E90/E91/E92/E93 (2006 - 2013)
Old 07-10-2008, 08:03 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
E90/E91/E92/E93 OEM Spare Tire source
I know the leather-Z kit has been out for a while. it just never sat right with me that a) it was almost 400 for the kit that fit the 335i ( tire + tools + spacer & bolts)
b) you needed to use a 15mm spacer to get it to work.
digging through the ETK, it looks like the leather-z spare is the spare from the E46 cab.
3.50BX17 ET:30
a little more digging shows that the E60 550i uses front brake rotors the same size (348mm) and thickness as the 335i. brake calipers look to be of approximate same size.
the compact spare for the 550i is:
4BX17 ET:18
the offset is close to that of the E46 spare plus spacer-- ET 15 for the E46 spare wheel + spacer vs ET 18
now the fun part. BMW sells a retrofit spare kit for the E60. it includes:
the wheel +tire diameter is within 2% of stock tires.
total price from tischer BMW, for the whole retrofit kit listed above, before shipping, is $239.
I've ordered up a set, will keep everyone posted as to if it works. if it doesnt, i have a new flower planter. if it does, a spare that works without having to deal with the spacer, and for a lower price.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 07-10-2008, 08:32 AM
BMWFM1 BMWFM1 is offline
Mein Auto: 328xi
Very interesting finding. Please keep us posted. (Already bought the LeatherZ but it is good to have alternatives).
Some folks had mentioned at one point using an X3 spare. Have you looked into it?
FM
E91 328xi, Jet Black, Black Dakota, Dark Burl, Premium, Steptronic, Navigation, Active Cruise, Park Distance Control, Sirius Satellite Radio. Debadged, Euro Switch, Dome Strut.
Old 07-10-2008, 08:40 AM
FM
yeah, the 550i and the X3 use the same spare rim. same P/N. i was drilling down using the brake size as a guide and the 550i was the best choice that had an optional spare.
i ran into a problem getting the tire-- when not bundled in the set i found, the tire has a lead time of 6-8 weeks from bmw and tire rack. alone its 120-150 bucks for the tire.
Old 07-10-2008, 09:00 AM
MrBones's Avatar
MrBones MrBones is offline
Skjoni's Dad
Mein Auto: 335i
Did you get a price for just the wheel/tire/valve? Or does it just come as a kit. Cuz I don't need a jack/chock/bracket... I already bought the BMW jack kit. I was planning on using a snow as a spare, but I'm sure your solution would be a thinner, lighter tire.
Old 07-10-2008, 09:12 AM
rim is about 52, tire is 116 from the tire rack, valve, usually 2 bucks when you get the tire mounted. bmw doesnt sell the rim and tire premounted unless its in the kit.
i was actually going to get the rim and tire only, but i only have full sized jacks.
i'm actually hoping i can mount the tire, somehow, to the roof of the trunk.
Old 07-10-2008, 10:40 AM
anE934fun anE934fun is online now
Mein Auto: 2010 335d
Where did you get the data on wheel + tire diameter?
Add me to those who are interested in your testing results.
Old 07-10-2008, 11:36 AM
easy... tire size is: tirewidth/sidewall height (expressed as a % of tire width) / rim size.
stock tire size is 225/40/18
225*0.4=90/25.4=3.54"
3.54*2= 7.08" +18"= 25.08" diameter
spare tire size: 135/80/17
135*0.8=108/25.4=4.25"
4.25*2=8.5"+17"=25.5" diameter
25.4 is the mm -> inch conversion.
Old 07-10-2008, 11:58 AM
TireSmoke's Avatar
TireSmoke TireSmoke is offline
Mein Auto: '06 E90 330xi
$400 bucks for a spare is highway robbery... I am also interested of there are any alternatives. I have 2006 330xi and I just changed to non-RFT's. I was considering just using AAA, but the problem is if you get a flat and need a new tire it will take 3 days minimum to get one from Tirerack (if the shop doesn't stock those). That's where the spare comes in. It also helps you to get to your destination and not be forced to abandon your trip.
Please keep us informed if any other BMW or other brand spares would fit E90. I assume that '06 330xi and new 335i's would require the same spare, right?
