Old 09-18-2008, 02:22 PM
XZLR8's Avatar
XZLR8 XZLR8 is offline
Mein Auto: X6 ///M
Headlight condensation...
I've been having an issue with a LOT of condensation in both of my front turn signals. When I wash the car or it rains, the condensation will stick around for days. I'm assuming that the seals are bad or some such? Easy fix?
I'm not having any issues, so I hate to take the car in for just this, but it's annoying.
2016 BMW X6 ///M | DoningtonGrey/BlackFullMerino
2016 BMW 750xi M-Sport | GlacierSilver/BlackNappa
2015 BMW X4 35i M-Sport | GlacierSilver/BlackNevada [wife's ride]
2017 BMW X5 50i M-Sport | SpaceGray/MochaNappa [ON ORDER!]
PREVIOUS | '14 328xiT, '14 X6M, '14 X6 35i, '13 650xiGC, '12 650xi, '11 535xi, '11 X6 50i, '09 750i, '09 328xiT, '08 650i, '07 750i, '07 X5 4.8i, '06 650i, '05 745i, '05 325xiT, '03 745i, '02 745i, '01 325Cic, '01 X5 4.4i, and on...
Old 09-18-2008, 02:27 PM
mustaine's Avatar
mustaine mustaine is offline
Mein Auto: 2007 ///M5
Warranty will replace it. Take some pics and take it to the dealer.
So, I ask myself the question, what today..... what tomorrow?
Old 09-18-2008, 06:41 PM
Phatisfy Phatisfy is offline
dRopTop'd
Send a message via AIM to Phatisfy
Mein Auto: 2005 E64
I get that problem too,but it goes away quick.
Old 09-19-2008, 08:32 AM
Last Emperor Last Emperor is offline
Mein Auto: 650 cic
was the car brand new
i had this the 1st day i picked up my 08 650
lasted a few days, and went away
now its gone,
came back for an hour or so after car wash, but is mostly gone
Old 12-16-2008, 06:11 PM
jzcrna's Avatar
jzcrna jzcrna is offline
Mein Auto: 2012 BMW 335i Sedan
The headlight condensation is a known problem.
Check these service bulletins out under auto recalls/repairs:
http://search.ebscohost.com/
username: lib
password: access
Old 12-16-2008, 11:37 PM
eefx eefx is offline
Mein Auto: BMW 650IC
same here first day got fog ed up
08 BMW 650ci vert
06 Range Rover Sport HSE
08 GMC Sierra 1500 (few mods)
02 Mustang Roush 360R 400hp (to many mods)
06 Ducati 749s (few mods)
Old 03-04-2011, 08:52 AM
-Paul- -Paul- is offline
Mein Auto: 645ci
Sorry to raise such an old thread - I'm having condensation issues on one light. I've undone and removed the rear cover and the main bulb. Is there anything else I can do? - I'm out of warranty.
Old 03-04-2011, 10:45 AM
Losnyc82 Losnyc82 is offline
Mein Auto: 06 650 vert
Mines does the same also such an eye sore I hate especially during the day when the day time lights are running
Old 03-04-2011, 01:07 PM
joepipe joepipe is offline
Mein Auto: 2005 BMW 645CI
I have the same problem in my passenger side headlight and turn signal covers....all fogged and with water droplets.....used to go away after a day or 2 now its hanging around for over a week with no end in sight....someone mentioned on another thread to remove the back cover for a night or 2 and drive around ......I might try that but I would really like to know whats causing the problem in the first place !!
heres the message
I was having the same issue for a week, there a few threads on here that deal with the same issue. So I thought I'd have to reseal the headlight housing or even buy a new headlight housing back plate but it turns out that if you remove the back on the headlight housing and drive around (this will clear the condensation out) and put the back plate back on you shouldn't have this issue again.
I basically used this approach and have been issue free since October. If it continues try replacing the back plate cover on the headlight unit first before removing the headlight and resealing with caulking.
Old 03-05-2011, 05:35 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is online now
Mein Auto: 2012 650 Coupe
I had the same issue on my 645 - it was the rubber seal under the turn signal (between it and the headlight casing). There is a thread on here about someone DIYing it with some silicone sealant. Do a search.
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 03-05-2011, 09:38 AM
Question
Is it easy to get to the turn light seal ? I would look at my car right now but its pouring rain outside lol.
Old 03-07-2011, 05:03 AM
Mein Auto: 645ci
I had the cover off and left overnight - not warm in UK - still misted up - left cover off and then turned lights including headlamps on - left them on too long and flattened battery! DOH.
Charged battery - left cover off lamp - only put wheel arch cover back on - had a spirited drive so engine bay warmed up.
%80 of water gone now. Cover back on.
Old 03-07-2011, 12:55 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
The head lamps are sealed and the only entrance into it is the bulb compartment cover. I was told that the rubber seal on the covers will go bad ofter awhile and this break in the seal will cause the condensation to build up. The rubber looses it's elasticity and form due to the high temp it's exposed to such as the HID builds and engine heat. Like with any rubber product, extreme hot and cold will cause it to break down. Try changing the rubber seal and see if that solve your problem. I've seen a post where small insects some how got into the housing as well so you know the rubber seal is no longer doing it's job.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 02-01-2013, 12:00 AM
yyzzhottop yyzzhottop is offline
Mein Auto: 325 ci
Great thanks. I v had the same problem.
I had the same problem with heavy condensation after going through car wash... It burnt out the bulb and I had to replace the control unit.... $1,200.00. Dealers says they can't find the source of water entering... After a week the bulb went out again, now the dealer wants another $2,500.00 for a complete headlight assembly...
Is there a better ( cheaper solution)
Old 02-01-2013, 12:01 AM
Mein Auto: 325 ci
Condensation in headlight
If anyone has a better solution please email me
winxtra@sympatico.ca.
Old 02-01-2013, 08:41 AM
GetMeABeer's Avatar
GetMeABeer GetMeABeer is offline
Mein Auto: 05 645Ci
Have some slight evidence of that in mine. Nothing that I can see after the car wash or whatever, but can see residual signs of it.
I've seen that in most of the cars I've owned though. Ford is notorious with that, but luckily, under warranty they replace anything with no questions asked. The worst is when the plastic headlight covers actually start to cloud over and they look like crap.
Old 02-01-2013, 02:53 PM
garethparsonage garethparsonage is offline
650i vert
Mein Auto: 650i
I did the 1mm drain mod, worked a treat for me, no condensation since also did the mod on the reverse/ fog lights, they kept filling up and blowing the bulb!
Old 10-14-2015, 09:38 AM
Snabben Snabben is offline
snabben
Mein Auto: 2005 645Ci Convertible
Do you have to remove the bumper to be able to drill the 1mm drain hole? Where is the best spot to drill the hole?
Old 10-14-2015, 12:18 PM
650i vert
Mein Auto: 650i
Unfortunatly yes, need to remove headlamp also, drill the hole in the bottom of the headlamp unit, be sure not to drill any of the internal fittings ***55357;***56833;
Old 10-23-2015, 12:24 PM
shan904 shan904 is offline
Mein Auto: 2005 645ci
I have had to replace my control module 3 times due to water leaking into my headlight assembly and shorting it out. Every time I replace it, I did my best to reseal the headlight assembly with silicone but the water still managed to get in there somehow. The last time I replaced the module I realized the seal was broken down on the headlight compartment door. I lifted the seal, put some silicone under and now it fits very snug, I could barely get it to shut, no leak since!
