Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-23-2008, 05:44 PM
pporcaro pporcaro is offline
Mein Auto: '86 325e
325e guibo?
so i thought this banging motion was my exhaust swinging until i fixed the hangers and put a new exhaust on. now the shake seems to be rotational and stops at 20mph and does it in first or second gear, if you push it a little bit. A buddy of mine thinks it's the guibo and it's all stretched out.
is replacing a guibo a DIY project?
any other ideas on what it might be?
thanks in advance
Old 09-23-2008, 06:05 PM
cliffmac cliffmac is offline
Banned
Mein Auto: 325ic
yes, the old guibo joint
quite typical, 6 bolts and nuts, 3 facing forward towards the front and 3 facing towards the rear...biggest issue is the propeller shaft bearing preloading not to mention the effort to DIY....but yes, the guibo will cause a shuddering upon acceleration, no question. Plus if not replaced it can cause a situation where the entire drive shaft may need replacing due to flange damage. While in there I would suggest examining the propeller shaft bearing as well, may or may not need attention...good luck...cliffmac
Old 09-23-2008, 06:22 PM
faviolosky faviolosky is offline
registered bimmer user
Mein Auto: 325e 1987
it could also be the center support bearing, so if your downthere already, might as well
Old 09-24-2008, 01:49 PM
Mein Auto: '86 325e
actually i already replaced the center bearing like 5 weeks ago because there was some serious hum coming from there.
Old 09-24-2008, 07:58 PM
ok then disregard lol