Old 07-10-2008, 12:00 PM
the 330i is a *little* easier, the front brakes are a little smaller than the ones on the 335i. but everything else would be the same
Old 07-10-2008, 12:03 PM
Interesting calculated results. For comparison, I have included data for the published spec on the Bridgestone Potenza RE050A RFTs:
Published Spec for Bridgestone Potenza RE050A RFTs in 225/40-18:
Diameter.........25.2 inches
Revs/mile........827
Based on your calculated result of 25.08 inches, there is apparently some minor variance between expected (calculated) and actual (published specification) diameter. Which is why my interest in your actual results. If you have ordered the BMW spare, when it arrives, could you do the following:
1. Mount the spare on your car at specified inflation pressure (60 psi?).
2. Roll the car forward for 1 complete revolution of the tire.
3. Measure the distance covered by the 1 complete revolution of the tire as loaded by the weight of the car.
The distance in item 3. above would give us the loaded circumference of the spare tire. It is then a matter to divide that result into a mile to get the number of rotations value. I acknowledge that the value won't be at speed, but I am wondering how close the rotations result will be to published specifications. If we wanted to get more precise, we could repeat items 1. - 3. for the Bridgestones and make an adjustment based on circumference for the Bridgestones.
I am personally really curious about the result of the measurement for the BMW spare tire. If the measurement is in the ball park, you may have found a viable option.
Old 07-10-2008, 12:22 PM
being completely honest, i'm not too worried-- its not exact on any of the other models. and of course its a temporary spare.
there's even a varience between the front and rear wheels with staggered tires... as well as tire wear varience. the rears will wear out faster than the fronts.
most modern traction control systems can handle 2-3% differences in diameters.
a 125/80/17 spare tire would be almost spot on, but i dont think a 4" rim will take a 125 tire ok.
also-- a runflat tire running on zero pressure has more a diameter difference than the temp spare (the FTM system doesnt trip until there's about a 10-15% diameter difference)
Old 07-10-2008, 01:07 PM
rallycobra rallycobra is offline
Mein Auto: volvo XC70 wagon !
Very interesting. I was pricing a 550 spare on ebay, last week. Kudos to you on your initiative! I would expect it to work, and eagerly await your results!
Old 07-10-2008, 01:28 PM
TireSmoke's Avatar
So, let me get this straight. If the total diameter is approximately equal to the regular tire, then any BMW spare will do? Is the bolt pattern the same? What about spares from older 5- and 3-series? Would they be okay?
Old 07-10-2008, 06:02 PM
E39 5 series wont fit-- the E39 for some reason had a centerbore that was different than any other bmw. the E39 had a 74.1mm centerbore. almost every other bmw has used 72.56.
E46 3 series will fit, but needs a spacer to clear the brakes.
the whole point of the E60 550i spare is to avoid the use of a spacer and the longer lugs needed.
Old 07-10-2008, 06:05 PM
yeah, i saw an E60 spare on ebay for 275 +50 S&H.
eesh
Old 07-13-2008, 05:26 AM
equ equ is offline
Mein Auto: Something or other
Generally agreed, a few % off (ideally below 2-4) should be ok. 10-15% diameter difference is huge. I think you mean, 10-15% pressure/PSI difference.
Are you planning to mount/test?
Old 07-13-2008, 09:41 AM
yes, 10-15% psi...
kit is ordered, waiting for tischer to get it from national distribution...
in my case, the tire size difference is going to be under 1%--- i'm switching to 235/40/18 non runflat Goodyear F1 GS-D3s
Old 07-16-2008, 07:59 AM
TireSmoke's Avatar
For how many miles is it safe to drive on a spare (if the spare is close in size to the original tire)? I know there are speed restrictions, but are there distance restrictions as well?
Old 07-16-2008, 10:13 AM
it depends on the tire... but i believe its about 150km or ~93 miles.
Old 07-16-2008, 12:06 PM
small update: kit shipped out. it came to 259 shipped from tischer bmw to my apt in manhattan.
i'll probably have time to test fit it this weekend.
Old 07-17-2008, 12:45 PM
TireSmoke's Avatar
Please let us know or PM me. I am interested in knowing. Tischer lists the spare wheel at $60 or so. Why did it come out to $259? What else did you order?
Old 07-17-2008, 12:54 PM
i have the ETK listing of whats in the kit i got in my first post
its:
Spare rim
Spare tire
Jack
wrench
chock
in-tire tray to hold all
i got the whole set for two reasons
1) the tire itself is backordered nationally for 6-8 weeks from both bmw and tire rack
2) seperately, the tire costs 115-150 depending on source.
115+60 + 20S&H
$195
+15 mount and balance
210
then add in the cost of the tools....
the kit arrived today, so i should be able to test it soon.
I'll be disappointed if the tire comes unmounted.... with my luck it will be..
Old 07-17-2008, 06:11 PM
and here's what the kit looks like, in box:
all the tools fit neatly into a foam tray that sits in the wheel hub.
Old 07-17-2008, 06:22 PM
alan93rsa alan93rsa is offline
Mein Auto: 335i
Looks like a winner
Old 07-17-2008, 06:30 PM
well, need to test mount it this weekend. almost tempted to go to the garage now and try it
