E30 (1982 - 1993)
Headlight Problems
Hello,
I'm new too the forums and just encountered some headlight trouble and was wondering if anyone could help me. my right low beam is out, my left one works fine, but the weird thing is when i put the high beams on all 4 lamps are working anyone have a quick fix? thank you very much!
just too be more specific its a 91 BMW 318i
check the wires may be some one cross a wire if im not mastaking it only has one beam and they conected from the high beaqm next to it
and if you want a quick fix run a wire from the low beam on the left to the right |
alright thanks. and was wondering someone said that it could be the low beam relay is that possible?
The low beam portion of the light is probably burnt out. Replace the light. Should only be $10 for a new light
My other car is German too!!! |
You have sealed beam lights. Everything is working normally for a set of headlights with either a low-beam filament or the fuse for that low beam blown.
In Italy for 30 years under the Borgias they had warfare, terror, murder, and bloodshed, but they produced Michelangelo, Leonardo da Vinci, and the Renaissance. In Switzerland they had brotherly love - they had 500 years of democracy and peace, and what did that produce? The cuckoo clock. -Harry Lime (Orson Welles), "The Third Man" |
hobbs new mexico?
really? out by the state line eh? I will be going to Los Lunas New Mexico shortly...how is Hobbs? wet?.....Cliff
