistle is from air moving or parts squeeking. This is the first Dinan I've had or ever been around. |
#92
Hi, I'm looking at buying a 98 M3, but this thread is making me lean towards an e46 330. Do all of the problems in this thread apply to models of later model years? Also is there anything you guys would look out for in particular on one with 70k miles? Thanks!
#93
At 70k miles, things begin to fail on all E36s - Check this list to see what to look for - I haven't looked through this thread in a while, so I'm not sure what's been covered and what hasn't. I will say one thing, though, if the car has overheated, stay away. There is a likelihood that the headgasket is blown, which is a $2k job for a good independent mechanic, which isn't an absurd charge for a car as fun as the M3. What *can* happen with that, though, is a warped or cracked head, which means a full rebuild, which can cost upwards of $2k ALSO, including the cost of a used head. That said, if the car checks out (M3) well from a pre-purchase inspection from a good independent mechanic, and you take care of hazards that (s)he may find, the car can serve you well for a long time. I know two people with almost 200,000 miles on their E36 M3s and know of several more with over 200k. With the E46 you get a more modern build, an equally reliable engine and similar issues with the car as a whole as you'll find in the link above. If the cost to just get into the car (sale price) is close enough, the E46 might be a better option, simply because of the newness of the car. Good luck
I drove one today and... wow, I can't believe what it's like to drive these things. Unfortunately, there was enough iffy about the car (like paint being slightly different colors on different body panels) to make me walk away. The potential E36 issues still might be worth it for a car that drives like this, I'm really leaning towards this instead of an E46 330 now. Of course I'm experiencing the problems w/ test driving a BMW; I can't stop thinking about the car!
#95
After filling my washer fluid up..it lost almost all pressure. Help!
#96
sounds like some kind of clog, maybe sediment or something similar... this is especially possible if you ever let the reservoir go completely dry. There are mineral deposits on the inside of the reservoir that can flake off if it stays dry for too long. These can clog the outlet line going to the washer pump.
"No matter where you go, there you are..." Buckaroo Banzai |
#97
Like other posts here, I was getting turned off of the purchase, given that I plan to track it and can't tell a water pump from an ice cream scooper. But, screw it! Gotta learn sometime. If anyone has a good BMW mechanic in the Los Angeles area, please post. 1st post BTW; you guys know so much good sh**! |
#98
About the nut that people recommend tack welding...how hard is this to get to? Is this a good DIY, or is someone like me with an average/below average knowledge of internals getting in over their head?
#99
M3 softtop....
Hi. I'm looking to re-enter the bimmer world with an 1999 E36/M3! I am concerned about the issues sited here, but feel like the car over all will be FUN to drive, and worth the few common issues. It seems that some of these are common to other bimmer models as well. Thanks for the thread. A list of maintenance items to perform at 110 and 120k miles, etc. would be GREAT! The car I'm looking at has 112k.... I'm READY to drive!
#100
Idrive330i and Terraphantm, i recommend go for the M3, I have just purchased a 97 Eurospec M3, it is awesome, I love it, the "M" badge and all that comes with it makes it an awesome experience every time I drive it! My advice is to get any car thoroughly checked by a qualified mechanic before buying, he should be able to identify through suspension and brake wear etc if it's been thrashed. If it does not have a documented service history (particularly for high mileage cars) walk away, these are high performance engines that need regular oil and coolant changes with top shelf products. Make sure the coolant is clean, if the coolant is clean but the bottle is dirty you will be asking for trouble.
It's only early days but the only issue with my car is the engine oil temp gauge is not working. The clutch was replaced and the Vanos was rebuilt at 150,000kms. It's a gem! Be patient and wait for the right car (I searched for 8 months with plenty of lemons out there), the "M" experience is worth it. Good luck! |
