Old 08-25-2008, 11:13 AM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
Dinan Oil Cooler
Is it worth buying a Dinan oil cooler to preserve the life of my engine? I plan on keeping the car for over 6 to 8 years. I might eventually get the stage 1 after I have gotten used to the stock power, but I am thinking of getting the oil cooler right away. Any thoughts?
- Mk
Old 08-25-2008, 11:19 AM
Mech_Man's Avatar
Mech_Man Mech_Man is offline
I'm much better now, Dave
Mein Auto: 2008 335i e92
Since you should be getting the stock cooler, and replacing it with the extra-big Dinan could be done anytime in the life of your car, I'd suggest you see how it runs as-is.
If you go Stage 1, check out what the recommendations are at that time, as there will be that much more experience with the e92s, factory equipped coolers.
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod
-=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra
Old 08-25-2008, 11:23 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
You should join the other oil cooler thread - it has already started devolving into whether the factory oil cooler is really needed or not....
On a serious note, it kind of depends on how much you want to obsess about your cars engine. Personally, I plan on finding the point (using oil analysis) where the oil starts to degrade (combination of viscosity deterioration and base number drop) and then replace the oil & filter on that schedule. I expect the magic number will be somewhere in the 7,000 mile (7,500 mile?) point. Unless you are planning on tracking the car, I really don't see the benefit of a larger oil cooler. You might be able to stretch another 500 - 1,000 miles out of the oil by running a larger oil cooler; you won't get a magical 7,000 miles. Given the installed cost of a Dinan oil cooler vs. the cost of more frequent oil & filter changes, it would seem that more frequent oil & filter changes are a better solution (less cost and the engine is better maintained).
Old 08-25-2008, 12:05 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
I'd say more frequent oil changes are better than an additional oil cooler. Especially if the Dinan oil cooler doesn't actually lower oil temps (as it relies on an electronically controlled thermostat).
- Mike
I am fortunate to have unique press cars delivered weekly, but I own:
'16 BMW X5 xDrive35i M Sport 8AT
'15 Volkswagen Golf TDI 6MT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... my E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Read my work as Editor-in-Chief for Autoweb and Autobytel!
Old 08-25-2008, 12:25 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
- Mike
+1
The stock oil cooler only has oil actually flowing through it when the oil temp goes above ~240F. so if you arent actually hitting the activation temp for the stock oil cooler, the dinan cooler will do nothing for you.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 08-25-2008, 03:48 PM
Lost Horizon's Avatar
Lost Horizon Lost Horizon is offline
Mein Auto: 435 MSport/MPPK/M Exhaust
Originally Posted by Orient330iNYC View Post
+1
yup.. that's pretty much the way to figure it out... if your average temp is around the 240 mark, Dinan won't do much except lighten up your wallet.
Old 08-25-2008, 07:03 PM
Mk23's Avatar
- Mike
That sounds logical. Appreciate it guys.
Old 08-25-2008, 09:28 PM
invariant's Avatar
invariant invariant is offline
+1
I heard that with Dinan flash one also gets remapped water pump control, so that water circulates faster and keeps engine cooler. I have always been wondering if one could get just that feature... I'd favor higher pump speeds and lower engine temperatures over the pump wear and slightly higher emissions.
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 08-26-2008, 06:32 AM
well, the price would be a voided *BMW* powertrain warranty...
replacement cost for the water pump is 500 + labor, guessing 1K total
I'm not sure that the dinan flash lowers the operating temp of the engine, i suspect it might increase cooling under high demand, not just in general.
I've yet to see anyone display any proof that the high engine temps are actually as detrimental as everyone seems to think. i have a strong feeling that the extended oil change intervals have more of a negative effect that the high operating temp.
Old 08-26-2008, 08:58 AM
Sterling Sterling is offline
Mein Auto: 2007 335i
Are you guys sure that the stock Oil Cooler does not kick in until oil temp hits 240
I thought it worked all the time
Old 08-26-2008, 10:34 AM
I'm sure. I have run mine without and with the stock oil cooler, it it's quite apparent that the thermostat regulation begins at 113C with the cooler installed which is 235F. Without the cooler, the temp just rises and falls above that, floating with the load in normal driving. With the cooler, it hangs around 235-240, unless you really dig into it to go past the capability of the system to hold the set point range.
It's the way you want it to work. Just as you don't want the oil too far above the design point, you don't want it too low either. Without the thermostat on a cold winter day, it could drag the oil temp down below design, or take the oil that much longer to warm up... also a wear problem.
Old 08-26-2008, 10:41 AM
jelliotlevy jelliotlevy is offline
Mein Auto: 2011BMW 335i, Honda S2000
In fairness, nobody here is knocking the Dinan cooler. If you drive competitively at the track, it would seem worth having. If your normal driving style involves aggressively going up and down hill, hard braking and acceleration, all in lower gears at high rpm's, then it might also be worth having. If none of the above apply, then the factory auxiliary cooler will keep you below 240 essentially all the time, and that should be best for longevity. You might also ask yourself if you have higher priority uses for the two thousand bucks.
Old 08-26-2008, 02:26 PM
fun2drive's Avatar
BMWCCA 149159
My car didn't have the cooler and my temps would hit 270F. However that was under high speed driving in Germany at an ambient temp of 50-55F. In the US I have seen 255F most of the time and decided that since I keep BMWs around 10-12 years getting the factory aux cooler installed was worth the cost. I can't comment so far to date because have not driven it that much on the interstate. From what I can tell the temp stays around 240F.
Still I came from a Supercharged 325 which never got above 210 and usually stayed at 180F.
I know from reading some SAE papers and some extended tests that the oil will handle the temps but what concerns me are the seals, hoses, other underhood components that are exposed to these higher temps.
Time will tell but I am doing oil changes at 7500 miles after an initial 2500 change.
Engines are expensive, oil is cheap and I am conservative...
Old 08-26-2008, 02:33 PM
amuro876 amuro876 is offline
Mein Auto: 335i
may i ask how much you pay for the oem oil cooler with installation? i am also without oil cooler.
Old 08-26-2008, 03:13 PM
Mine was approx 2,500 CDN back in 2007. There is a fair bag of parts to do it, and they have to change out the front wheel well liner as well as change the oil filter and housing. If you are without, the Dinan is most likely no more expensive, and a better cooler from ground zero.
Old 08-26-2008, 03:33 PM
g2artist's Avatar
g2artist g2artist is offline
Mein Auto: 2008 335i convertible
My thoughts exactly, the seals and hoses have gotta be taking a beating in that kind of heat.
