Alarm goes off for no reason - Bimmerfest - BMW Forums
Old 10-06-2008, 06:48 AM
mgianetto's Avatar
mgianetto mgianetto is offline
Mein Auto: 2012 550I M-Sport
Exclamation Alarm goes off for no reason
I am not sure why this is happening but my alarm goes off out of the blue. I have been near the car and the siren and lights flash with out anything touching it. The windows are up and the sunroof is closed so nothing is moving in the car. Could a shadow cause this?
How do you lock without the alarm being set?
It seems that this started just after I installed the new battery.
Go Blackhawks
DABEARS
I have learned that you shouldn't compare yourself to others..
they are more screwed up than you think.
RIP: 2000 540 Sport
Old 10-06-2008, 07:56 AM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
This usually ends up being the hood alarm sensor, but theres 2 things id try. When locking the car hit the lock button twice (disables interior motion sensor and tilt sensor) if you still get random alarms disconect the hood sensor (its on top in the engine compartment, to the left of the right interior air filter). If that solves your problem then leave it disconnected or buy a new one. As far as i know you cant lock the doors without arming the alarm because even if you use the key to lock the doors it arms, however any bmw dealership can disable that feature for you (for a fee )
Old 10-06-2008, 09:09 AM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
dannyc9997 pretty much nailed the answers. Not sure if it will work on your car but on my '08 535i through iDrive I set it to re-lock after unlocking if no door is opened after a short period of time. This way no alarm is set.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 10-06-2008, 09:27 AM
PJB. PJB. is offline
Mein Auto: 2000 528i (01/2000 mfg.)
I'm with dannyc9997, usually it's the hood alarm switch that is the old design. Replacing it with the newer one fixes the problem but since you have a 2003 e39 I'm sure the updated switch is supplied already.
As for locking the car without arming the alarm you need to exit the car, close the front driver's door, enter the car through the rear driver's door and keep it open while you hit the central lock button to lock the three other doors, then pull the rear driver interior door handle out while pushing the lock down on the door to lock the final door. Close the door and your e39 is locked without the alarm engaged. Hit the regular unlock button on the key fob to unlock it. Obviously this should be used only as a temporary workaround.
Old 10-06-2008, 10:19 AM
mgianetto's Avatar
Ok that is crazy to do. I was told that the Indy shop can run the fault code to find the culprit.
Thanks guys.
Go Blackhawks
DABEARS
RIP: 2000 540 Sport
Old 10-06-2008, 10:28 AM
TimeOut's Avatar
TimeOut TimeOut is offline
Mein Auto: '10 Genesis V8 Tech
Just unplug the hood alarm switch. If the alarm stops acting, you know that you only need to spend $25 on a new hood switch.
None are more hopelessly enslaved than those who think they are free.
Gothe
Old 10-06-2008, 02:07 PM
dannyc9997's Avatar
Mein Auto: 540i
Wow thats a crazy way to lock your doors I think it would be easyer to lock all the doors, open the drivers door (it will unlock) hold in the door press switch and push down drivers lock then (make sure you have your keys ) close the door.
Edit: Nevermind I just tried that and it doesnt work....played with it for awhile and ended up with my door unable to close because I moved that locking mechanism (I have no idea what it is but I always seem to get in trouble when I play with them, also on the trunk lol) took me a few scary moments but pulled the door handle and it opened again
Old 10-07-2008, 12:54 AM
Freestyler Freestyler is offline
Mein Auto: E39 525 TDS
My alarm also goes off for no reason at all. So i've gotten used to always 'doubleclick' the lock button on the remote. Doubleclick = click it twice within 3 seconds to disable motion, tilt and electronics sensors.
Old 10-07-2008, 06:05 AM
mgianetto's Avatar
Fixed.. Spare Fog light???
Ok it was the bonnet switch. It was the only code that was tripped. Getting it today.
Now another weird thing was the alarm sensor was sensing the rear windows were open when the were closed. Well I hope this is the last of the annoying alarm going off for no reasons.
Anybody have a right side fog light laying around? The housing is broken on mine and need to fix it.
Go Blackhawks
DABEARS
RIP: 2000 540 Sport
Old 10-07-2015, 09:20 PM
cwaybest cwaybest is offline
Mein Auto: bmw x5
random alarm
Ok so i unhooked the hood sensor and the alarm is still sounding off randomly ..also the interior light comes on and then goes back off...what other suggestions ..i recently had battery tested and said it was fine could it be battery in the key ..i have now unlocked the doors to see if it only does it when its locked..
Old 10-09-2015, 08:53 AM
QSilver7's Avatar
Originally Posted by cwaybest View Post
...also the interior light comes on and then goes back off...what other suggestions ..i recently had battery tested and said it was fine could it be battery in the key ..i have now unlocked the doors to see if it only does it when its locked..
Hmmm, the interior lights come on when a door is opened or if the vehicle is unlocked. Do you have any door open/ajar warnings? I wonder if the issue may be a door actuator...again, due to the interior lights coming on.
A dying battery inside the key wouldnt cause false alarm triggering...it is only used to transmit the 315 MHz signal to the FZV receiver in the C pillar when a button is pressed. You aren't accidentally pressing a button on the key...like if you keep the key in your pocket when you go inside the house or work?
But the alarm siren itself has a rechargeable battery inside of it that is kept charged by the car's battery. A dying battery inside the alarm siren could false trigger...if the voltage drops enough, it could be interpreted as someone removing electrical power from the car in a theft attempt...thus it would sound the alarm:
Q {BMW CCA Member #191509}
(SOLD)
Old 10-09-2015, 01:37 PM
Mein Auto: bmw x5
I figured it out the motion sensor in the car when alarmed has gone bad so i have taken the sensor out ..have to order part but i can now lock car without alarm going off
